Old 09-10-2012, 11:10 AM   #31
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,041
Originally Posted by clapped_r6 View Post
it's going to be once i order some parts!
what % pulls 3 watts? i was planning on getting the model 60. which dimmer does this come with for the ktms?
3 watts with the model 60.
LED Contoller is the same setup as the Husky with KTM specific connectors (whatever they might be).
Old 09-10-2012, 11:15 AM   #32
clapped_r6
The Spoad Warrior
clapped_r6's Avatar
Oddometer: 2,687
i meant what % is the 60 putting out at 3 watts? (i.e. 20%, 30% etc)
none of us is as dumb as all of us
clapped_r6 is offline   Reply With Quote
Old 09-10-2012, 11:47 AM   #33
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,041
Based on the power used, around 10%. As far as % of light well I'd guess maybe 20%, when you turn on the high beam it really is an OMG type of reaction to the increase in light.
Old 09-11-2012, 07:24 AM   #34
teambft
teambft
teambft's Avatar
Oddometer: 1,199
Any updates on availability of the light for a 2012 KTM 500 EXC?
2011 KTM 300 XC-W, 2001 Aprilia Falco, 2010 KTM 530 XCW Six Days, others
2012 KTM 500 EXC - sold, 950 SER-sold (regret)
Prior: BMW XC, TE610, KLR 650, 07 KTM 990 Adv, and many more ...BMWs, Ducs, KTMs, Harleys
teambft is offline   Reply With Quote
Old 09-11-2012, 08:12 AM   #35
Hondo
What if its a Samsquamch?
Hondo's Avatar
Oddometer: 9,506
I am considering a Model 60 in an effort to improve the crummy headlight on my KLX450R. (and reduce electrical demand)
Have you had anyone attempt to mod this kind of headlight -
KLRWorld.com Forums - Nighthawk Forums
"Life's an adventure, and I refuse to live a boring one."
Hondo screwed with this post 09-11-2012 at 08:45 AM
Hondo is offline   Reply With Quote
Old 09-11-2012, 12:20 PM   #36
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,041
Should be available next. Would you prefer one or two lights?
Nope. How does the light mount in the mask?
Old 09-11-2012, 12:25 PM   #37
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,041
WIthumper photos!
Low Beam
High Beam
Yep, its a night shot Night rides will never be the same
What the cager sees
Old 09-11-2012, 12:34 PM   #38
clapped_r6
The Spoad Warrior
clapped_r6's Avatar
Oddometer: 2,687
i'm totally getting one, that looks amazing.
need to convert my katoom to dc first though
Old 09-11-2012, 05:45 PM   #39
Baja Ho
Baja Ho's Avatar
Location: Central Coast, CA. USA & Cabo San Lucas, Baja Sur
Oddometer: 773
The last two pictures, the night shots are they hi or low beam?
Baja Ho is offline   Reply With Quote
Old 09-11-2012, 06:43 PM   #40
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,041
Probably high beam on the pic with the driveway to the left. Perhaps WIthumper can confirm?
Old 09-11-2012, 08:01 PM   #41
Hondo
Hondo's Avatar
Oddometer: 9,506
I'll have to take it apart & look at it- I'll take some pics.
Old 09-11-2012, 08:24 PM   #42
Hondo
Hondo's Avatar
Oddometer: 9,506
Ok, here are some images-
The front of the mask with the H4 bulb installed- the screw on the bottom allows for vertical adjustment-
The rear -
I removed the bulb and the found that the mounting area is about 65 mm across-
The diameter of the model 60 is shown on your site as 55mm- this just might work!
I'll have to cut up the reflector housing, but it won't be used anyway.
How much does the model 60 weigh?
Hondo screwed with this post 09-11-2012 at 08:30 PM
Old 09-11-2012, 09:09 PM   #43
WIthumper
The 610 guy
WIthumper's Avatar
Oddometer: 210
Those are hIgh beam pics. To give it perspective, the concrete slab on the side of the gravel driveway is 32 feet long.
WIthumper is offline   Reply With Quote
Old 09-12-2012, 07:30 AM   #44
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,041
Lights weigh 8oz.
PM Sent
Old 09-19-2012, 07:18 PM   #45
Baja Ho
Baja Ho's Avatar
Oddometer: 773
Still interested in this light, but am concerned about what oncoming drivers see. Sanjoh, could you provide a night picture of the low beam from oncoming traffic?
Times are GMT -7.   It's 01:01 PM.
