Thread Tools Rating: Thread Rating: 29 votes, 5.00 average. Display Modes
Old 02-02-2013, 09:20 PM   #151
pvangel OP
Team AARP
Oddometer: 2,512
pvangel is offline   Reply With Quote
Old 02-02-2013, 10:16 PM   #152
dirtydeeds
I'm alive.
dirtydeeds's Avatar
Oddometer: 2,648
Cool. I've seen similar units. I take it you have plans to vent it?
990SMT, 640A, TXC450, TE510, ATC350X, ATC200ES, 550MXC, BW200. Need more space in garage.
dirtydeeds is offline   Reply With Quote
Old 02-03-2013, 11:02 AM   #153
pvangel OP
Team AARP
Oddometer: 2,512
The heaters have a automatic shutdown when it senses a lack of oxygen, probably would leave in front of a vent or open window. Also will have a CO alarm.
Got started on the other side early today,
Made a cardboard template for the backsplash.
Laid it out on the diamond plate and transferred the layout.
Fit perfect! (with a little trimming)
Used a FRP trim piece for the exposed joint, cabinets will cover everything else.
Looks factory! just have to glue it all together now.
Old 02-03-2013, 11:47 AM   #154
dirtydeeds
I'm alive.
dirtydeeds's Avatar
Oddometer: 2,648
Remember that sufficient 02 does not mean there isn't an excess of CO. You can get CO poisoning with 21% oxygen. Your trusting only the CO alarm.
I'm not saying that using this will kill you in the event your CO monitor fails, but you may wake up with massive headaches and mild retardation.
Edit to add: CO is slightly lighter than air. Keep that in mind.
If you're only using it for a short time and shutting it down while sleeping, go for it. I wouldn't trust an unvented hydrocarbon burning heater in an enclosed box while asleep though. Do they have a vented version of that heater? I'd be interested in that.
Old 02-03-2013, 03:33 PM   #155
pvangel OP
Team AARP
Oddometer: 2,512
I really haven't planned on heat as I really haven't needed it in the past, maybe something to take the chill off at times? I know I am not spending $500 on a furnace.
Got the FRP up on the drivers side, uses a lot of glue. I used a whole gallon in the trailer.
I got the backsplash installed.
Trim ring and all!
Old 02-03-2013, 04:20 PM   #156
pvangel OP
Team AARP
Oddometer: 2,512
I got a lot done today! I'm exhausted...
FRP and diamond plate base are in.
And........ CABINETS!!!!
Uppers are INNNNNN!!!
Pushed the base into place just so I could see...
I am loving the portholes!
Time for Super bowl now....
Old 02-03-2013, 06:38 PM   #157
zgfiredude
Oddometer: 837
Great work! It looks awesome.
I'm curious as to how many bikes you think will fit, and how they are going to be arranged? That deep base cabinet has me a little concerned for how I have envisioned my own trailer in the future.
But she is a fabulous build!
'06 950S Adv, DRZ440E, KLX440R, DRZ250, & F650GS
zgfiredude is offline   Reply With Quote
Old 02-03-2013, 08:18 PM   #158
pvangel OP
Team AARP
Oddometer: 2,512
The plan was to get 5 bikes in there but it won't work, I wanted a 18" deep base cabinet but for financial reasons I went with a stock 24" deep cabinet. I thought about cutting it down but ...ain't gonna do it.
So I should be able to get 4 bikes in there, one up front and 3 wide across the back. I already put the bikes in there to try it and it seems to work, I will be doing the mounts and wheel chocks soon so we'll see.
Old 02-03-2013, 08:36 PM   #159
dirtydeeds
I'm alive.
dirtydeeds's Avatar
Oddometer: 2,648
I think I squeezed out a bit more room by putting in the chocks facing the walls, each one on the opposite side. Lay it out, it may work for you too.
My box is 8' across though; wide enough by about 12".
Old 02-03-2013, 08:54 PM   #160
pvangel OP
Team AARP
Oddometer: 2,512
Mine is a 6' wide so about 12" short...my life story
I did not want to go wider for ease of towing and MPG but 8' wide sure does make it easier to fit bikes in. In general we bring 4 bikes to the track but I still can fit 2 more in the back of the truck so I'm good for now...
Old 02-05-2013, 06:39 PM   #161
pvangel OP
Team AARP
Oddometer: 2,512
I have been waiting to drill the holes for the water fill and electric cord until I could borrow a 3-1/2" hole saw and today I did, dark and snowing I put on my LED headlight to drill away so I could return it tomorrow. I did take time to reflect what was wrong with me as snow flakes fell down my back as I drilled the holes (no court has been able to prove anything by the way) but I attributed it to be a good friend that wanted to return the drill as promised...
The mark-out.
Holes drilled and everything in for a test fit,
Water, electric cord, battery vent and a exterior outlet below. I didn't install anything as it is in the 20's and didn't want to caulk anything.
Old 02-05-2013, 06:52 PM   #162
pvangel OP
Team AARP
Oddometer: 2,512
Although to cold to do anything outside I planned on cleaning up my HD cabinet front diamond plate inlays... my way of making my regular(and cheaper) cabinets worthy of the build.
So first thing was to clean up the edges, started big but ended up small, a quick wire brushing and they were good to go.
Clamped in with wood so they don't get scratched,
Laid out the holes with ultra sophisticated equipment,
Pre drilled,
Countersunk,
And installed, a little silicone behind for adhesion.
And one section done!
Old 02-05-2013, 09:08 PM   #163
ShadyRascal
Master of None
ShadyRascal's Avatar
Oddometer: 6,407
Oh now this is getting so sweet it doesn't even make sense.
Originally Posted by Javarilla
Evolution, or, natural selection, has nothing to do with better.
It merely weeds out what is no longer suitable for the given context.
Originally Posted by Dragoon
I would rather be on my motorcycle thinking about God than in church thinking about my motorcycle.
ShadyRascal is offline   Reply With Quote
Old 02-05-2013, 10:13 PM   #164
dirtydeeds
I'm alive.
dirtydeeds's Avatar
Oddometer: 2,648
Agreed. Nice touch.
It's a beautiful project. Keep posting, we appreciate it!
Old 02-06-2013, 03:51 PM   #165
pvangel OP
Team AARP
Oddometer: 2,512
Thanks guys!
Pump showed which means I can do the plumbing soon, one more missing piece and I can do all the plumbing.
Thread Tools
Times are GMT -7.   It's 06:05 PM.
