02-21-2013, 07:16 AM
#226 |
I'm alive.
Very pimp.
I like the helmet brackets. |
02-21-2013, 05:09 PM
#227 |
Team AARP
Oddometer: 1,463
02-24-2013, 04:31 AM
#228 |
Team AARP
Oddometer: 1,463
Bed time!
I pre-cut all the rails at work, ![]() All set for 3/8" plywood base, ![]() ![]() I used some of my ultra sophisticated layout equipment "can-o-screws" to set my double radius rail drop, ![]() Evened em up with a block plane, ![]() Some time with a belt sander to clean up the drops, ![]() Pre assembled to make sure it all fit, and it did! ![]() "Wide" body for me and the narrow one for my son, the narrow one will double as a couch so didn't want it to be too wide.
02-24-2013, 09:38 AM
#229 |
Team AARP
Oddometer: 1,463
Only problem I'm having is that I had convinced my lovely wife Sister Mary Margaret (3 children from immaculate conception automatically grants you sisterhood) that when I lost (outgrew) my carpenters tool belt I lost all my carpentry skills with it, I have not had to fix anything around the house for years but I blew it with this build...
![]() And now i'm painting, no idea how to get out of this one.... But... after examining 100's of color charts and paint chips I have found (I had a gallon of paint leftover from another project) the perfect color to match the floor. ![]() Now if I can just hide from SMM for another week or two I can finish this trailer |
02-24-2013, 11:36 AM
#230 |
Team AARP
Oddometer: 1,463
Test fit the beds,
![]() I will hinge with a full piano hinge but have not figured out exactly how I will do the legs, I was hoping the whole bed would be stiffer. I probably should have used 1/2" plywood but will stiffen it with some steel that I will mount the legs too. I have a plan but just need to refine it.
02-24-2013, 11:48 AM
#231 |
I'm alive.
Looks like they fold up decent enough. Will you be using any particular type of mattress or just any type?
Where did you find the hinges from? Looks good. |
02-24-2013, 02:38 PM
#232 | |
Team AARP
Oddometer: 1,463
Mattress will be foam, Lux Foam - Regular from www.thefoamfactory.com $46.00 each and custom cut to size. Have to convince Sister Mary Margaret to sew covers on them but I can sweet talk her into it... |
02-24-2013, 02:56 PM
#233 |
Team AARP
Oddometer: 1,463
3 coats of paint and the bed frames are done,
![]() And of course they have to have some diamond plate on the bottom, ![]() I have to figure out the folding legs now and get the hinges. I can't figure out what to do with the countertop, was going to buy a premade at HD or Loews but according to the Misses the colors weren't right ( I'm color blind but can see diamond plate just fine). Interesting fact that I saw a bar sink and faucet that would be perfect for $99 at the HD close to where I work but was in Connecticut at a HD and it was $110, I didn't think that they changed prices between stores and there probably only 30 miles apart. |
02-25-2013, 08:45 AM
#234 | |
I'm alive.
It's a nice way for stores to say "we rip people off at every chance we get" Thanks for the foam factory link. Good call on doing the wood cutting at work. I've done that once in my garage. Covered everything in saw dust. The Jeep, 1/2 a dozen bikes, liquor cabinet, desk, 440ci that's in the corner - everything. Now I can't be bothered to cut wood inside. |
02-25-2013, 04:02 PM
#235 |
Team AARP
Oddometer: 1,463
I HATE cutting anything in my garage, I vacuumed a few times while working on Sunday after cutting the remaining diamond plate and the sanding of the beds. When I rebuild a motor I don't want to worry about a metal shaving or dust getting into my motor. Mechanical shops and woodworking do not go together... I will take everything out of my shop when I am done with the trailer and vacuum every bit I can.
My custom made shower box finally showed up! Not crazy about the quality of it as the door doesn't close and rattles back and forth about 1/4" but will fix with weather stripping....oh well, nobody cares about quality anymore :( ![]() I had it made to fit the outdoor shower heater, ![]() At least it fits. ![]() 38 days till the first race, need to get'er done! |
02-25-2013, 06:40 PM
#236 |
Team AARP
Oddometer: 1,463
OK....I know I have gone to far but really can't stop now... I ordered fabric samples from www.fabric.com to cover the foam I ordered and a pillow for the couch because you know it has to look good...
![]() $8.99 a yard for a outdoor fabric which Sister Mary Margaret says is a deal! And.... She will sew em up for me. That's a good woman! ![]() Am thinking the gray for the mattress/couch cushion and red for the pillows, $54.00 and a dinner out at Mcdonalds (I'll let her supersize) |
02-25-2013, 06:53 PM
#237 | |
Radical centrist
Oddometer: 21,238
Seriously, you are doing an excellent and interesting thread. Keep up the good work. Maybe the inmates here should take up a collection so that You and Yours could at least hit the Outback ;) Sent from my iPad using Tapatalk HD
PirateJohn -- http://www.PirateJohn.com IBA #7552 - SS1K in 2000 and 50CC in 2002 In the Laredo, TX area and always willing to help travelers escaping into Mexico.
02-26-2013, 02:58 PM
#238 |
Team AARP
Oddometer: 1,463
Outback is reserved for special occasions like a anniversary, If you bring them there all the time they will expect it....
![]() Applebees maybe but that really is for birthdays... And... your right I am such a white guy, you should see me dance...pitiful AND on that note I am not using the gray fabric, all red because that's right, I'm a rebel. |
02-26-2013, 09:56 PM
#239 |
I'm alive.
My Transmogrifier build has a friend of mine itching to start something.
As fate would have it, this ended up in his possession. For FREE. ![]() Apparently the interior is decent. The engine and trans were robbed out of it. We'll see what happens with it. Hijack over. Where is Cracker Barrel in your Order of all things Matrimonial? |
02-27-2013, 06:26 AM
#240 |
Team AARP
Oddometer: 1,463
Cracker Barrel is only for when my Mother is in town...I thought everybody knew that?
Nice rv.. throw a 318 in her and get many more miles. |
| Thread Tools | |
