Old 08-10-2012, 10:00 PM   #1
mustardfj40 OP
mustardfj40's Avatar
Oddometer: 140
How do you open the snout on Rotopax?
Hi, how do you open the snout on the Rotopax to let the gas out? No matter what I tried couldn't get the gar to pour out. I turned blue dial which has the small arrow to point to picture with open lock, but nothing came out. After some trying and cursing, the little spring inside the blue dial popped out. I think I screw up already.
Has one try to modify the snout?
Thanks.
mustardfj40 is offline   Reply With Quote
Old 08-10-2012, 10:10 PM   #2
JustKip
JustKip's Avatar
Oddometer: 4,455
Did you remove the stopper from the end that goes INSIDE the can?
DAMHIK
JustKip is offline   Reply With Quote
Old 08-10-2012, 10:26 PM   #3
DaymienRules
Traffic target
DaymienRules's Avatar
Oddometer: 197
Turn it to unlock, then push it towards the can.
DaymienRules is offline   Reply With Quote
Old 08-10-2012, 10:54 PM   #4
mustardfj40 OP
Oddometer: 140
I think I did, is it the the little back thing the size of a dollar coin? Thanks
Old 08-13-2012, 09:51 PM   #5
TJ Willy
ADV, this, I crave.
TJ Willy's Avatar
Oddometer: 345
Yeah, you have to turn and pull it down.
Phil
2009 Solo TAT Ride Report
01 F650 Dakar | '99 Triumph Trophy 1200
SmugMug Goodness Coupon Code (GZnn7vYHaHJjg)
TJ Willy is offline   Reply With Quote
Old 08-13-2012, 11:35 PM   #6
raceu2
Oddometer: 39
I got one of these had the same problem. you'd think for the price they would tell you how it works
raceu2 is offline   Reply With Quote
Old 08-14-2012, 01:01 AM   #7
Shov3BR
Tinkerer
Shov3BR's Avatar
Oddometer: 282
RotoPax
You don't. Just throw it away and purchase the RotoPax water spout.
http://www.rotopax.com/Self-Venting-Spout.html
Shov3BR is offline   Reply With Quote
Old 08-14-2012, 10:23 AM   #8
Wadester
Rides a dirty bike
Wadester's Avatar
Oddometer: 1,964
From Rotopax:
http://www.rotopax.com/ECO-Spout.html
TO USE THIS SPOUT TWIST GREEN RING TO THE UN-LOCKED POSITION AND THEN PUSH OR APPLY PRESSURE TO THE SPOUT UNTIL IT SLIDES 1/4" AND THE GAS WILL FLOW.
Two roads diverged in a wood, and / I took the one less traveled by, and / now where the hell am I?
This isn't a "you're doing it wrong" topic. (Originally Posted by Human Ills, 7/1/14)
Wadester is offline   Reply With Quote
Old 08-14-2012, 10:32 AM   #9
TurkeyChicken
TurkeyChicken's Avatar
Oddometer: 186
That spout is a giant POS. The spring popped off of mine after spending 20 minutes trying to get it to work. I ended up having to forget about the spout and try to fuel up straight out of the rotopax which was a bit of a pain.
TurkeyChicken is offline   Reply With Quote
Old 08-14-2012, 10:45 AM   #10
Alleycatdad
Unbunch yer panties!
Alleycatdad's Avatar
Oddometer: 1,439
I dunno. I have two and they're the best working Cal spouts I've ever had. Just hook the little, er, hook on the end of he spout on the edge of the tank opening, turn the ring to the unlock and give a gentle push. Works great.
California spouts suck, no doubt about it, but these work fine for me.
S
When in doubt, PIN IT! It may not help, but it'll sure end the suspense...
Wretched Exce$$ See ADVr's around the world-ADV spotwalla page
Riding Wretched Wretched Passes
Bad decisions make good stories.
Alleycatdad is offline   Reply With Quote
Old 08-18-2012, 01:47 PM   #11
Shov3BR
Tinkerer
Shov3BR's Avatar
Oddometer: 282
RotoPax self venting Fuel Spout
A bit of clarification on my recommendation to use the yellow self-venting spout (post #7). I inidcated that it was for the water RotoPax. This might lead one to believe it is not suitable for fuel. Not the case. It is also shipped with the international FUEL RotoPax so it is safe to use with all fuel RotoPax. See RotoPax webpage last line of the description.
I just returned from a ride UK to Uzbekistan and the RotoPax were required where decent fuel was difficult to find. Pics aren"t the greatest but here's my 990 in UZ. Mount is a modified RotoPax Polaris RZR Plate + Pack Mount.
http://www.rotopax.com/Polaris-RZR-P...ack-Mount.html
Old 08-18-2012, 11:30 PM   #12
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,228
Originally Posted by Wadester View Post
From Rotopax:
Originally Posted by bassogap View Post
If my aunt had nuts, she'd be my uncle. What's your point?
Manic Cycles=My Blog
ben2go is offline   Reply With Quote
Old 08-19-2012, 09:14 AM   #13
steve_k
steve_k's Avatar
Oddometer: 1,062
Mine works just fine, but might switch to the water spout to make it even easier.
steve_k is offline   Reply With Quote
Old 08-19-2012, 10:46 AM   #14
Wadester
Rides a dirty bike
Wadester's Avatar
Oddometer: 1,964
There is one thing about these - I recall it from a coleman fuel can spout I've got:
The push direction is in line with the screw connection - NOT in the direction of the spout. If you push directly in on the spout - it wants to bind up the valve! You have to push in line with the valve, which puts a bit of a side load on the spout, but that doesn't give you problems unless what you're fueling can move in that direction.
Old 08-19-2012, 04:34 PM   #15
el profe
el profe's Avatar
Oddometer: 144
I somehow broke my spout fighting to get the bike gassed up by the side of the road. The spring fell off, then something else broke off so that the green collar you have to twist isn't in the way anymore, I just push the spout in and gas pours out-- all over the effing place.
el profe is offline   Reply With Quote
Times are GMT -7.   It's 05:34 AM.
