Old 06-05-2014, 06:50 PM   #1
TyeGagne OP
Oddometer: 5
Question XL600R Headlight Trouble
Hello,
Long time reader, first time poster. I just picked up a 1985 XL600R. Before I got it running, the headlight as far I can remember worked fine with just the key in the 'on' position.
Today I got it running great, and now the headlight wont work at all. Running or not. Turn signals are working fine.
The bulb is good (swapped it out for another good one to check) , connections are decent as far I as I can tell everywhere.
Possible culprits?
- Rec/Reg? the other finned rec/reg(I dont remember which it is?)
- If so which one, and how do I test the current units to see if they good or not.
- Switch (how to test?)
- Stator? The headlights worked with just a battery as far I as I can remember
- (Battery is charged and healthy)
Any other ideas, I appreciate the help.
TyeGagne is offline   Reply With Quote
Old 06-05-2014, 06:55 PM   #2
TyeGagne OP
Oddometer: 5
Could it potentially be a faulty ignition switch as well? The switch is a little finicky to get power through to turn on the neutural light, and the speedo light.
Old 06-05-2014, 07:30 PM   #3
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,816
The headlight only works when the engine is running. Get a multimeter and start testing.
My high beam quit working the other week, turned out a soldered connection broke in the hi/lo switch.
'83 Honda XL600R 618cc 11:1 Wiseco, XR's Only Exhaust + over sized header
Originally Posted by Carter Pewterschmidt View Post
He's the XL600 Jesus, his bike dies for our sins.
RFVC600R is offline   Reply With Quote
Old 06-05-2014, 07:31 PM   #4
RFVC600R
SAND EATER!
RFVC600R's Avatar
Oddometer: 2,816
http://advrider.com/forums/showthread.php?t=245878 That is where the XL600 guys hang out
Old 06-05-2014, 07:38 PM   #5
davek181
davek181's Avatar
Oddometer: 881
If it is a US spec XL the headlight does not come on with the key. The headlight is powered from the stator with a/c current. The current gets voltage regulation, and none of the power goes to the battery, and battery voltage has no bearing on the headlight. The instrument lights and turn signals and brake light and horn are d/c (battery) powered.
If memory serves me well the yellow/white wire out of the stator is the headlight circuit. It travels to the dimmer switch and then headlight, no other switches involved. It just gets power when the engine is running only, and switches off so to speak with the engine.
davek181 is online now   Reply With Quote
Old 06-05-2014, 08:29 PM   #6
TyeGagne OP
Oddometer: 5
Does the wire from the stator run through either of the reg/rec or the AC regulator?
Times are GMT -7.   It's 07:11 PM.
