08-26-2012, 12:49 PM
#46 |
Rat Rider
Oddometer: 2,801
08-26-2012, 12:59 PM
#47 | |
Boring Old Fart
Oddometer: 814
Defense Against Bears
"The National Park Rangers are advising hikers in Glacier National Park and other Rocky Mountain parks to be alert for bears and take extra precautions to avoid an encounter.On a more serious note a 12 ga. w/ slugs will provide ample penetration to stop one of those rascals, assuming of course that you hold up your end of the deal.
"I don't want a nickel... I just wanna' ride my motor-sickle." Arlo Guthrie LexLeroy screwed with this post 08-26-2012 at 01:06 PM |
08-26-2012, 01:22 PM
#48 | |
winter is coming
Oddometer: 9,153
Murphy's Law. One of the problems with something like that would be the complacency it could breed. I do not go for electronic sights on any gun that I consider a defensive arm.
Μολών λαβέ Hard cases make bad law. |
08-26-2012, 01:25 PM
#49 | |
Careening forward
Oddometer: 5,663
It's too bad that you can't carry a sidearm because I've always thought the Ruger Alaskan would be a good bear gun. http://en.wikipedia.org/wiki/Ruger_Alaskan
KLX 400 dual sport Tune in, turn on, drop out. |
08-26-2012, 01:34 PM
#50 | |
winter is coming
Oddometer: 9,153
Re the 500, there is something almost magical about that cartridge in my opinion. It just smacks shit down. It's hard to even describe until you experience. IMHO, no 44 Mag nor 454 even comes close. It is the only handgun that I would even consider if I knew I had to go deal with a big bear.
08-26-2012, 02:01 PM
#51 | |
Oddometer: 6,452
There was one I recall where a guy was potting woodchucks and attacked, he had a 22/250 if I recall, shoved it in the grizzlies face and pulled the trigger. Was an instant stop, said the bears brain was the consistency of oatmeal.
You know, a long time ago being crazy meant something. Nowadays everybody's crazy IBA 22425 |
08-26-2012, 02:09 PM
#52 | |
Rat Rider
Oddometer: 2,801
Wish we could carry sidearms. I'm in black bear country, so a good S&W 686 would work well here. Lyle |
08-26-2012, 03:03 PM
#53 | |
winter is coming
Oddometer: 9,153
08-26-2012, 03:32 PM
#54 |
Oddometer: 108
Bella twin of Lesser Slave Lake Alberta held the world record size grizzly bear for a number of years. Shot in self defence in 1953 with a 22 single shot rifle. She only had 7 shells on her when she was berry picking. Do not know how to attach the story from the internet on an iphone. Lol. But a google search will find it.
08-26-2012, 03:49 PM
#55 | ||
Easily trainable
from http://www.angelfire.com/on2/LandOwn.../Grizley1.html The Rimfire Wins Again!
08-26-2012, 04:35 PM
#56 | |
Oddometer: 2,494
Plus http://www.garrettcartridges.com/4570.html My buddy bought Garrett 45-70's, and killed two full grown wild hogs from the side (through the plate oat least one!) with one shot. I'm not shitting you - I was there with my Marlin lever-action .357 Magnum. Both hogs fell from one shot. "PENETRATION: THE 45-70 & 458 MAGNUMS The following article is based on bullet penetration test results as measured in water-saturated penetration materials (wet newspapers). Water is the primary substance of life, and constitutes about 90% of the content of all mammals. I have observed that some "testers" have chosen wood boards or dry newspapers for penetration testing material, and this is a very poor choice, which in no way simulates the characteristics of a bullet impact with animal flesh. Wood tends to channel the bullet path, and is less demonstrative of the terminal instabilities inherent to non-expanding bullets when impacting game animals, and is thus an inferior material for the testing of bullet penetration characteristics. Water-saturated penetration materials such as newspapers or ballistic gelatin are far superior with regards to their ability to demonstrate the terminal instabilities that typically occur when non-expanding bullets impact live animal flesh. - Randy Garrett There are few things in the world of ballistics less well understood than the issues relating to comparative penetration. It is commonly believed that the faster one drives a solid bullet, the deeper the penetration. We see this all the time in the various attempts, via new calibers, to achieve higher velocity for improved performance on heavy game. The current rage among big bore shooters seems to be the 458 Lott, since it achieves a good 200-300 fps