Old 10-10-2012, 04:22 AM   #31
vonotto
vonotto's Avatar
Oddometer: 210
I put this pipe on my 11' R. Sounds great, almost like a big single till you open up the throttle. I added an high flow filter with the pipe and it helped with the throttle control and added bottom end power. Remus told me I didn't need a map just put it on and go. This is a great addition to the bike
vonotto is offline   Reply With Quote
Old 10-10-2012, 08:20 AM   #32
Narsisco Lopez
Addlepated
Narsisco Lopez's Avatar
Oddometer: 2,060
I put my Remus Revolution Titanium (got it from CJ Designs along with his 2-into-1 collector) on my bike just around the same time as Hondo for the same reason... also got my CJ Designs Expedition Storage Box.
I went with the Revolution Titanium/ESP for the extra storage and weight loss (looks like a net loss of about 15lbs), but the great sound and performance is an added benefit. And no... didn't have to mess with the ECU map whatsoever. The bike idles just fine and I haven't noticed anything jarringly different in the power curve.
FYYFF!
http://www.youtube.com/watch?v=NtpUv4VBDhA
Bikes
2012 BMW K13S | 2009 KTM 990 Adventure (SOLD!) | 2003 Suzuki DRZ400E
Narsisco Lopez is offline   Reply With Quote
Old 11-08-2012, 06:29 PM   #33
zen rider
veteran rider
zen rider's Avatar
Oddometer: 208
I have a TuneECU for my '08 990 Adv even without an exhaust. The TuneECU is mainly to smooth out the fueling (not a prob on newer than '08). So if you have a newer bike save the money.
I'm really thinking of this Remus Roxx 2:1. Also contemplating a Q4 or Arrow too. I have no plans for tool tube or aux fuel tank. I've owned Q4 (xr650l) and a Remus (vfr800) on previous bikes. Loved both. I've read the Q4 may lose bottom end? Wondering if TuneECU would fatten the bottom end?
Kevin
'08 KTM 990 Adventure w/19" front Excel; '09 Sherco ST 2.9 trials
zen rider is offline   Reply With Quote
Old 01-02-2013, 02:52 PM   #34
romeoalpha29er
Oddometer: 5
Thanks hondo !
As they use to say - Your're the Man !!
Thanks for your helpful tips, now I just wait (I am about 14,000 Kms from Colorado),,, !
Big B
romeoalpha29er is offline   Reply With Quote
Old 01-03-2013, 10:02 AM   #35
onedirtbag
Oddometer: 4
Remus
Should be receiving my Remus roxx and tank from CJ in the next few days for my 07 990.Thanks Hondo for your detailed pic by pic instructions. You sure make it look easy. Do you have the stock fuel mapping? I have read some threads recommending 15 minute idle for reset. Did you do that? Thanks again for giving your time.
onedirtbag is offline   Reply With Quote
Old 01-03-2013, 10:56 AM   #36
Hondo OP
What if its a Samsquamch?
Hondo's Avatar
Oddometer: 7,742
I used the stock mapping & did the 15 minute idle (though I read somewhere that this might not work unless hooked to Tune ECU or the KTM software) - it runs great.
LC8World.com - KLRWorld.com Forums - Nighthawk Forums
"Life's an adventure, and I refuse to live a boring one."
Hondo is offline   Reply With Quote
Old 01-03-2013, 08:58 PM   #37
Pussboy
Oh, nice marmot.
Pussboy's Avatar
Oddometer: 336
Just pulled my stock exhaust in anticipation of my new Remus 2 into 1! I cant wait until it gets here! Thanks for the info!
2011 KTM Adventure R:
Pussboy is offline   Reply With Quote
Old 01-04-2013, 12:02 AM   #38
Hondo OP
Hondo's Avatar
Oddometer: 7,742
Post up what you think when you get it running-
Old 01-04-2013, 02:46 AM   #39
1050rat
Oddometer: 26
Did you remove the SAI system as I understand it is only necessary for the stockers with cats and even if disabled in tuneecu fails open ?
Cheers
1050rat is offline   Reply With Quote
Old 01-05-2013, 08:40 AM   #40
T-Mac
orange
T-Mac's Avatar
Oddometer: 36
TuneECU
If anyone manages to create a better map with TuneECU, please share it.
I believe the standard map can improve a lot, moreover fuel economy.
Other than that everything said about the Roxx is true, a bit more on the bottom, a bit less on the top, better response in bottom, saved weight. I like it (titanium)!
KTM 990 S Adventure
T-Mac is offline   Reply With Quote
Old 01-05-2013, 09:38 AM   #41
MAXVERT
Rough Rider
MAXVERT's Avatar
Oddometer: 831
8,000 mi.
'07 KTM 990 A 28,000 mi. Remus 2 to 1 Stainless Pipe
CPR air filter kit with red prefilter.
SAS off, Canister gone. O2's on
TPS set TB's balanced
I installed this '08 Akra map from the TuneECU library.
KM601AK0702S01Map.hex OEM md5checksum KTM990 Thanks Nils
After 8,000 miles, most of which was in Mexico, riding every road
type from the fabulous Ruta 16 from Hermosillo to Creel to
blasting two up on the Auto Pistas at 160 km/hr, the bike is as
close to perfect as any bike I've ridden.
The throttle response is as good as any carbed bike I've ridden,
an absolute must on the twisty bits. Power wise, it's there, across the RPM range.
Most riding was two up fully loaded for touring.
Twist it, Max
Da oggi la strada
é senza limiti
MAXVERT is offline   Reply With Quote
Old 01-05-2013, 11:56 AM   #42
Hondo OP
Hondo's Avatar
Oddometer: 7,742
Cheers
Nope, my 990 remains stock under the plastics.
Old 01-12-2013, 10:06 PM   #43
Pussboy
Oh, nice marmot.
Pussboy's Avatar
Oddometer: 336
Got mine on last night! Thank goodness for 60 degree January days in Ohio! Thanks for the pics Hondo, they helped when I was trying to figure out how the clamp mounted! It sounds good and seems well behaved. Come on spring!
Sent from my DROID RAZR using Tapatalk 2
Old 01-16-2013, 12:59 PM   #44
skclarey
Tempe trail rider
Oddometer: 61
rack?
Where did you get the rear rack that holds the Roto Pax?
2012 KTM 500 XC-W
2010 KTM 990 Adventure
skclarey is offline   Reply With Quote
Old 01-16-2013, 01:16 PM   #45
Hondo OP
Hondo's Avatar
Oddometer: 7,742
I made it.
http://advrider.com/forums/showthread.php?t=795348
Hondo screwed with this post 01-17-2013 at 05:14 AM
Times are GMT -7.   It's 10:48 PM.
