Old 07-11-2013, 04:04 AM   #1
Just Dan OP
Bugger, Burnt toast
Just Dan's Avatar
Oddometer: 1,877
Bike in a box. A winters project a Skyteam Ace
Being in the grip of a cold winter on this side of the world. The garage takes over instead of riding around on icy roads.
An advert in a local motorcycle magazine caught my eye. A Skyteam ACE 125 delivered to your door in a box for bit more than half the price of on fully assembled from a shop. A couple mates have also bought one as well with the idea of modifying them for more speed. Most likely we will go down the same path as AVA motorcycles and put a 250 engine in place of the 125. These things a tiny at 90kg with a full tank of fuel.
Like Mad Ass's. The hot up bits cost less than a carton beer. This make a nice change after European bike prices.
Said box arrives after 3500 km on the back of a semi trailer and cross a small ocean to arrive at my garage.
Yep, there is a bike inside that tiny box.
After removing the packing frame.
Had a laugh at this.
Front wheel on.
On its own wheels. Looks like it ready to go, Not really.
I have the 303 kit from OOracing. With a smaller rear sprocket, CDI and new needle & jet. The muffler has to be hack sawed off and CAT removed (+3 hp) and more racy muffler. Need some of piggy back shocks from Ebay. Well you probably get the idea.
13' kawasaki W800, Yep the twin
13' Skyteam Ace 125 BIG BORE
81' BMW R100 TIC
Old bikers don't get old by accident.
Just Dan is offline   Reply With Quote
Old 07-11-2013, 04:28 AM   #2
Brunow - 007
Bantam Fever
Brunow - 007's Avatar
Oddometer: 308
I would check all the nuts & bolts.
-ADD GREASE
-Check tire's for pressure
-Drain oil
-Drain brake fluid
-Replace spark plug
-ADD GREASE x2!
-Replace chain
-Replace engine
It's Chinese =/ Honda!
Still like the honda Dream 50 dual overhead cam engine more!
Good luck with it!
Working on the D14/4 Bsa Daily Driver .
Brunow - 007 is offline   Reply With Quote
Old 07-11-2013, 04:50 AM   #3
Just Dan OP
Bugger, Burnt toast
Just Dan's Avatar
Oddometer: 1,877
I fully understand the Skyteam is Chinese and is a mixed bag in a quality. I don't plan to ride the bike across country. It is more about having a bit fun during the winter months in the garage.
81' BMW R100 TIC
Old 07-11-2013, 01:05 PM   #4
YamaGeek
Ancient trailbike padwan
YamaGeek's Avatar
Oddometer: 6,177
Funny it doesn't look a thing like the Sachs Madass, but it looks like it has the Lifan 125 OHV clone of the Honda CG125 engine. Those engines, (according to BigMoth..) are supposedly real durable engines. But can they rev up?
We're here because of a love most exestential. (toothy)
YamaGeek is offline   Reply With Quote
Old 07-11-2013, 02:32 PM   #5
Kennon
Kennon's Avatar
Oddometer: 285
this will be good to follow, perhaps a supertrapp silencer? for a small bike like this would really recommend Michelin Pilot Sporty tyres had them on my supermoto they were great in the dry and in the wet.
Kennon
2009 Yamaha Jog 50RR LC sold 2011
2011 Rieju Marathon Pro 125 SM sold 2013
1990 Honda VFR 400 NC30 purchased 2013
Kennon is offline   Reply With Quote
Old 07-11-2013, 03:56 PM   #6
DRjoe
DRjoe's Avatar
Oddometer: 5,072
That's a cool little bike.
Old 07-12-2013, 01:05 AM   #7
Just Dan OP
Bugger, Burnt toast
Just Dan's Avatar
Oddometer: 1,877
The importer said the engine is from Loncin and is their copy of a Honda CG125. Loncin is the same factory that makes the engines for the BMW F800gs. They also make small single cylinder 4 strokes for Yamaha and Honda.
From threads that I have read about the ACE. Most have surprised by the reliability and some have blown up in a couple hundred miles. I guess the Ace is about the same quality as a Mad Ass. The Mad Ass also seems to real hit and miss in the engine department. Only time will tell if my bike is a grenade.
I think the secret with all small engines is change the oil often. The sump on the ACE only holds 1L (1qt) So no hard ship in changing the oil.
