Old 08-25-2012, 07:14 PM   #46
jrsndman
Oddometer: 74
I have mine mounted in side my right hand guard. I painted it flat black. You can't even see that it's in there. Works every time.
As those of us in the Philadelphia area know, you can't just ride through all the tolls and look for it on your bill. The bridges between PA and NJ have gates that don't open if the transponder doesn't read.
jrsndman is offline   Reply With Quote
Old 08-27-2012, 01:56 PM   #47
Old_Crow
Old_Crow's Avatar
Oddometer: 133
Laugh What ez pass?
Just so you know - I've gone through ez pass in NJ without actually having the unit in my car. I was charged the normal toll rate, so I'm guessing they can just read your plate and charge you that way. Also I've gone over the bridge from PA to NJ with no EZ pass in the car and the gate opened anyway (I was going to drive through it if it didnt )... they're not going to detain you if they don't get a clean read!
I have one ez pass unit and two cars, which are both registered to the same unit. To bail out of a traffic jam I just went through the ez pass lane despite not having the unit in the car... everything's been fine ever since. I bet you could just register the bike on the website and drive through ez pass at will with no unit mounted up at all.
The online procedure for disputing an EZ pass ticket is very simple so no worries there, just make sure your bike is registered to your account.
Old_Crow is offline   Reply With Quote
Old 08-27-2012, 02:19 PM   #48
teizms
teizms's Avatar
Oddometer: 1,739
As mentioned earlier, Texas has the sticker type pass so its not a big deal. But for larger transponders one option could be a jacket pocket that would allow the pass to work:
One other implementation i have seen is a gps type mount with the transponder velcroed on it. or velcro the pass on top of the caps around the bars. check the top left of this image.
Same discussion here:
http://www.bmwlt.com/forums/showthread.php?t=61294
teizms screwed with this post 08-27-2012 at 02:43 PM
teizms is offline   Reply With Quote
Old 09-03-2012, 10:27 PM   #49
ScienceOfDirt
U-Boat Rider
ScienceOfDirt's Avatar
Oddometer: 1,753
I have the previously mentioned holder on my right mirror stalk. It doesn't seem to matter that it is to square to the ground.
Friend: That was some trail shortcut. Me: Yep. See how fast we got lost.
ScienceOfDirt is offline   Reply With Quote
Old 09-04-2012, 09:01 AM   #50
der_saeufer
?איפה בירה
Oddometer: 688
Originally Posted by SFCommuteRider View Post
If the transponder doesnt register the system looks up your license number and adds to your account But, They charge the full fare instead of the reduced carpool fare for motorcycles! Check your bill.
I've never been charged the full fare when going through at carpool hours, though I think that's what happens on the Golden Gate if your tag doesn't read since you have to go through a staffed lane to get the discount. The state-owned bridges will get you for the correct amount.
Originally Posted by trc.rhubarb View Post
Had me scared there!
Here's a line from a bill (looks like I got lucky):
Tag Agency Plaza Entry Time Entry Exit Debit Balance
CA20N5436 CALT BEN 08:45:39 17 - - $2.50 $18.40
The loop detector in the carpool lane's pavement on the Benicia-Martinez bridge is very easy to dodge. Just saying.
der_saeufer is offline   Reply With Quote
Old 09-04-2012, 05:42 PM   #51
trc.rhubarb
trc.rhubarb's Avatar
Oddometer: 2,050
Hmm... I'll have to look closer
2007 BMW GS Adventure / 2000 Ducati 900ss / 2010 Harley Ultra Limited / 1975 BMW R90/6 / 2006 DRZ400S
Follow me here
trc.rhubarb is online now   Reply With Quote
Old 09-04-2012, 06:14 PM   #52
Doug Just Doug
Silly Party Candidate
Doug Just Doug's Avatar
Oddometer: 580
My EZ Pass transponder (same beige unit as my cars use) is just thrown in my tankbag and AFAIK has never failed to register.
2003 Kawasaki ZR-7S
ADVRider Relay 2008 - Delaware
My stupid little website:Tilted Horizons
Doug Just Doug is offline   Reply With Quote
Old 09-12-2012, 06:55 AM   #53
deltamark
Oddometer: 45
EZ Pass
I ride the Ohio Turnpike every day to work. ($$$) I have a small Chase Harper barrel bag on my handlebars that I use. I wedge the EZ Pass in so that it sticks up and out of the bag on the right side. I then close the zipper tight against it. This works as long as you're not riding on too rough of a surface. I did lose one once after hitting a hard bump, but have doing this every day for the past few years and it works. I also use the bag to keep a small can of chain lube, tire pressure checker and whatever else.
2012 Triumph Tiger XC, 1999 BMW R1100RT, 2013 Cabela Hiking Boots
deltamark is offline   Reply With Quote
Old 10-06-2012, 05:20 PM   #54
SwissFreek
Oddometer: 32
Originally Posted by phantomjr View Post
In New Hampshire the black 2x7 transponder is the one they give you if you say your car has special UV windshield glass. It can be mounted on your license plate for a car/truck. I mounted mine on the light bar for my Shadow.
Back when I lived in MA with my first bike, I carried the car version around and it almost never worked either in my pocket or a tank bag. Waved it above my head like a dumbass and even then a lot of times it didn't work. I learned that MA also has the little black ones for motorcycles that you can put on your license plate, but by the time I found out I was moving out of MA to MD and didn't care anymore anyway. Since then the only state I've lived in with EZ Pass is MD, and those tolls were so far north from me that I never crossed them on my bike.
SwissFreek is offline   Reply With Quote
Old 10-07-2012, 08:03 PM   #55
calgaryjeff
calgaryjeff's Avatar
Oddometer: 286
There were able to read my EZPass on my bike while it was in the back of a moving van so I don't think it matters where you mount it.
2003 Aprilia CapoNord
1985 Honda VF1000R
IBA #23204
calgaryjeff is offline   Reply With Quote
Old 12-18-2012, 04:58 AM   #56
raypitter
Oddometer: 21
I have EZ pass holder in my car. and I have mounted it on windshield.
raypitter is offline   Reply With Quote
Old 12-18-2012, 06:37 AM   #57
clintonl
Oddometer: 111
If you order the long narrow black EZ Pass transponder that bolts onto a front license plate rather than the white square one then you can zip tie it neatly and securely out of site. You can see mine mounted just in front of the tachometer in the photo below. It just looks like a black bar.
clintonl is offline   Reply With Quote
Old 12-24-2012, 04:10 AM   #58
raypitter
Oddometer: 21
Front of the tachometer and Two strips of heavy duty velcro under the beak. Holds perfectly and very easy to install!
Old 12-24-2012, 09:13 AM   #59
DJacobsen5116
Oddometer: 163
Good-to-Go Pass
Anyone here from the Seattle area use the Good-to-Go Pass? Where do you mount it? I've called their office a couple of times to get information about the pass for Motorcycles and placement and they don't seem to understand "motorcycle" but will happily send you a bill including penalty if you don't have a pass. I'm not enthused about mounting it on the windshield but that seems to be their only option. FJR1300
DJacobsen5116 is offline   Reply With Quote
Old 12-24-2012, 10:51 AM   #60
trc.rhubarb
Oddometer: 2,050
http://www.wsdot.wa.gov/GoodToGo/Pas...ilable2011.htm
Bottom of the page they have motorcycle specific passes that are very small and mount to your headlight.
Follow me here
Times are GMT -7.   It's 10:27 AM.
