Old 09-13-2012, 01:19 PM   #16
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,238
I'm diggin it.
Originally Posted by bassogap View Post
If my aunt had nuts, she'd be my uncle. What's your point?
Manic Cycles=My Blog
ben2go is offline   Reply With Quote
Old 09-13-2012, 04:36 PM   #17
cam14
Oddometer: 171
Originally Posted by crypto666 View Post
...There is some wraps out there that are impregnated with some stuff that when you get it wet it hardens; plaster perhaps. I think that would better because my worry is now is that it will come unwrapped.
The heat wrap I used on my race car, soaked it in water before installing it made is stretch a bit and easier to contour. When it dried, it took the shape very well. Then coated it in high temp paint, worked very well.
cam14 is offline   Reply With Quote
Old 09-14-2012, 08:40 AM   #18
jwalters OP
Farkle Proliferator
jwalters's Avatar
Oddometer: 2,271
Good news, Superplush finished up my suspension and it's on its way. Once it arrives, I'll be able to really get moving on this project. I have a pile of stuff ready to go, I just need a rolling chassis! Couple more days!
-jw
Minnesota North Shore Shindig 10-13 September 2015 -- Finland, MN
Proliferator of Farkles of Mass Percussion
jwalters is online now   Reply With Quote
Old 09-14-2012, 01:29 PM   #19
Lutz
Killer Rabbit
Lutz's Avatar
Oddometer: 1,387
Sweet!
Lutz is offline   Reply With Quote
Old 09-14-2012, 03:54 PM   #20
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,320
im in
Sean-0 is offline   Reply With Quote
Old 09-14-2012, 06:31 PM   #21
DocAxeYarYar
RideDualSport.com
DocAxeYarYar's Avatar
Oddometer: 784
XRR Build
Great job on your bike, I like that your putting new life into it. Looking forward to watching the progress!
My XR650R Build:
http://ridedualsport.com/forum/index.php?topic=2748.0
DocAxeYarYar is offline   Reply With Quote
Old 09-14-2012, 10:45 PM   #22
woodsxr
Oddometer: 181
Gotta see how it turns out.
Thanks for sharing
woodsxr is online now   Reply With Quote
Old 09-15-2012, 08:50 AM   #23
jwalters OP
Farkle Proliferator
jwalters's Avatar
Oddometer: 2,271
Hopefully it turns out well! Thanks for tuning in.
Thanks for sharing
Suspension should be here September 20th. Then it should be off to the races. Still waiting on my new longer control cables but they should be here next week as well. After I finish this XR, I have to get cracking on my RZ350 project. But that will be another thread.... :-)
Old 09-20-2012, 07:44 PM   #24
jwalters OP
Farkle Proliferator
jwalters's Avatar
Oddometer: 2,271
Looked what arrived today!!!!!
Oh baby!
Old 09-20-2012, 07:47 PM   #25
jwalters OP
Farkle Proliferator
jwalters's Avatar
Oddometer: 2,271
Well now. I have pretty much everything I need to get the XRR back on the road. No more excuses. First thing first, clean up the work area a bit and get the parts on the table to see what I have to work with. Lot's of work left to do, but suspension is back on the bike and I've started installing the aftermarket sub frame. Electrical work soon to come!
Old 09-20-2012, 09:32 PM   #26
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,238
Son of a beach! I think you'll have something to keep you busy for a day or two.
Old 09-21-2012, 12:19 AM   #27
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,320
keep us informed on the sub frame mounting ... im looking at 1 of these
Old 09-21-2012, 05:59 AM   #28
DocAxeYarYar
RideDualSport.com
Oddometer: 784
XRR Build
Sweet, great progress! I like your other projects, Im kind of stuck in the 80's myself....have a built up 84 985 cc Ninja that I enjoy.
Great idea on the subframe! I went for the smaller w/out luggage rack since I already have a small ManRacks for the back. Gives great peace of mind for the long haul!
My XR650R Build:
Old 09-21-2012, 04:13 PM   #29
jwalters OP
Farkle Proliferator
jwalters's Avatar
Oddometer: 2,271
Well finally! Starting to build the machine back up. Taking my time, one piece at a time and one cup of coffee at a time.
I got the suspension reinstalled on the bike. Buttoned up the front wheel and axle so at least I once again have a rolling chassis. After installing the rear shock, I installed the steel sub-frame. I know a few of you were interested in the part fitment, so I took a few more pictures of it for you.
The frame was about 1/4 an inch too tight at the upper mount location, so I rigged up a system to open up the face a bit. I used a bolt and screwed the nuts outward to open the face slightly. It worked well and the sub-frame fit nicely after widening the mount points.
All in all, it's fitment was great. I'm nitpicking here, but it would have been nice for them to include a new M8 bolt that's used on the upper sub-frame mount (the same one I widened above). The stock bolt is too long and the threads didn't go down the shaft far enough, since its designed for the thicker aluminum sub-frame. Fortunately, I had some M8x100mm bolts that fit the bill.
After finishing up the subframe, I installed the new hose kit. Some of my radiator hoses were badly cut, so this was more than just a bling upgrade! I do like the look though! After the hoses, next came the FMF header. That was a simple installation as well. That's it for now, going to hit the trail and get a workout in. Here is it's current condition, it's starting to look like a bike again!
Old 09-21-2012, 07:03 PM   #30
Lutz
Killer Rabbit
Lutz's Avatar
Oddometer: 1,387
...and here's me, starting to look like this again:
Times are GMT -7.   It's 07:25 AM.
