Old 02-19-2014, 08:59 AM   #121
DrKayak
Retro Rider
Oddometer: 778
Originally Posted by slicktop View Post
How does the plug look?
I was quite surprised to find that at 80;1 my bike was running rich with even some unburned droplets of oil on the inside of the head. I haven't really run it hard yet so things may change. Also the inside of the exhaust is exceptionaly clean, which seems counterintuitive.
I will check the plug tonight.. good idea.. I had it smoke like this once last fall on a long climb. Got home and opened the muffler and it was exceptionally clean like yours...
Talked to Adrian yesterday and he said they generally don't re-jet the Evo. Hate to think the Evo just doesn't have the cooling capacity to be used on hard trail riding.
DrKayak is offline   Reply With Quote
Old 02-19-2014, 10:32 AM   #122
slicktop
Oddometer: 243
I run a Lectron carburetor on my husky 2t. Its a metering carb and the predecessor of the smart carb. It is a 'set it and forget it' deal. The atomization is unreal and very simular to FI.
When mentioning this upgrade on the beta I was snickered at and told I didn't need it.
Its the preferred mod over the pwk or tmxx on the Italian Husqvarna 2t. My fuel milage shot thru the roof!
slicktop screwed with this post 02-19-2014 at 10:38 AM
slicktop is offline   Reply With Quote
Old 03-21-2014, 11:39 AM   #123
lineaway
Oddometer: 2,862
Beta fix on 2014`s.
http://www.trialscentral.com/sub-hea...selector-fault
lineaway is online now   Reply With Quote
Old 03-22-2014, 06:41 AM   #124
slicktop
Oddometer: 243
Originally Posted by lineaway View Post
That could potentially be devastating if the rivet gets into the Idler, Clutch, or Flywheel gears. If any of those gears gets damaged you have to replace them all. It would be worthwhile to pull the cover and check for any loosening or play at the rivet. Potential damage could run over $1000.
Old 03-22-2014, 07:03 AM   #125
lineaway
Oddometer: 2,862
So what happened with the starter?
Old 03-22-2014, 05:30 PM   #126
slicktop
Oddometer: 243
All well now. Beta sent the clutch basket along w/ flywheel. I didn't change the flywheel or Idler gear and the same problem occurred. Then Beta sent the same setup and Stu sent the Idler gear and bearing. That seems to have fixed it. I have 15 mi. on it and have started maybe 10 times since fix.
Old 03-31-2014, 06:19 PM   #127
Gordy OP
Team Listo
Gordy's Avatar
Oddometer: 22,756
What kind of jetting are you guys using and at what altitude?
I currently have:
MJ 125
Pilot 48
Mostly at around 5,000 feet but have run this same jetting all the way up to 8,000.
Going to be riding at around 3,000 in few weeks and probably need to fatten it up, but to what?
Gordy is offline   Reply With Quote
Old 03-31-2014, 07:05 PM   #128
lineaway
Oddometer: 2,862
I`d say your already fat. Should run great in land.
Old 03-31-2014, 07:18 PM   #129
Gordy OP
Team Listo
Gordy's Avatar
Oddometer: 22,756
It runs good but I do think it is too rich judging on the splooge that was in the silencer. I'm thinking that it could run "better" if I was willing to work with this.
What do you think I should be running around here? I'm ordering a range tomorrow for both TX and mountains of NM.
Old 03-31-2014, 07:46 PM   #130
lineaway
Oddometer: 2,862
I would try a 120 for San Ysidro, maybe a 115 or 118 for Sipapu, Did the 125 come with the bike? If so a 118main and a 50 pilot might be a combo to try for home.
By the way that was the land owners LOGO. I`m not just crazy.
Old 03-31-2014, 08:02 PM   #131
BEEF706
King of the dumb dab
BEEF706's Avatar
Oddometer: 713
Is the new Beta hugely different from my Rev3? I have 30 pilot, 125 main and it seems to run really well (in the back yard anyway) and almost no spooge out the back.
NMOHVA Member NMTA Member
07 CRF450x, 04 Beta Rev3 270, I like red bikes
A good friend will take you trail riding, an ADV friend will double back and say, "how did you get down there?"
BEEF706 is offline   Reply With Quote
Old 03-31-2014, 08:24 PM   #132
lineaway
Oddometer: 2,862
Wrong carb Beef.
Old 03-31-2014, 08:41 PM   #133
Gordy OP
Team Listo
Gordy's Avatar
Oddometer: 22,756
Thanks Bob! I'll order some up mañana.
Old 04-01-2014, 07:13 AM   #134
BEEF706
BEEF706's Avatar
Oddometer: 713
Wrong carb Beef.
DOH! yup that makes sense.
Old 04-01-2014, 10:44 AM   #135
Gordy OP
Team Listo
Gordy's Avatar
Oddometer: 22,756
Bill at Balance Trials has me all straightened out.
115 or 118 and 52 around here.
125 and 50 at lower than 4,000.
For Sipapu and high elevations, just add a turn out to the fuel screw.
It is difficult to get your head around the fact that you have to fatten the pilot at altitude, but with trials bikes, you do!
Stick with the 3.5 slide here and go with a 4.0 only when close to sea level.
Times are GMT -7.   It's 05:42 PM.
