Old 10-21-2013, 06:42 PM   #1
diverdown OP
Oddometer: 200
sportster chain drive gearing
Hello all. building an adventure sportster 2005 1200r and having Brock Smith at side effects build me a custom adventure off road car. Will be going to a chain drive conversion and was wondering on the sprocket size. want to be able to putt around on gravel roads. with wife in the hack. top speed of 110 kph or 70 mph would be ok for me on the highway. was thinking 23 on the front and 55 on the rear. Would that work.
diverdown is offline   Reply With Quote
Old 10-21-2013, 06:47 PM   #2
DRONE
Dog Chauffeur
DRONE's Avatar
Oddometer: 3,950
Not too many Sportster guys here. Maybe Swampfox knows, or knows where to point you. If your conversion is anything like most chain drive bikes, it's fairly easy and cheap to try different combos until you find the one you like.
WUMPA
Sidecardogs.com
DRONE screwed with this post 10-21-2013 at 06:53 PM
DRONE is offline   Reply With Quote
Old 10-21-2013, 07:08 PM   #3
FR700
Heckler™©®
FR700's Avatar
Oddometer: 7,871
883's run lower primary gearing than the 1200's.
That then leaves more options for your final gearing. First and second gear ratios for off road/gravel should be your primary focus ... no pun intended.
The tractor I ran ( FLHT ) was converted to chain to get away from the PITA of having to drop the whole primary/clutch/swingarm in the event of a belt failure. The sporty doesn't suffer from this problem as a belt change is far simpler at the side of the road.
I'm diagonally parked in a parallel universe.
FR700 is offline   Reply With Quote
Old 10-22-2013, 05:17 AM   #4
SwampFox883R
SwampFox883R's Avatar
Oddometer: 373
Originally Posted by FR700 View Post
883's run lower primary gearing than the 1200's....
diver, I have no personal experience with the chain drive conversion, but the general consensus for 1200 Sportster tugs is to gear down to the 883 gearing - which employ a smaller OEM front pulley. So figuring the stock 883 gearing and crossing that over to the chain conversion is a good starting point.
But from my Sportster experience and considering your application, I would suggest going a little lower: -- my 2002 XL883R is geared down another 4% with a 1 tooth smaller aftermarket front pulley, which still permits 70mph, although I rarely travel more than 62mph with my little rigid mount tug. If I recall correctly, I run ~3200rpm's at 62mph.
Please keep us informed.
Lee - Maddie's Chauffer
KLX250S + TW200
R1100GS w/CSM Sidecar
AN650 Burgman w/Texas Sidecar <Mrs. SwampFox's
SwampFox883R is offline   Reply With Quote
Old 10-22-2013, 07:41 AM   #5
jaydmc
Oddometer: 1,059
I have not done the chain drive conversion however we have done a Sportster dual sport rig based around our Enduro sidecar, as the person we built it for was never going to go off road and just wanted the look of going off road we did not worry about it. I wanted to let you know that the Big Foot sidecar club has one or two events in your area every year.
Jay G
DMC sidecars
www.dmcsidecars.com
866-638-1793
jaydmc is offline   Reply With Quote
Old 10-22-2013, 03:31 PM   #6
kshansen
kshansen
Oddometer: 195
I do not know about the newer Sportsters but according to may factory manual for 1991,92 models the primary drive ratio was the same for all Sportsters. 35:56 for a 1.60:1 ratio.
There were 2 different transmission pulleys 27 on the 883 and 29 on the 1200. All belt drive bikes used the same 61 tooth rear wheel pulley.
The chain drive as used on the 883's used a 21 tooth front sprocket and a 48 tooth rear sprocket.
As for changing the belt on the side of road, not a bad job with a few hand tools and small jack to hold the weight off the rear wheel. Done it twice so far!
kshansen is offline   Reply With Quote
Old 10-22-2013, 05:00 PM   #7
FR700
Heckler™©®
FR700's Avatar
Oddometer: 7,871
Not all sportster's are born equal.
http://883sportster.webs.com/products.htm
On a sportster , yes.
