Old 08-07-2012, 05:39 AM   #16
kailuasurfer
Dreamer
kailuasurfer's Avatar
Oddometer: 379
Looks great! Is it a 2005?
Originally Posted by transalpian View Post
And here is my rig:
kailuasurfer is offline   Reply With Quote
Old 08-07-2012, 05:44 AM   #17
transalpian OP
Over, Across, and Through
Oddometer: 306
Yes, its a 2005 with a Champion Escort car. Hydraulic Brembo on the car wheel with Jay's TILT mechanism between the car and bike. I'm thinking its an upgrade from my old GL1000/Velorex 562.
Nowhere near as nice as your rig though! I'd love to know what your conversion cost....
I'm on a one-year bike buying hiatus. If I contact you about buying a bike, ignore me!!
On second thought, maybe I'm interested....
transalpian is offline   Reply With Quote
Old 08-07-2012, 05:51 AM   #18
kailuasurfer
Dreamer
Oddometer: 379
That will be an excuse for us to get together . Rocket III is an amazing sidecar pusher but I see very few Rocket rigs around. Did you make any steering modifications?
Old 08-07-2012, 05:55 AM   #19
transalpian OP
Oddometer: 306
Not yet. I talked to Brock at Steerite and will likely go that route this winter.
I had Unit leading links on my wing, but never really got it to where I wanted it to be. Have you seen any hub-steering setups for these? I was seriously Jonesing for a BMW GT1300 rig with a Hannigan HPS car, but at $19k I couldn't justify it yet.
Old 08-07-2012, 07:00 AM   #20
Bobmws
Curmudgeon At Large
Bobmws's Avatar
Oddometer: 1,350
I was also looking at a Yokohama S-Drive in 195/45/17. It looks to be about 1" wider than the 175/55/17 on kailuasurfer's bike above. I'll need to measure closely, but it looks like it might fit and is super easy to find here in the US. Here is that tire on a FJR1300 stock rear rim:
This rim is 5.5" wide (+2" than mine), but it looks like it might work? More to come....
Here is the Yoko on my BMW 5.5" rim. It was a real bitch to mount, I think a 2" narrower rim will distort the tread alot, the side walls are short and stiff. Even wit 6mm additional spacers the tire grew with road heat and rubbed the corner of the BMW swingarm, had to sand some rubber from the inside edge of the tread. I will probably go with the adapter from Claude and 15" wheel in the future.
Want to buy a slightly used (4000 miles) tire?
Bob Weis 04 K12RS - Hannigan Hack
Everything happens for a reason, but sometimes the reason is you're stupid and make bad decisions.
Photo's: http://s1077.photobucket.com/albums/w464/Bobmws/
www.earplugco.com
Bobmws is offline   Reply With Quote
Old 08-07-2012, 08:22 AM   #21
Melrone
Oddometer: 958
Thats like me looking for a 165HR15 pusher tire.I ended up by 165 80R 15.Which worked.I went through Mid America VW parts company got a NangKang..Did you check with either Cooper or Coker tires.They both specalize in odd size tires..Isn't it fun looking for tires.....
Melrone is offline   Reply With Quote
Old 08-07-2012, 09:02 AM   #22
transalpian OP
Oddometer: 306
No luck with Cooper.
On Coker, the closest thing is a 600/650R17 Excelsior Stahl Sport Radial. Main problem is that the thing is 29.5" OD (versus about 26.5" OD for stock). I know the width would fit and the tire would mount on the rim (tire recommended rim width is 3.62" to 5"), but I don't think it would clear the fender.
Its $285 and kind of looks like crap too....
Old 08-07-2012, 02:27 PM   #23
dholaday
dholaday's Avatar
Oddometer: 342
for 175/55R15:
http://www.tirerack.com/tires/tires....tnum=755TR5CPC
It is better to have ridden and crashed, than to have never ridden at all.
dholaday is offline   Reply With Quote
Old 08-07-2012, 02:50 PM   #24
triumphsidehack
triumphsidehack's Avatar
Location: Nowhere Indiana ,on the outskirts of Darmstadt
Oddometer: 78
175/55/17 option's
Hey Transaplian . Having the same problem for my Rocket 3 Rig .. . Stop in at Coker on the way back from a ride to see what they had to offer and the closest I got to a match was a.......... Excelsior All Black = 450-17" W/ 4" tread width and 4.50 sec width and 26" dia. cost $155.00 . But it was a tube type like the Excelsior Stahl Radial you looked at , and I'm not sure I want to go with a tube setup / close to needing another frt tire from the ride out to Colorado and back looks like only about 12K on this Macadam if I'm lucky. Good luck and post if you find something !
Oh...and i'm sending my tree's out to Brock this winter also ......29K with no mods is starting to get a little old for this 70 YRO senior. But man.... that monster motor makes up for heavy steering.
triumphsidehack is offline   Reply With Quote
Old 08-07-2012, 03:43 PM   #25
transalpian OP
Oddometer: 306
Originally Posted by dholaday View Post
Do they make a tire stretcher? Thanks, but we need 17" not 15"
Old 08-07-2012, 03:48 PM   #26
transalpian OP
Oddometer: 306
So are you a possible fourth for a group buy? (assuming price, etc)
Old 08-07-2012, 07:25 PM   #27
NortwestRider
TRIPOD ADVENTURER !!
NortwestRider's Avatar
Oddometer: 4,079
I have been running a 205/55-17 on my Vstrom with a 5.5 rim and fit and worked great,I also run this set up solo ( darkside )....
2012 Honda NC700XAR
1994 KTM440 exc
1983 IT490
GS500ADV..THE PURPLE EXPLORE
[B
NortwestRider is offline   Reply With Quote
Old 08-08-2012, 03:38 AM   #28
transalpian OP
Oddometer: 306
Not to change the subject, but didn't I see that you sold your rig? At least I think it was your rig for sale on sidecar.com...
Old 08-08-2012, 03:55 AM   #29
transalpian OP
Oddometer: 306
Tire Update
I have made contact with Rod at Motopodd! I guess the Olympics were too much a distraction for him?
Buying them 1 or 2 at a time will be very expensive ($300+). We are trying to see if shipping more of them via water will reduce the cost where it makes sense to more people. I don't know yet what the lower cost will be.
All that said, who might be interested in this tire?
--To be clear, we are talking about the Bridgestone Potenza RE040 in 175/55 R 17 --
We know it fits on a stock Triumph Rocket III 3.5"x17" front wheel. Doing a little digging on here shows it fits on the 1150/1200 GS 4"x17" wheel as well. This tire comes OEM to the Vauxhall VX220 on the front 5.5"x17" wheel.
This would be a pre-paid order, Rod would ship the lot to me, and I would ship to you.
I'm probably in for 2, seeing how difficult these are to find.
Anyone interested?
Old 08-08-2012, 10:14 AM   #30
Farmer1949
Out standing in his field
Oddometer: 218
Going on the old classroom assumption that if I have a question so do others....When you say expensive at $300, I'm assuming that is per tire FOB Ohio, correct?
I am interseted but want clarity on the price, ya know how cheap farmers are! What is the rough Breakdown?...Is this about right? Tire about $130 and shipping $170= $300/tire FOB Ohio? And hoping to lessen freight by getting a larger order?
"How hard could this be for men of our caliber?"
Farmer1949 is offline   Reply With Quote
Times are GMT -7.   It's 07:49 AM.
