Old 08-18-2012, 01:50 PM   #1
rade OP
Oddometer: 185
KTM 950/990 Adv UNDERSEAT TANK
I do long distance travel and some extra tank w/o any mods was missing on the market, so I decided to do one.
It fits to 950 or 990 Adventure without ABS and the only mod you need to do, is cut the underseat box and link the underseat tank to the main tanks. It has petcock, so you can close it and keep it as a reserve.
You fit there 6,3 liters of petrol.
I can produce some, if anyone is interested.
cheers:-)
Rade
创创创创创创创创创创创创创创创创创创创创创
complete portfolio at: radegarage.com
rade screwed with this post 11-26-2012 at 02:09 PM
rade is offline   Reply With Quote
Old 08-18-2012, 02:12 PM   #2
Stumpalump
Oddometer: 128
Brilliant! Have you weighed it?
KTM 950A
Rokon 2X2
Montesa 315R trials
KTM 200 EXC.
XR400
Stumpalump is offline   Reply With Quote
Old 08-18-2012, 03:27 PM   #3
TcRulz
Oddometer: 289
Man you are talented That is a piece of art. I love it when people find a solution to a need. Have you tried it to see the rear wheel won't touch?.
TcRulz is offline   Reply With Quote
Old 08-18-2012, 03:35 PM   #4
moosnutz
meow meow
moosnutz's Avatar
Oddometer: 68
Great work! Very clean install.
moosnutz is offline   Reply With Quote
Old 08-18-2012, 04:31 PM   #5
jdw4748
Oddometer: 67
Just curious but why not replace the existing subframe with your tank. You obviously are a talented fabricator/welder. Instead of making your tank fit the subframe couldn't you have made your tank the subframe?
jdw4748 is offline   Reply With Quote
Old 08-18-2012, 04:47 PM   #6
viola-tor
Needs to ride!
viola-tor's Avatar
Oddometer: 2,071
That's amazing! Looks like it would work in conjunction with the side-mounted ADV tank too...
viola-tor is offline   Reply With Quote
Old 08-19-2012, 09:57 AM   #7
3 up
Les in LV
3 up's Avatar
Oddometer: 146
Tank
So what would be the price then?
Life is Short Ride More Work Less
3 up is offline   Reply With Quote
Old 08-20-2012, 02:59 PM   #8
rade OP
Oddometer: 185
pls. write to Kevin from Warp9: kevint@warp9racing.com
He will have soon (3-4 weeks) some in stock.
Rade
Old 08-21-2012, 02:11 AM   #9
bigkuri
bigkuri's Avatar
Oddometer: 785
Amazing job - just some great skills in fabb'ing that. I think a good idea about the sub-frame - if you have the skills to make that you could potentially create the whole subframe-incorporating the tank to suit?
Great job though
Current Bikes: 2006 Honda XR650R & 2015 KTM 1190 Adventure R
bigkuri is offline   Reply With Quote
Old 08-21-2012, 05:23 AM   #10
Nailhead
Free at last!
Nailhead's Avatar
Oddometer: 6,217
Originally Posted by viola-tor View Post
That's amazing!
That's exactly what I was thinking.
-Chris
'7? Benelli 650S, '80 BMW R100 RS, '93 Ducati 900 SS, '07 KTM 990 Adventure
Nailhead is offline   Reply With Quote
Old 08-21-2012, 12:19 PM   #11
Roeligan
Belgium power!!!
Roeligan's Avatar
Oddometer: 507
me too!
makes me thinking again on removing my ABS...
KTM 990 Adventure (Stealth one ; 2008-), now S-d & Beta 350 RR 2013 to play with
Suzuki DL-1000 V-Strom (2004-2008) and Suzuki GSF 600 Bandit (2002-2006)
www.roeligan.net
Roeligan is offline   Reply With Quote
Old 08-21-2012, 02:07 PM   #12
Gordonktm
Gordonktm's Avatar
Oddometer: 134
great work
Are you going to paint or power coat it
Gordonktm screwed with this post 08-21-2012 at 02:10 PM Reason: mod question
Gordonktm is offline   Reply With Quote
Old 08-21-2012, 03:03 PM   #13
DirtyADV
DirtyADV's Avatar
Oddometer: 2,324
Im looking at a solution with tank welded onto the subframe, but its quite far away, the dream would be a solution with fuel on the right side covering the muffler and a storage on the left side (2-1 system) and be able to keep stock under seat tool box.
Have scored 2 extra cheap subframes (one was a write off from a crashed bike so need to see if its still straight) the other should be fine.
Actually have a subframe in my apartment and have plans on starting to make some drawings on my dreams, will probably be around here asking for help about material thickness and similar.
But right now Im running a fever and have a hard time sleeping so drinking a little whiskey to kill some germs!
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is offline   Reply With Quote
Old 08-21-2012, 04:41 PM   #14
Off Road Ryder
Off Road Ryder's Avatar
Oddometer: 2,666
Great fab skills.
Has there been a lot of testing?? It seams possible that pipe temps might cause an issue with fuel expansion??
When Quality matters,Its all about choices.
Cyclops Performance LED Vendors thread
http://advrider.com/forums/showthread.php?t=839163
www.cyclopsadventuresports.com
1-800-624-0278
Off Road Ryder is offline   Reply With Quote
Old 08-22-2012, 09:08 AM   #15
DesertSurfer
Tail sprayin
DesertSurfer's Avatar
Oddometer: 1,469
+1 Wha Cy Says...
Originally Posted by Cyclops Motorsports View Post
Great fab skills.
And if any flex/ twist in the rear would be directed at the seams... Causing a rupture near a smoldering exhaust.
But I love this direction so keep it going!!!
'"This whole memory lapse is gett'in to me. Hopefully I think I'll outgrow it."
DesertSurfer is offline   Reply With Quote
Times are GMT -7.   It's 11:25 AM.
