Go Back   ADVrider > Riding > Layin' down tracks > GPS Tracks - West & PNW
Old 08-15-2012, 02:26 PM   #1
hayshaker OP
hayshaker's Avatar
Oddometer: 388
WBDR E-burg fire re-route
This is a possible re-route for the WBCDR due to the fire closures near Ellensburg Washington. Reecer Creek Road is closed to through traffic as of 8-13-12 because of the Taylor Bridge Fire.
I do not know the Wenatchee/Squilchuck/Stemilt area all that well and welcome ideas and suggestions. This thread is just a start to provide info to those that are in the process of trip planning. It is hard to say how long the roads will be closed. With SR 97 and HWY 10 being close I chose NOT to send the route to Liberty.
TONY
Eburg fire reroute.gpx
2014 450XC-W, 2006 KTM 450 EXC, 2010 KTM 990 Adventure, 1995 Goldwing Trike
George, WA
hayshaker is offline   Reply With Quote
Old 08-15-2012, 04:08 PM   #2
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,479
Thanks Tony!
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is offline   Reply With Quote
Old 08-15-2012, 05:37 PM   #3
pdxmarcus
pdxmarcus's Avatar
Oddometer: 31
Got it!
Much obliged, Tony!
2009 KTM 530 XC-W
pdxmarcus is offline   Reply With Quote
Old 08-15-2012, 08:22 PM   #4
dvwalker
Working to ride
dvwalker's Avatar
Oddometer: 768
tony, watching the local news looked like the fire may have been located west of the wind generators, just off of 97.
Do you know if they closed down NF-35? It may be possible to route out of Ellensburg north on Wilson Creek to NF-3517 to NF-35....This would keep Table mtn and Mt Lillian in the route if that is the case....You're route also works, and one could back track to Mt Lillian.
dvwalker is offline   Reply With Quote
Old 08-16-2012, 09:50 AM   #5
hayshaker OP
hayshaker's Avatar
Oddometer: 388
Latest fire map http://www.co.kittitas.wa.us/respons...0-fire-map.pdf
My professional instinct is to recommend staying well away from the fire area for a couple of weeks at best. Even though the fire has not burned to there still makes me think that the roads will be closed due to evacuations and firefighter safety. It might be possible to route up through Coleman Canyon to Naneum Bridge to Grouse Springs to tie into Liberty/Beehive Road but is not an easy route on a big bike. It's something I would do but don't know everyones riding capabilities.
Another option might be to go all the way into Cle Elum and use 970. There is a road to Liberty/Beehive that goes almost directly to Haney Meadows but seems out of the way to me with the closures on 97 near Ellensburg.
George, WA
Old 08-16-2012, 10:24 AM   #6
DockingPilot
Oddometer: 9,479
You still thinking Colockum Road is a option as well ?
Frank Reinbold
Old 08-16-2012, 01:07 PM   #7
hayshaker OP
hayshaker's Avatar
Oddometer: 388
Yes, I have not seen any mention of a closure there. The route I posted keeps you out of the worst rocks by using Naneum Ridge to Jump Off Joe Road. It also uses the most dirt I can think of in that area as opposed to staying on Colokum Pass all the way down to Malaga. If you stay on Colokum to the North it gets pretty rocky for a few miles.
If the down log in Mission is an issue then you could go through Malaga to #2 Canyon and hit that bypass posted months ago.
Hmmm..if Colokum is open then Coleman probably is too. That may be another option along with the route out to Mission Peak. It offers a good view.
It is just hard to say when things will return to normal.
George, WA
Old 08-16-2012, 01:16 PM   #8
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,265
thanks for the update.
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 08-16-2012, 08:49 PM   #9
dukegnarley
Oddometer: 224
thanks for the update, I'm leaving the gorge on the 1st
dukegnarley is offline   Reply With Quote
Old 08-21-2012, 08:38 AM   #10
hayshaker OP
hayshaker's Avatar
Oddometer: 388
Posted this in the PNW section too but Reecer Creek might be open.
http://co.kittitas.wa.us/response/20...re/default.asp
TONY
George, WA
Old 08-21-2012, 08:46 AM   #11
DockingPilot
Oddometer: 9,479
Meaning the Taylor Bridge fire is snuffed and route open Tony ?
Frank Reinbold
Old 08-21-2012, 11:24 AM   #12
hayshaker OP
hayshaker's Avatar
Oddometer: 388
Not out.... but under control (I still have a fire truck and crew there). If you look at the map it shows some road closures but Reecer Creek is not one of them. I'm hoping someone gives it a try and posts back if it is open.
TONY
George, WA
Old 08-21-2012, 11:47 AM   #13
DockingPilot
Oddometer: 9,479
Thanks for the current info Tony
Frank Reinbold
Old 07-02-2013, 03:04 PM   #14
Yukondoit
Oddometer: 5
Any other information about this closure?
I'm headed South (Doing it backwards just like Canucklehead) and came across the gate closed at the end of Mission Creek Rd (at the start of NF 7100) at the Cashmere end. Something about repairing the damage from the 2012 fire.
I tried to re-route but my dang gps put me into some super narrow single track that eventually turned into a 12% grade. Didn't it know it was dealing with someone of questionable skills. At that point, late in the day, I headed for my sisters in Enumclaw with my tail between my legs.
I'd like to do this section as it looks to have great views and camping spots. Anyone know how far the road closure extends.
Also, I know this might not be the right thread but are there more closures in the Southern sections?
And finally I did run across a high lead logging operation smack dab in the middle of the trail just north of Cashmere. They were kind enough to let me go through. If you're going north there will be plenty of warning but coming south I was almost on top of them before I realized it.
Yukondoit is offline   Reply With Quote
Old 07-02-2013, 05:52 PM   #15
hayshaker OP
hayshaker's Avatar
Oddometer: 388
We rode much of the same section that you were having trouble with over the weekend. The logging equipment was sitting in the road but was easy to sneak through. The WABR thread in the Northwest forum should have a suggested re-route. All you had to do was ride through Wenatchee and catch the Liberty/Beehive Road to get back on the route. This is a better route rather than the "fire re-route" I posted. I'll strip out those track files and post them.
George, WA
Times are GMT -7.   It's 11:37 AM.