Out of the box. There is no other way to say it. The little Ace is gutless, and is strangled with EPA gear & cat in the exhaust. Top speed out of box is 80 kph (50 mph). With EPA and cat removed from the header pipe. Add the hot kit from OOracing. The blokes at OOracing have got 130 kph (85 mph ) on a dyno. In real life that would be more like 110 kph (70 mph) down hill.
The 303 Kit from OOracing
81' BMW R100 TIC
Old 07-12-2013, 01:32 AM   #8
rat110
Has a Zombie House
rat110's Avatar
Oddometer: 540
MORE! I'd be interested in seeing how this turns out
You have a link to a site where you ordered the bike from? Sounds good fun!
If ever there was a place where mother nature said to man fuck you go away, it'd be Australia. -PachmanP.
rat110 is offline   Reply With Quote
Old 07-12-2013, 02:06 AM   #9
Just Dan OP
Bugger, Burnt toast
Just Dan's Avatar
Oddometer: 1,877
I bought the bike in box from Ikonik motorcycles in Perth WA. They have ads in Motorcycle trader. $1695 for the bike and $125 delivery Aus wide. Or from the website here. You can buy one fully assembled from a dealer for $3000
http://ikonikmoto.com.au/demo/index....29cff91b36fc28
81' BMW R100 TIC
Old 07-12-2013, 01:25 PM   #10
YamaGeek
YamaGeek's Avatar
Oddometer: 6,177
I've got a 125cc OHC horizontal clone engine in a Honda Cub, it's not without some small problems, the main one being it doesn't have a 5 speed gearbox, and the jump between 3rd and 4th gears being a bit wide. The countershaft and rear wheel sprocket gearing is almost perfect otherwise.
Does the Loncin come with a 5 speed box? I know the vertical cylindered Lifans are 4 speed up to the 150cc.
I've found that both of my clone engines like having an intake tuning tube between the carb and air-cleaner. It loses a small amount of bottom end, but adds a considerable amount boost to the mid and high rpm range. You do have to play with the jetting if you do this mod, at least with Stateside engines because they all seem set up a bit lean.
Old 07-12-2013, 04:39 PM   #11
Just Dan OP
Bugger, Burnt toast
Just Dan's Avatar
Oddometer: 1,877
The Loncin is a 5 speed box. From what I have read, the Ace is set up really lean as well. I have a larger jet to go in the carb. I have also made a blanking plate for the side of the engine to remove the EPA gear to meet Californian requirements.
The Ace air box is not suppose to be that bad. It seems the HP loss is the CAT imbedded in the header pipe. Removing that gives an extra 3 HP.
81' BMW R100 TIC
Old 07-12-2013, 07:48 PM   #12
MacNoob
MacNoob's Avatar
Oddometer: 1,585
"Racing Super Battle Creative Factory Posh C.D.I."
OK, I have to see what happens with this.
"Ignorance, you see, can be out thought. Arrogance can be outmaneuvered. But ignorance and arrogance combined are unassailable."
82 Honda C70, 71 Honda CL175, 08 Kawasaki KLR650, 85 Honda GL1200 Goldwing
MacNoob is offline   Reply With Quote
Old 07-12-2013, 08:04 PM   #13
Kennon
Kennon's Avatar
Oddometer: 285
what is the carb a copy of? I know from pitbike tuning that even a unset up mikuni will produce a good 2bhp more than a well set up copy due to the tolerances of the quality in its production so when a mikuni is set up well its a big difference in responce
Kennon
Old 07-13-2013, 12:07 AM   #14
Just Dan OP
Bugger, Burnt toast
Just Dan's Avatar
Oddometer: 1,877
It looks like a copy of Keihin. The brand an model is Deni gpz26. Today, I replaced the main jet (90) with a 95 and idle jet (38) with a 45.
Removed the pollution stuff
Attached a blanking plate
Plugged in the new CDI
Replaced the standard 38 tooth rear sprocket with a 34 tooth JT sprocket.
If you are playing along at home. Make sure the JT brand mark is on the inside of the wheel. The sprocket cir clip needs to refitted and only works the JT brand mark is on the inside.
81' BMW R100 TIC
Just Dan screwed with this post 08-22-2013 at 01:26 AM
Old 07-13-2013, 12:30 AM   #15
WTFMATE
Oddometer: 50
Cool looking bike. Does it have a compliance plate?
WTFMATE is offline   Reply With Quote
Times are GMT -7.   It's 05:58 PM.