higher velocity than the 458 Winchester Magnum. It is claimed that the new 458 Lott is an improvement over the 458 Winchester Magnum since its higher velocity supposedly results in more lethal impact-effect and deeper penetration. This, it is claimed, is just the ticket for busting the heaviest game. Of course, the new 458 Lott also achieves greater kinetic energy as a result of its higher velocity, and this is also a convincing characteristic for those brave souls in pursuit of the heaviest game. Despite all the impressive "science" deployed to reinforce the assertion that higher speed projectiles are more capable of inflicting the deep penetration and impact-effect required to reliably anchor heavy game, one finds that these assertions simply do not withstand common sense, repeatable penetration testing. In fact, if one conducts these tests, one finds that there is nothing that can be observed which supports the assertion that the faster one drives non-expanding solids the deeper they penetrate. Very interestingly, if one takes the Hornady 500-grain .458 diameter solid bullet and compares the penetration that results from impact speeds varying from about 1500-fps to 2500-fps, one finds that the higher impact speeds produce the least penetration. When driven to about 1500-fps (as the 45-70 will do) one finds that such solids produce nearly 6-feet of penetration in wet newspapers. When the same bullet is driven to about 2100-fps (as is characteristic of the 458 Winchester Magnum) one finds that the penetration is reduced to about 4 to 4 and 1/2 feet. When one tests the same bullet at 2300-2400 fps (as is characteristic of the 458 Lott) one finds that the penetration comes up nearly 20% short of that produced by the 458 Winchester. And when one tests the same bullet at the blistering speeds characteristic of the mighty 460 Weatherby Magnum, one finds that the penetration achieved is the most shallow produced by the various 458s. What is apparent from testing is that penetration stops increasing at impact speeds above about 1250-1300 fps. When the impact speeds significantly surpass about 1600-fps, there is a very definite and measurable decrease in penetration depth. This raises some interesting issues regarding the relationship between kinetic energy generation and impact-effect. Although higher velocity projectiles always generate more kinetic energy they clearly do not produce deeper penetration, and when the velocities reach the levels common to today's magnums, the increases in velocity result in significantly reduced penetration. Simply stated, the faster they strike the faster they stop. Fortunately for all of us who shoot the 45-70, it can be considered to be the deepest penetrating of the various 458 calibers. This is not due to any particular inherent superiority, but due to the 45-70's "inability" to achieve the velocity with heavy bullets that leads to decreases in penetration. The reasons why high impact speeds reduce penetration are not well understood. However, anyone who takes the time to run comparative penetration tests will find that those of us who pack a good 45-70 with heavy bullets need not take a back seat to any other 458 caliber, especially when the game is heavy and the penetration requirements are great. - Randy Garrett" http://www.garrettcartridges.com/penetration.html |
08-26-2012, 05:59 PM
#57 | |
Oddometer: 4,524
Really?? I've hunted and killed bears they usually dont just walk up and kill you. Most any revolver of .357 mag or above I would feel very safe with.
Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover. -Mark Twain |
08-26-2012, 06:23 PM
#58 |
aka Road Monster
Those aimpoint thingies are good for bust'n paper targets and bowling pins, But I wouldn't wanna be look'n for a red dot against a brown back ground that's chargin'. That sounds like disaster fix'n to happen. I'll take the open sights.
The basic question of politics is "Who does what to Whom?". -Vlademir Lenin. "Politicians are always interested in people. Not that this is always a virtue. Fleas are interested in dogs." -P.J.O'Rourke |
08-26-2012, 09:08 PM
#59 |
Riding Nomad™
Oddometer: 12,722
Learn to ride. Ride to learn. FS: 1993 Suzuki DR350S (wide ratio 6 speed - street legal kickstart) |
08-26-2012, 09:45 PM
#60 | |
Tenured Prof - Leghump U.
Oddometer: 648
Buffalo Bore rocks. Great stuff. |
| Thread Tools | |
