Old 08-01-2013, 04:44 AM   #3481
Mobiker
Mobiker's Avatar
Oddometer: 1,824
Originally Posted by markjenn View Post
Of 'old what? Honda had one single foray with hydraulic valves on a DOHC bike back in the mid-80's, but other than that, they've not been tried before or after.
- Mark
True, except they built that bike, more or less, up until 2003. Pretty good run. No problems that I'm aware of. Begs the question why they couldn't have done hydraulic valves on the cb1100. Honda obviously knows how to do it. I wouldn't think cost is that much of a factor since the Nighthawk 750 was always a pretty low priced bike. Certainly simplifies maintenance and lowers the cost of ownership.
'88 R100GS
'76 xl350
"Don't Panic"
"If I was in a hurry, I'd left earlier."
Mobiker is offline   Reply With Quote
Old 08-01-2013, 05:03 AM   #3482
Super Sneaky Steve
B@nned Club :D
Super Sneaky Steve's Avatar
Oddometer: 6,427
Hydraulic valves don't work on higher reving bikes. My guess is they wanted the new CB to have a higher red line than those types of valves would allow.
Naturally, the common people don't want war; ... the people can always be brought to the bidding of the leaders. That is easy. All you have to do is tell them they are being attacked and denounce the pacifists for lack of patriotism and exposing the country to danger. It works the same way in any country - Hermann Goring
Super Sneaky Steve is offline   Reply With Quote
Old 08-01-2013, 05:53 AM   #3483
Mobiker
Mobiker's Avatar
Oddometer: 1,824
Depends on what you consider higher revving, The 700 Nighthawk of the early '80's redlined at 10,600. I don't recall the exact redline of the later 750's, but I'm sure it was at least 8500-9000 rpm.
'88 R100GS
'76 xl350
"Don't Panic"
Old 08-01-2013, 06:14 AM   #3484
Dave in Wi
Dave in Wi's Avatar
Location: Madison WI (40 Square Miles Surrounded By Reality)
Oddometer: 2,052
Man we can be cranky old son of a guns can't we.
"I won't buy one because it doesn't have (insert some feature from a random older bike)."
"I won't buy one because it has (insert updated, modern feature old bikes didn't have)."
Dave in WI
2002 ZRX1200R
1975 XL100
1988 DT50
"Daddy, it's five o'clock sometime!"
Dave in Wi is offline   Reply With Quote
Old 08-01-2013, 06:35 AM   #3485
Roadscum
Oddometer: 2,503
Why not.... Ya gotta have what puts a smile on your face, no?
REgards, Paul
"One of the things that make motorcycling so great is because it never fails to give you a feeling of freedom and adventure." - Steve McQueen
Roadscum is offline   Reply With Quote
Old 08-01-2013, 06:36 AM   #3486
Roadscum
Oddometer: 2,503
If it has shaft drive and hydronic lifters...... It's for me.
Regards, Paul
Old 08-01-2013, 11:11 AM   #3487
markjenn
Oddometer: 10,473
I'm sure they could have done it; my point was only that hydraulic valves on a DOHC inline-four are not something Honda (or any mfg) has commonly done and so to do it on the CB1100 would have been a fairly departure from normal practice and likely expensive. We've been living with shims on DOHC bikes now since the 1973 Z1.
All this being said, most shim-adjusted systems these days have been marching towards fairly high adjustment intervals, typically 26K miles on Yamahas and 15K miles or so on most Hondas, Suzukis, and Kawasakis. To now have a 8K interval on the CB1100 is a bit of a regression; it's probably lower because the bike is air-cooled. I haven't seen a DIY on how to do it, but I assume it is fairly easy since the bike has no bodywork to remove and no cooling system to monkey with.
It certainly wouldn't be a reason I would avoid the bike.
- Mark
Old 08-01-2013, 05:11 PM   #3488
tjohns14
Oddometer: 3
how do you tell abs from standard
Hi,
I just put 1k miles of my cb1100. Went riding with a friend he pointed out to me that my bike is abs. Because of the control wire going to rear caliper. Does anyone know if this is right? Also have 2 piston calipers on the front x 2.
Thanks Tom
tjohns14 is offline   Reply With Quote
Old 08-01-2013, 06:36 PM   #3489
Crilly
Oddometer: 793
All CB1100s have the rear abs ring. It is also used for a speed sensor.
The abs model also has a front abs ring. That is how you tell the deferents.
Crilly is offline   Reply With Quote
Old 08-01-2013, 07:36 PM   #3490
Scoobynut
Oddometer: 583
Crilly is correct. If it doesn't have the front ring, it's a non-abs bike.
____________________________________
2014 Yamaha XT1200Z Super Tenere
2013 Honda CB1100
2008 Yamaha WR250R
1988 Honda Hawk GT
Scoobynut is offline   Reply With Quote
Old 08-01-2013, 08:24 PM   #3491
tjohns14
Oddometer: 3
abs
Thanks Guys appreciate the help.
Old 08-06-2013, 01:44 PM   #3492
buck80mph
"Power Junkie"
buck80mph's Avatar
Oddometer: 199
I just got back from a 9 day 3,757 mile trip on the CB...
It performed flawlessly in all conditions: 100+ degree dust storm in the panhandle of Ok. USA, 35 degree freezing rain and snow at 12,000 feet elev in Co USA, in the high winds at 14,160 feet elev of the highest paved road in North America (Mount Evans Co.), to the Desert of Az. USA and from the twisties of the "Million Dollar Highway 550" to the straight slabbing of the interstates. Very dependable and adequate motorcycle. I went 162 miles on a tank once(not by choice). I filled it up and figured 50 miles to the gallon. That was during a stretch of highway where speeds didn't surpass 65mph much if any. When slabbing it on the interstate at 72 mph- 76 ish it burns much more of course.
2011 1050 Speed Triple
2012 750 Kawasaki Brute Force
2010 800 polaris rzr-s
buck80mph is offline   Reply With Quote
Old 08-06-2013, 01:52 PM   #3493
dirtdreamer50
long time rider
dirtdreamer50's Avatar
Oddometer: 1,160
Sounds like a great adventure. Guess you put the complaint of "Too Small Gas Tank to Tour" to rest. Did you use a windshield on the trip? If not, you are one determined individual, for sure... tp
Little Fauss: I was going faster than I ever went in my whole life, then I fell off.
dirtdreamer50 is offline   Reply With Quote
Old 08-06-2013, 02:17 PM   #3494
buck80mph
"Power Junkie"
buck80mph's Avatar
Oddometer: 199
Lol. Yes it had a windshield.
Old 08-29-2013, 07:00 PM   #3495
DOUBLE-O G OP
Smooth Operator
DOUBLE-O G's Avatar
Oddometer: 2,797
Where did everybody go?
2013 Honda Super Cub
DOUBLE-O G is offline   Reply With Quote
Times are GMT -7.   It's 07:34 PM.
