Old 08-17-2012, 03:38 PM   #1
bigmd OP
Oddometer: 66
all balls bearing question
hey guys working on an 82 cb450 project.I ordered new steering head bearings and installed.it seems the top bearing race is fully bottomed out into the recess of the head tube but does not sit flush therefore i have no room for the nut that requires the spanner wrench.is this normal.i double checked and the package def states its for my bike,.i even cross referenced on the all bals site and its the correct part number.
bigmd is offline   Reply With Quote
Old 08-17-2012, 03:49 PM   #2
baloneyskin daddy
bikaholic
Oddometer: 2,085
You should always compare aftermarket parts to the originals, or any parts for that matter, before installing them because now its too late. Are you sure the bottom race is seated properly in the frame and on the steering stem?
baloneyskin daddy is offline   Reply With Quote
Old 08-17-2012, 04:28 PM   #3
bigmd OP
Oddometer: 66
yeah definately rushed it/\.but i double checked and bottom race was not seated.i tapped it in and buttoned it up but now the bottom tree was hitting the head tube,is it safe to say i need a washer on the bottom before the bearing?
Old 08-17-2012, 06:21 PM   #4
pennswoodsed
lizards,bugs and me
pennswoodsed's Avatar
Oddometer: 729
Sources
Hi,
Maybe check with supplier or Ohio Cafe Racers .
Luck,Ed
pennswoodsed is offline   Reply With Quote
Old 08-17-2012, 07:12 PM   #5
bigmd OP
Oddometer: 66
Reread directions and it says washed may be needed
Old 09-17-2012, 06:26 PM   #6
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,408
All Balls misapplied the bearings for my vintage project, TX750. Chinese bearings at upscale prices.
Old 09-17-2012, 08:57 PM   #7
anonny
What could go wrong?
anonny's Avatar
Oddometer: 5,546
Mine (for a cl 450) came with 2 washers, a thick and a thin. I used the thin on the bottom and the thick in my bolt bin.
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is offline   Reply With Quote
Times are GMT -7.   It's 08:15 AM.
