Old 08-19-2012, 09:37 AM   #16
sailwing2003
Oddometer: 329
I had about the same needs and looked at doing the self build. I ended up with a Work & Play 18LT for only 50% more dollars than your budget.
It was a easy deal, got ready to do Moab in a couple of weeks after buying. Used it for a number of trips, and it worked great. Much better build quality than most of the rv style toyhaulers. Those are just stick walls on frame, with usually rubber roofs. The Work & Play are solid walls, and bolted on all 4 joints, and seem to last for years. They are heavier, and the longer ones are the same price as the 16' and 18' when I was shopping used. If I had been looking for a bigger W&P I could have traded up, as those were wanting to trade down, due to having too small of tow vehicles.
Good luck with your build.
Dave Cobb
Pantego (DFW) TX
08 R1200GSA Adventure 11-08
1998 Foretravel 36' Unicoach 295
sailwing2003 is offline   Reply With Quote
Old 08-19-2012, 05:24 PM   #17
pvangel OP
Team AARP
Oddometer: 1,502
I agree the Work&Play are great trailers but they are so heavy (which is why they last so long) and am worried it will kill my gas mileage, I'm thinking under 2000 lbs for my build trailer and those are closer to 4000lbs.
If I had a diesel I wouldn't think twice on the W&P but the 1/2 ton gas truck will suffer I believe...
pvangel is offline   Reply With Quote
Old 08-19-2012, 05:49 PM   #18
pvangel OP
Team AARP
Oddometer: 1,502
I just checked and the 18' weighs 5200lbs, thats a heavy trailer.
If my build trailer starts at 1300 lbs and I add 700 to it (which I don't think I will) then add 5 bikes at 200lbs and say another 500lbs of gear etc than loaded it would be 3500 lbs. I'm guessing 3000 loaded but still that is a big difference.
Old 08-19-2012, 05:57 PM   #19
ragtoplvr
Oddometer: 4,596
much of the gas mileage hit is from the trailer frontal area. Some streamlining pays big dividends.
Rod
ragtoplvr is offline   Reply With Quote
Old 08-19-2012, 06:39 PM   #20
pvangel OP
Team AARP
Oddometer: 1,502
The wind drag is a valid point and I am sure it effects the mpg but...
If you take a 5200lb trailer and add the same weight, 1500lbs to it that's 6700 lbs versus 3500 lbs that's a ton and a half extra your pulling up a hill and that's will definitely effect mileage,
Old 08-27-2012, 04:08 PM   #21
pvangel OP
Team AARP
Oddometer: 1,502
I have been busy so haven't spent much time on the trailer hunt but did stop today on the way home from Boston and saw a nice one, a 7x14 vnose but am stuck now on the size and think it might be too big?
My current trailer is 5x8 so 40 sqft and definitely to small.
I have been looking at 6x12's(72 sqft) but feel there a little tight for what I want so have been drawing plans for a 7x12 or 6x14(84 sqft), the 6x14 is not a common size but the 7x12 is.
So the trailer in the pic is a 7x14 (98 sqft so more than twice my current trailer) and seemed huge inside, I had a 7x16 before that was great as far as room goes but to big for my needs now.
The trailer in the pic is 1865 lbs empty so if I added 400lbs to it outfitting it and then 1000lbs of motorcycles thats 3265lbs loaded to go. Even 3500lbs would be doable.
Not sure if I should save a couple hundred pounds for a single axle (trailer in pic has brakes on both axles) and 14 sq ft, or go for the bigger trailer? I like the vnose with the drop as it should cut through the wind better.
Old 08-27-2012, 07:38 PM   #22
DirtyOldMan
Oddometer: 1,718
My hillbilly rv
Kitchen hangs on the outside. That's the shower cutain on the left
bunk folds up against the wall, for now guests use a cot.
It'll hold 3 bikes easy, (shower test in progress)
Shower in use
It's a 6x12 vee nose, you can haul larger ones with a half ton truck but I don't want to and this one is adequate for my needs. Water for shower is heated by a propane camp heater, gravity fed from a container on the roof, through the heater and into a container on the ground. Then the container on the ground is placed on the roof and rub-a-dub-dub.
Surprisingly, the 7gal container spewed water uninterrupted for a full 20 minutes.
04 250 RFS
99 640 ADV
13 650 Terra
DirtyOldMan is offline   Reply With Quote
Old 08-27-2012, 08:59 PM   #23
sailwing2003
Oddometer: 329
Back to help. See you had a Work & Play. Mine was 8' wide, and while I liked the interior space, your idea of a 7' wide trailer would be better in many ways.
I towed with my half ton Avalanche with SnugTop topper, and up hill from Ft. Worth to Amarillo, to Moab, in head winds I was getting sometimes less than 7mpg per tank. With a tail wind, up hill, east bound out of Albq. NM I was amazed to get a 12mpg tank. It seemed to be the wind, more than the weight of the trailer with a GSA and X-Challenge inside. I once towed 400 miles to the coast and back without bikes, and got hammered on mileage again with winds.
8' trailers required mirror extensions to be able to see down the side of the trailer on the highway, and backing. The truck is 6' wide, standard mirrors work well with 7' trailers.
If doing again, I would sure buy another Work & Play, but if I were building, v-nose, 7'. I would also go tandem axle, hoping to be able to tow on a flat tire till I found a safe spot to change the flat one. And with a tandem you can often drive up on a stack of wood blocks with the single good tire to change a bad one, without risking a jack accident, or messing on a badly sloping shoulder.
Dave Cobb
Pantego (DFW) TX
Old 08-28-2012, 09:00 AM   #24
OaklandStrom
Oddometer: 1,508
The reason I ended up with a 14x7 is that it was the smallest trailer I could find with tandem axles. Each axle (in general) has a 3,500# capacity, if it has brakes. A single axle trailer is good for 3,500# and a tandem is good for 7,000#.
I also like the security of a second set of wheels on the ground.
OaklandStrom is online now   Reply With Quote
Old 08-28-2012, 09:58 AM   #25
ghostrider.y2k
ride enything but HD
ghostrider.y2k's Avatar
Oddometer: 789
This is what we use, works great.It will be for sale next spring when new replacement get delivered.
MOTORCYCLES-->created to keep us from choking the idiots around us
"w strone slonca..........."
www.rapidroadrescue.com
ghostrider.y2k is offline   Reply With Quote
Old 08-28-2012, 03:16 PM   #26
pvangel OP
Team AARP
Oddometer: 1,502
Those are cool but tough to use for my daily trips to the track and huge tongue weight.
Old 08-28-2012, 03:17 PM   #27
pvangel OP
Team AARP
Oddometer: 1,502
I agree on the second axle, I think it's much easier on the tires to spread the weight out.
Old 08-28-2012, 03:19 PM   #28
pvangel OP
Team AARP
Oddometer: 1,502
The 7' wide dual axle is making sense to me as well, the trailer in the pic is pricewise the same as a single axle because it's on special which makes it that more atractive to me.
Old 08-28-2012, 03:40 PM   #29
pvangel OP
Team AARP
Oddometer: 1,502
DOM, Love the hillbilly trailer and will be using some of your ideas, your folding bed is close to what I was thinking.
Old 08-28-2012, 03:58 PM   #30
pvangel OP
Team AARP
Oddometer: 1,502
I was going to use the Blazintech couch like this one but know from sleeping on them that they suck for sleeping and at $500++ each I think I can build something better.
Same thing on the Bunk beds, although I think these are better to sleep on than the couch, for another $500 I think I can build them better.
Thread Tools
Times are GMT -7.   It's 10:59 PM.
