Old 11-13-2012, 01:24 PM   #46
Rapid Dog
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 9,483
Thumb
Originally Posted by JagLite View Post
T
It's a ROLLER!!!
Damn! I'd give your left nut to have that roller in my livin' room...
'91 R100GSPD Derelict Deux , '81 R100RS Rattlecandy Red/'06 950 ADV Orangeboom/91 R100GSPD Derelict etc.
Rapid Dog is offline   Reply With Quote
Old 11-19-2012, 03:48 AM   #47
dfisher
Oddometer: 2
Question
Not to be critical but.... I am sensing a need for some steering stops and a looming issue with the rear brake anchor/actuating lever location.
dfisher is offline   Reply With Quote
Old 11-19-2012, 09:45 AM   #48
JagLite OP
JagLite's Avatar
Oddometer: 1,247
Cool2 Progress Report
Good eyes!
I installed the steering stops (they are just above the lower clamp) but since the fork clamps have much less offset I had to install the stops in the only way they hit the frame tube.
You are very correct about the rear wheel brake problem.
It does seem to me that trying to use the Husky rear wheel is not going to be workable.
While anything can be made to work (almost) it isn't cost effective with the various problems.
I am hoping that Matt at Speed & Sport can help me with a proper rear wheel.
Other progress is that I bought a '75 Can-Am 250 parts bike for the Betor forks and front wheel.
I have torn the forks down and they are good to use as are the fork clamps.
Next is to see if the new stem (that cost more than the Can-Am!) will work with the Betor clamps, or if the stock Betor stem will mate with the new bearings in the steering head.
Here is the parts bike AFTER I spent two hours de-greasing and scrubbing the filthy beast.
It is amazing to me that people who want to sell something don't clean it up to look its best.
The bike has almost new tires on it too!
Except that they were new 10 years ago and have been sitting outside flat for those years and the sidewalls are all cracked. What a waste.
I removed the front tire and cleaned the wheel up and it looked pretty good until I put the axle back in and spun it.
It spins like a potato chip. That is one bent up rim. Argh!
The Magura levers look good to use also, and the handlebars are straight (amazing!) and look correct for the Rickman to me so I will use them. The Can-Am also supplied the Magura trap door throttle to use.
This picture shows the Honda front end with the Can-Am handlebars and new levers I bought.
Will most likely use the Magura levers now that I have them though.
So, I may get new spokes and put the Honda rim on the Can-Am hub to mate with the Betor forks with the new springs I got from Rickman (that did not fit in the Honda forks) that fit perfectly and use the Betor clamps. That will give me the proper offset for correct trail. New spokes would make a world of difference in looks as well as the fact that I could actually true the rim without spokes breaking from rust in the nipple.
Attitude ~
The difference between
Ordeal and Adventure
James
JagLite is offline   Reply With Quote
Old 11-19-2012, 02:00 PM   #49
TUCKERS
the famous james
TUCKERS's Avatar
Oddometer: 11,910
Wow! You scored some nice bits off the Can Am.
Probably be able to sell what's left too.
Check Buchanan's for heavy duty rustless spokes. I like the shot blasted stainless steel ones, they look like cad plate but never rust.
James and Colleen Tucker.
Aut viam inveniam aut faciam
DMV work/insurance/registration/titles/address use/room rental/motorbike&vehicle buying/travelers help/problems solved
TUCKERS is offline   Reply With Quote
Old 11-20-2012, 12:19 AM   #50
TUCKERS
the famous james
TUCKERS's Avatar
Oddometer: 11,910
Couple of wheels on Ebay right now in my area (Los Angeles).
Just Ebay search BSA wheel. Put in within 50 miles of 91711. Should come up quickly.
Old 11-22-2012, 12:40 PM   #51
kellymac530
motorcycle addict
kellymac530's Avatar
Oddometer: 1,052
Jaglite,
Love love love Rickmans!
Bless you.
