08-17-2012, 01:16 PM
#16 |
Oddometer: 1,448
Do whatever works for you, but copy and pasted from the wikipedia article on cast iron-
A seasoned pan has a stick-resistant coating created by polymerized oils and fats. Seasoning is a process by which a layer of animal fat or vegetable oil is applied and cooked onto cast iron or carbon steel cookware. The seasoning layer protects the cookware from rusting, provides a non-stick surface for cooking, and prevents food from interacting with the iron of the pan.
I'm very well acquainted with the 7 deadly sins, and I keep a busy schedule trying to fit them in- Warren Zevon |
08-17-2012, 02:14 PM
#17 | |
b00b
Oddometer: 316
![]() This is truly the only major downside to cast iron cookware. I keep mine in the garage.
08-17-2012, 02:19 PM
#18 | |
Oddometer: 9,781
Not a downside - flavor. I am also OK using soap in mine, and usually every so often I'll do so. Lately I will just click on my electric kettle to boil up some water, and drop some boiling water into the hot pan right after cooking, swirl and wipe. Then leave on heat till dry, and wipe it with some oily paper towel. |
08-17-2012, 03:06 PM
#19 |
b00b
Oddometer: 316
What I meant was the unstoppable drive of certain members of the family to scrub them out is the only down side. Hence I keep mine in the garage.
08-17-2012, 04:48 PM
#20 |
Oddometer: 114
Cleaning
I haven't seen this method mentioned yet, so here is my secret to an absolutely stick free skillet. NO WATER! Seriously. I know, I know. Heresy. You'll get the plague. Stick with me on this one.
I'm a Firemen. I work with some pretty damn fine cooks. This tip was passed on to me, to keep our stations collection of Wagner cast iron in tip top. Anytime you cook with bacon, pour the grease into a paper cup or glass. Put bacon grease in fridge. Anytime you cook with your cast iron, use a metal spatula to scrape out what you can. Then, pour a tablespoon or two of coarse sea salt in the pan. Take a rag and begin "sanding" away the caked on gunk. Takes less than a minute. Brush all salt and food gunk into the trash can. At this point, you'll have a smooth, gunk free surface. Removal of non-stick oils and seasoning will have been minimized. Finally, stick the pan on the stove on medium heat. Apply a teaspoon of previously saved bacon grease. Turn off heat and wipe away excess with a paper towel, or leave it for that matter. The bacon grease will cool and leave a grayish, almost dry appearing surface. TOTALLY STICK PROOF! I can fry eggs over easy all day long. Scott Gonad Nomad screwed with this post 08-17-2012 at 04:50 PM Reason: Not sow grood at smelling |
08-17-2012, 05:06 PM
#21 |
Oddometer: 497
Temperature?
I love my cast Iron pans. I also love my Stainless steel pans. I always thought it was temperature and skill that makes a pan non-stick. I can cook eggs and omelets in both types no problem.
I only use soap on my cast iron after my wife uses it. ![]() Water rinse while hot, wipe, dry on med heat, wipe w/ oil done. never had one go rancid. |
08-17-2012, 06:31 PM
#22 | |
Oddometer: 1,448
08-17-2012, 06:37 PM
#23 |
Oddometer: 1,448
I have a couple that I am not sure what they are, only markings is a large stamped number, 12 on one and 5 the other (about a 15 inch and 8 inch respectively). Any ideas?
A lot of people say you can do better than Lodge, I have one Wagner dutch over (kinda hard to tell about nonstick with that) but want to try a Griswold (if those I have are not, and I don't think they are). Is there that big of a difference? Also I was looking at the Lodge Signature series in a store the other day, man those look fine, but the price is crazy.
08-17-2012, 07:28 PM
#24 |
Oddometer: 6,416
You know, a long time ago being crazy meant something. Nowadays everybody's crazy IBA 22425 |
08-18-2012, 08:56 AM
#25 | |
Painting by numbers
Oddometer: 5,387
The use of a soap/petroleum cleaning agent isn't necessary, and sure as hell ain't gonna improve the season, so why bother?
-Chris '04 GS Adv- A fond memory '07 990 Adventure- still bonding... How hard can it be? - Jeremy Clarkson |
08-18-2012, 08:57 AM
#26 |
Painting by numbers
Oddometer: 5,387
I've actually always wanted one of those.
08-18-2012, 09:06 AM
#27 | |
Painting by numbers
Oddometer: 5,387
I have a Griswold Chef Skillet that I bought cheap because the bottom of the interior is pitted as hell. Cooking in it was dicey at first, but now that the pits have filled in, it cooks great. I suppose a rough-cast modern one would do the same thing, but the flap-sanding idea sounds like a good one to remedy modern makers' laziness.
08-18-2012, 09:10 AM
#28 |
Painting by numbers
Oddometer: 5,387
08-18-2012, 10:36 AM
#29 | |
Archvillain
Oddometer: 30,407
Every saint has a past and every sinner has a future. If, after I depart this vale, you ever remember me and have thought to please my ghost, forgive some sinner and wink your eye at some homely girl. Xeraux screwed with this post 08-18-2012 at 10:44 AM |
08-18-2012, 11:26 AM
#30 | |
Painting by numbers
Oddometer: 5,387
| Thread Tools | |
