Old 09-26-2012, 02:06 PM   #61
PhiSig1071
What's ******width?
PhiSig1071's Avatar
Oddometer: 2,438
Looking forward to following your progress.
Which one of you FF's was it?...FOUNDER!
Entia non sunt multiplicanda praeter necessitatem
PhiSig1071 is offline   Reply With Quote
Old 09-26-2012, 11:24 PM   #62
Quacamole OP
Quacamole's Avatar
Oddometer: 85
Originally Posted by sailah View Post
With your fab skills, I'd seriously consider a tank from scratch. I've fought with modifying tanks before and usually the result is less than stellar.
You also could consider redoing the subframe and putting a couple gallons there by replacing the entire thing and plating in some tubes. I tried this on my last build and got 2.16 gallons under there. I'm thinking about making a new one with 4 gallons as it's my only tank.
You could make a slim tank on top with 4-5 gallons and get 3 under the seat.
To make it from scratch I dont have any sheetmetal treatment machinery available, so it will be quite angular. Easier to modify some existing tank I think. Also was thinking to shove all the electrics inside the subframe, and use 950 plastics over there. BMW F800 has nice set up for a tank, but that's where my silencers will be.
Your CBR has only 2.16 gallon tank - was wondering will you add something on top of the engine like your FZ1 has?
Quacamole is offline   Reply With Quote
Old 09-26-2012, 11:29 PM   #63
Quacamole OP
Quacamole's Avatar
Oddometer: 85
Originally Posted by TerraRoot View Post
I thought the point of use the ktm as the start point was to bolt on the ktm bits after the engine was in?
That was one of the ideas, but hard to get these tanks and they'r expensive + KTM original frame is with straight tubes, mine has an angle so the KTM tanks will be looking outwars like wings.
Old 09-27-2012, 06:20 AM   #64
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,647
The cbr is just a toy so no top tank. Thinking about building another tank with 3-4 gals though.
Tanks are tough to get to look right, they are so visible and in many cases, the focal point of the bike. I had to cut the fz1 tank but not that much and it was a lot of work. Plan on lining the tank when you are done I had a few pinholes from welding that were impossible to get with a tig torch.
That gs tank just looks huge. I wonder if there is a smaller main tank that would fit the frame better and maybe a side pipe tank or subframe tank to get you the volume you want?
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
sailah is online now   Reply With Quote
Old 09-29-2012, 12:29 PM   #65
Keith
Slabbing it
Keith's Avatar
Oddometer: 906
Supposedly one can fill and cap thinwall pipes with sand to keep them from wrinkling like that.
Random Crap
Keith is offline   Reply With Quote
Old 10-08-2012, 11:09 PM   #66
KaceCoyote
Pass the queer more beer
KaceCoyote's Avatar
Oddometer: 5,632
A split tank may be a better idea. I carry the fuel lower and so fourth, and you dont have to worry quite so much about the width in question.I worry about the bar clearance.
When the smoke clear, you can see the sky again
There will be the chopped off heads of leviathan
My friend, they call 'em strangers
Everybody talk to them end up in some danger
-MF Doom, Strange ways
KaceCoyote is offline   Reply With Quote
Old 10-11-2012, 11:45 AM   #67
snowhawk jockey
Slack Jaw Gaper
snowhawk jockey's Avatar
Location: The other Center of the Universe: Bend, Oregon
Oddometer: 1,115
Cutting the Tank into thirds:
Each side and the center span.
Replacing the center span with flat sheet metal, increasing the width, until sides are in acceptable position for the frame.
snowhawk jockey is offline   Reply With Quote
Old 10-12-2012, 01:02 AM   #68
Quacamole OP
Quacamole's Avatar
Oddometer: 85
Thanks for...
Thanks for the good advice and ides for all of you. Have been working in Sweden for two weeks, will be back next week to continue with the bike.
About the tank - looks like I'll be cutting it in three sectoins as snowhawk jockey suggested, but I have to take look
at it again when I'm back.
Br.,
Old 10-16-2012, 10:03 AM   #69
SloMo228
World Class Cheapass
Oddometer: 1,729
I love builds like this. Subscribed!
--------------------------- Steve----------------------------------------
'93 GL1500 frankenbike basketcase in progress
'96 DR350SE
SloMo228 is offline   Reply With Quote
Old 10-16-2012, 01:29 PM   #70
Quacamole OP
Quacamole's Avatar
Oddometer: 85
Back in the shop
Back in the workshop, but I only had couple of hours for some serious engineering and designing.
Decided not to cut the tank into three pieces, instead I cut the areas off from lower side to make the
tank fit. Probably will cut the whole lower side off and weld VFR tank's lower side to it.
Also cut the VFR tank into half - lot of sludge inside
Lower side of it, which I'm thinking to use
VFR gas cap fits the GS tank opening but to lock it some mods are needed
So the result should be something like below
Area where the additional tank volume will be added
Old 10-16-2012, 01:36 PM   #71
Quacamole OP
Quacamole's Avatar
Oddometer: 85
Cans
Also KTM SM silencers arrived while I was away. Heavy bastards, thought them to be lighter like everything else
on KTM's. Maybe I'll end up using only one - still thinking
Old 10-16-2012, 01:38 PM   #72
SloMo228
Oddometer: 1,729
Very cool. Did you take any kind of precautions with regard to gas fumes before cutting the tank? I have been thinking of cutting off the bottom of my bike's tank to attach a larger-capacity top to it since the stock tank has odd dimensions and few tanks I've seen are close, but I worry about accidentally setting off an explosion in my face.
'96 DR350SE
Old 10-16-2012, 01:46 PM   #73
Quacamole OP
Quacamole's Avatar
Oddometer: 85
Just flushed the tank with high pressure water couple of times and left the water inside, while using angle gringer.
Can also use the jig saw or recip saw not to create the sparks.
Old 10-16-2012, 06:58 PM   #74
R1100purist
Which way is north?
R1100purist's Avatar
Oddometer: 151
Great
This is the coolest thread I have seen in awhile! Keep it up.
R1100purist is offline   Reply With Quote
Old 10-16-2012, 09:17 PM   #75
mikejohn
mikejohn's Avatar
Oddometer: 1,179
De-cat them, might save some weight there
mikejohn is offline   Reply With Quote
Times are GMT -7.   It's 06:44 PM.