In 1973 when I was 9 yrs old I had moved up from my mini enduro 60 to a DT 125 Yami and there was a Yamaha dealership in Lawndale Ca on Hawthorne Blvd { don't know why I can't remeber the name of that shop, chime in if anyone remebers} and they were also Rickman dealer. They had a Rickman there that looked the same as a Metisse body work and frame wise but it had a Puch or Zundapp or something 125cc in it. I wanted it bad but my dad was not going to spend that kind of cash on a punk 9 yr old and he hated Euro motors for reliability compared to his beloved Japanese bikes.
Then one day we walk in to buy parts for his bullet proof Yamaha that had seized { ozymoron I guess} and they had some custom built Rickman that had a Yamaha DT 125 motor in it.... PLEASEEEEEEEEE daddy, I want it, buy it for me.
He thought about it right up till he saw the price tag....don't remeber how much but I know it was alot more than a standard Yami.
Keep it up Jag.
If I may put my $0.02 in I do not really like that top triple tree there. Those canted back bar clamps just look wrong to me for a Rickman. I think you are figuring it out that sometime trying to finagle some odd part to fit is more than just buying the right part the first time....Glad to see some Betor forks on there and not the Crappy Jappy Showa junk. JMHO though.
it is easier to ask for forgiveness than permission
kellymac530 is offline   Reply With Quote
Old 11-22-2012, 01:16 PM   #52
Bambi
Bambi's Avatar
Oddometer: 693
Hi there,
just for the record: those Rickmans with the small engines were called Micro Metisse.
And yes, yes, yes I love Metisses since I saw the first one. And it carried a Triumph Twin which is the best combination I think!
Good luck with the build and kind regards, Bambi
'Find me kindness, find me beauty, find me truth ...'
(Dreamtheater, Learning to live)
Bambi is offline   Reply With Quote
Old 11-22-2012, 06:55 PM   #53
kellymac530
motorcycle addict
Oddometer: 1,052
Bambi,
Thanks for the info. I had never heard micro metisse before. I do not know if the one I wanted said that on it, but I can not remember much more than I wanted THAT one.
I would also agree BIG time that the big twin Metisse is by far the coolest of the Rickmans, but when you are 9 or 10 is even starting one was tough, a 125 was just right....for another year or 2...
Now the only one I would spend any REAL money on would be a 650 Trumpet Metisse.
Old 11-23-2012, 08:59 AM   #54
JagLite OP
JagLite's Avatar
Oddometer: 1,247
Cool2 Micro Metisse
Originally Posted by kellymac530 View Post
Jaglite,
I agree with you there.
I never cared for the rearset bar mounts but they were considered the "hot ticket" back in the mid '60's.
Steve McQueen had them on his Rickman as did many others.
They used a BSA top clamp for the rearset bar mounts.
Metisse Motorcycles uses the same BSA top clamp on their overpriced replicas.
Take a look at the pictures:
http://www.metisse-motorcycles.com/stevemcqueen.htm
I will be using the Betor clamps though as I like having the bars farther forward.
I am 6'-4" and need all the room I can get.
The Micro Metisse came from the factory with a 125 Sacks (?) engine, or as a rolling chassis for any engine you could fit.
I was racing mx in '72 on my new Honda SL100 that cost $425 new out the door.
The Rickman dealer close by had a new Micro Metisse roller on the show room floor and it was $550 with NO engine.
So, yes, they were very expensive.
One fellow racer had a Honda SL125 (4 stroke) engine in a Micro Metisse and it looked so good and sounded so neat!
Rickman Motorcycles sells the parts for the Micro as well as the full size bikes.
http://www.rickman-motorcycles.com/parts-and-prices.php
Thanks for the comments everyone!
Attitude ~
James
JagLite screwed with this post 11-28-2012 at 10:13 AM Reason: Rickman 125cc engine mfg?
Old 11-23-2012, 09:15 AM   #55
JagLite OP
JagLite's Avatar
Oddometer: 1,247
Talking Steve McQueen
I remembered reading an article where Steve talked about his bike:
http://www.realclassic.co.uk/rickman08063000.html
and another site with similar info:
http://www.angelfire.com/biz/snwvlly/bikes/steve.htm
The article was in Popular Science in 1966.
The Rickman Triumph was his favorite bike.... until he rode a Husky!
I read this morning that Bonham's auction will be selling his 400 Cross Husky.