A big twin such as my FLHT ... not so much. ALL the primary comes off , inner , outer , clutch , chain , compensator sprocket ... plus you need to drop the swingarm to get the belt around the pivot.
And you had better be carrying the special tools
Big twins also ran different primary ratios depending on if they were carbed or injected. Carb' like mine came with taller gearing in the primary from the factory.
All international models compared to US domestic models came with taller final gearing.
Old 10-22-2013, 06:28 PM   #8
diverdown OP
Oddometer: 200
Jay G
DMC sidecars
www.dmcsidecars.com
866-638-1793
Hey thanks jay. Im the guy here in Kamloops that has your enduro hack on my KLR 650 luv the thing to pieces. will be talking soon for triple trees for the Harley. talked to pete at zipper performance and has set me up with a 530 oring chain. 24 counter sprocket and a 60 rear, will start there and change as needed
Old 10-22-2013, 07:38 PM   #9
DJ1
Chopper Jockey
DJ1's Avatar
Oddometer: 236
Stock 883 final gearing is around 2.28/1, the 23/55 would give you 2.39/1 and might be just about right for what you're wanting to do. I have a 21/48(2.28/1) on my Sporty chop hack and it's a little faster than what I want on my ADV Sporty hack, when I finish the ADV Sporty hack I will probably go with a 20/48 for 2.4/1 ratio or a 20/49 for a 2.45/1 depending on how it feels.
I know the newer rubber mount bikes need larger sprockets to clear parts of the frame and mounts compared to the older solid mounts motored bikes like I have. Make sure you have clearance, the 55 in the rear should be fine.
choppers, they're for ridin'
DJ1 screwed with this post 10-22-2013 at 07:39 PM Reason: added info
DJ1 is offline   Reply With Quote
Old 10-23-2013, 06:12 AM   #10
SwampFox883R
Oddometer: 373
From the referenced site:
The 883 has a very flat torque curve. Usable torque starts about 2200 rpm! You can take full advantage of this curve (which is Harley engine design) by 5th gear cruising in the 2800-3100 rpm range, this is where the fuel economy range lies! So, pick the speed you want to cruise at (see chart in "Documents" section) and pick the pulley that matches your desired cruise speed.
That's exactly what I have discovered, 2800-3100 rpm's push me along at 55-60ish MPH and result in the best overall fuel economy on the '02 XL883R rig. Any faster and fuel economy suffers dramatically.
KLX250S + TW200
Old 04-13-2014, 08:27 AM   #11
drbike
drbike's Avatar
Oddometer: 270
how is the rig coming? Will we be seeing you on it soon?
drbike is offline   Reply With Quote
Old 04-13-2014, 09:18 AM   #12
diverdown OP
Oddometer: 200
Hey drbike. Bike is at side effects as I write this, talked to Brock the other day and his Dad came out of retirement to do this build, pipe is being bent and welders are buzzing, am dying to go see how it is coming along but don,t want to be a PIA. will gets some pictures up soon, ETA is the end of this month
Old 04-14-2014, 07:38 AM   #13
drbike
drbike's Avatar
Oddometer: 270
Two weeks.....wow that's soon.
Looking forward to seeing it. I am excited for you.
Old 04-14-2014, 12:20 PM   #14
ooweel
Jobless, Its OK!
ooweel's Avatar
Oddometer: 810
Check this link out for your 1200 R
This dude is UBER talented ! Bike is so bitchin pictures don't do it justice!
http://www.advrider.com/forums/showthread.php?t=667638
I don't know Jack Shit !
ooweel is offline   Reply With Quote
Old 04-14-2014, 04:13 PM   #15
kshansen
kshansen
Oddometer: 195
I can attest to that, have done it twice on my 1992 Sportster As long as you have a good set of tools in the sidecar and a jack takes maybe an hour could do faster but hot parts are hard on fingers About the worst part of the job is getting the clevis pin out of the brake linkage. I'm tempted to replace the stock one with the knurling with a smooth one that just slips out.
Times are GMT -7.   It's 11:11 PM.
