08-06-2012, 08:15 AM
#1 |
Oddometer: 183
School me on bar end weights
Hello Fellows,
I know that bar end weights reduce vibration but what determines how much weight is required? Do both weights need to weight the same or can they differ a bit? In my instance I have HDB handguards with their weights, but want to add a Kaoko cruise unit. I have a Kaoko unit already however, they do not make one that fits HDB handguards on a F800GS. I'm wondering if I cut the cruise unit down to size and it weights less than the opposing bar end weight if it will cause adverse vibrations. Has anyone done this? |
08-06-2012, 08:48 AM
#2 |
Oddometer: 119
I am newbie myself but on my F650GS I have the BMW hand guards which came with a new replacement set of bar end weights and Kaoko throttle lock, it vibrates at highway speed. The Kaoko only goes on the throttle side.
mustardfj40 screwed with this post 08-06-2012 at 08:54 AM |
08-06-2012, 08:58 PM
#3 |
Oddometer: 1,075
I've played with bar end weights on other bikes and they do help a lot. The only difference you should notice with only one is more vibration, especially on the throttle side. You might try something like bar snakes that go inside the bars to reduce vibration.
08-07-2012, 07:03 AM
#4 |
Oddometer: 3,434
I have the BMW handguards and was recently told the weights that come with this kit are lighter than the OEM weights...
I have not had time to check that to find out if it is true... Here are two folks that play in this area: http://www.vibranator.com/ (associated with Richor) http://www.barsnake.com/ Also some folks say they put lead shot inside the ends of the bars... On the F658GS the bars are plugged close to the ends so I'm not sure how that works....or if it works... Some discussion here as well: http://www.ukgser.com/forums/showthr...=136903&page=2 |
08-08-2012, 01:51 PM
#5 |
Danger: Keep Back 500 Ft.
Oddometer: 999
08-08-2012, 02:28 PM
#6 |
It is what it is
Oddometer: 178
The issue with handlebars is that they can act like a tuning fork, thereby causing numb hands. The purpose of the weight is to change the resonant frequency characteristics of the bar and the location where the vibration is least to where your hands are placed.
In plain english the amount of weight required is the amount that works (statement of the obvious). It really can be hit or miss. Moving the bar slightly from side to side (one side ending up being slightly longer than the other) can also have an effect (good or bad). I wouldn't stress too much about weights being different on each side. If you don't notice anything wrong, then you're good to go.
F800GS IBA#42277 SOLD - K1600GTL, S1000RR, R1200GSA, K1300GT, R1100, K75 http://www.scfoster.com |
08-08-2012, 02:32 PM
#7 | |
Location: Oakland, CA, USA, Thrid Rock from the Star Sol
Oddometer: 410
F800GS Mag/Black 2009 "Faucon GriS" Farkles; Garmin GPSMap478 in a TT cradle, throttle Rocker, Airhawk seatpad, Pivot Pegs, Renthal grips, SW-motech bars, MOD skid plate, Altrider headlight guard, HDB handguards, Maier Mudguard. Wishing for farkles; If/when I can ride offroad better- suspension, rims. |