I don't think anyone knows what happened to his Rickman.
That should be worth something!
Attitude ~
James
Old 11-23-2012, 08:06 PM   #56
r77toy
Oddometer: 466
Jaglite,
Bless you.
Keep it up Jag.
Harry D Foster Yamaha.
r77toy is offline   Reply With Quote
Old 11-24-2012, 08:48 AM   #57
kellymac530
motorcycle addict
Oddometer: 1,052
Thanks 77. I knew someone would remember. We had a buddy that worked at T&O Yamaha in Lomita so we got most of our stuff there, but Harry D was a bit closer and a great back up resource if T&O didn't have something.
Jag,
I am glad you were not offended at my comment. I am 6'0" so not real tall, but I almost always change my triple clamps on my MX bikes to move the bars up and forward. Those clamps to lower and pull back the bars just seem uncomfortable to me.
But I do think that with the riding style neccesary back then of carrying the front on jumps and using throttle to drop it slower maybe the bars being back a bit helped that kind of body position required to ride that style.
It was a big change for me to learn the newer riding style of landing on the front wheel at full throttle to drive out of a jump.
I took a few years off from MX racing from the mid 80s and got back to it in the mid 90s and man what a difference in Forks and that has changed riding styles alot.
When I was young the forks, even the best of Cerriani or whatever else, were still a bit noodley and if you landed on the front wheel there was a chance the wheel would deflect and you were swappin ends. In the 90s when forks got USD and MUCH stiffer in the flex area it was completely different. That precise throttle control to arch the jump just right and land on the rear wheel and put all of the power down that you could but not loop out and bring the front down slowly was very different than now days. Now you want to land on the front wheel {within reason} and at full throttle which drives out the landing and keeps the rear suspension loaded. Took me a while to get that style down, but it is faster I think than before, but less stylish than rear wheel steering and wheelies everywhere.
Sorry for any hijack. Please build on and keep the beautiful pics coming. Seems like you really have a handle on the project now.
PS: not sure I would spend the money on a micro Metisse if I could afford that, I would just spend the extra bucks and build the trumpet powered big boy like you.
Old 11-25-2012, 01:15 AM   #58
motu
Loose Pre Unit
motu's Avatar
Oddometer: 4,536
That precise throttle control to arch the jump just right and land on the rear wheel and put all of the power down that you could but not loop out and bring the front down slowly was very different than now days. less stylish than rear wheel steering and wheelies everywhere.
That was the magic of the Rickman - power standing off jumps and huge full lock slides out of turns. The new tracks can't be ridden like that, and your way is much faster of course. You don't buy a Rickman if you want to ride modern tracks in the modern style.
motu is online now   Reply With Quote
Old 11-25-2012, 01:34 PM   #59
syntec4
syntec4's Avatar
Oddometer: 1,375
This is a good thread. Keep going
i spotted this one racing this year at Cholmondley.
My Smugmug
syntec4 is offline   Reply With Quote
Old 11-25-2012, 09:35 PM   #60
JagLite OP
JagLite's Avatar
Oddometer: 1,247
Thumb Action shot!
Thanks Syntec!
That is a beautiful action shot of a Rickman at work.
I always smile when I read how dangerous a low mount front fender (mudguard) is and that no dirt bike should have one.
Yet all the early scrambles bikes had them and often raced in mud.
I have a Yamaha TW200 that has a low front fender and often get flack for not changing it.
I do agree that it is much more likely to clog up but i rarely ride in deep mud anyway.
A Rickman, like any heavy dirt bike with very limited suspension, just can't be ridden like a modern mx bike.
I think there is a lot of appeal to the old machines.
I have a lot of interest and appreciation for airplanes with radial engines.
Modern jets are so far advanced in every way but they don't interest me at all.
Modern bikes are just phenomenal in power, handling, braking, and quality.
And that is what I like to ride most of the time, but sometimes it is a treat to relive the days when the "4 stroke dinosaurs ruled the land and thunder shook the ground".
I am going to get that put on a tee shirt.
Attitude ~
James
Times are GMT -7.   It's 03:07 AM.
