Old 01-13-2013, 05:42 PM   #31
Konflict Motorsports
KM TUNER
Konflict Motorsports's Avatar
Oddometer: 855
Vetmxr what do you weigh geared up? And how much luggage weight do you carry?
Konflict Motorsports & Suspension www.KonflictMotorsports.com
Konflict Motorsports is offline   Reply With Quote
Old 01-13-2013, 06:37 PM   #32
VetMXR
Oddometer: 71
220lbs fully geared minus luggage. I'm just looking for a ballpark for normal 50/50 riding.
VetMXR
VetMXR
2012 KTM 990 Adventure R
2007 CRF450X Plated (Dirt & Sumo)
1999 Vulcan Drifter 1500
http://www.advrider.com/forums/showthread.php?t=469494
VetMXR is offline   Reply With Quote
Old 01-13-2013, 06:55 PM   #33
Black Hills
Oddometer: 1,206
I'm 240 switch gear and had Superplush do a revolve and I stall .72's it work fantastic! Like a whole new bike on gravel
Black Hills is offline   Reply With Quote
Old 01-13-2013, 07:31 PM   #34
KM TUNER
Oddometer: 855
Pm sent vetmxr...
Old 01-13-2013, 08:04 PM   #35
FuTAnT
KTM 990ADV
FuTAnT's Avatar
Oddometer: 341
Originally Posted by syzygy9 View Post
I am struggling to see how an increase form the stock 0.48 to 0.70 is required. I had my own (2011 990 Adv) forks resprung to 0.56 with a revalve to suit - that's an ~17% increase in spring rate and it seems fine for my 85kg 'naked' + gear + load.
On a recent trip across Australia with lots of fast and slow dirt roads (and some really gnarly sections) I am not aware of ever bottoming the forks but did use all of the suspension travel. Front and rear were set to 'max payload'; with no load this setting feels quite stiff.
I am no suspension guru so happy to defer to the experts, but my understanding was that if you are using all of your travel and not bottoming, you're pretty close to the mark. Of course, if all you are doing is riding on smooth roads than compliance may not be your primary concern, rather things like fork dive under braking, and you can get away with much stiffer and less compliant forks.
I know where you are coming from. The traditional train of thought for pretty much all the 950/990 ADV was to put a set of anything from 0.54 to 0.58 kg/mm springs in with a revalve. However, there has been a bit of a shift and experimentation with putting in stiffer springs with alternative valving (putting in 0.58 kg/mm would also require a revalve of course). Think of it as a bit of a different path. I had mine with 0.56 I think, and while it was light and day better than stock, I still feel that it could have been stiffer, with the valving modified to suit to get it to move through the stroke nicely. They carry so much bloody weight over the front end, you can certainly jack up the spring weight.
If you were in the USA/Canada, I'm sure a call to SPS etc would give you an idea on the current train of thought and methodology in getting the most out of the ADV machines.
Cameron Corner - 6 Day Blast
FuTAnT is offline   Reply With Quote
Old 01-13-2013, 08:33 PM   #36
KTMADV
Hammer Down
KTMADV's Avatar
Oddometer: 174
The suspension that I run was installed by Moto Pro Suspension . Phone number 800-277-5089.
My bike is a 2007 ktm 990 adventure with ABS.
With all my gear Iam at 225 pounds.
If you use a 70 front spring it will not take up the square edge bumps. Make sure you get the right spring for the weight of the person plus there gear.
I run a Ultra Max Valving system with a mid valve kit with a 62 front spring and have never had any problems.
http://www.moto-pro.com/
Ceasar Vasquez
KTMADV screwed with this post 01-13-2013 at 08:54 PM
KTMADV is offline   Reply With Quote
Old 01-13-2013, 09:43 PM   #37
rossguzzi
990 Adv.
rossguzzi's Avatar
Oddometer: 996
Great thread this one.
My 03 950 Adv dives a fair bit under road riding. How can I tell what spring I have ? Is there markings on them ?
PO dosnt know.
Cheers.
rossguzzi is offline   Reply With Quote
Old 01-14-2013, 02:41 PM   #38
KM TUNER
Oddometer: 855
If you provide me with the ID, OD, diameter of wire, and number of active coils I can provide you with the spring rate.
Old 01-14-2013, 06:39 PM   #39
rossguzzi
990 Adv.
rossguzzi's Avatar
Oddometer: 996
Many thanks. It may be a few weeks before I can do it, bit I will.
Cheers.
Old 06-07-2013, 09:39 AM   #40
orange spy
diddly squat
Oddometer: 33
do you guys know of any European site that that carries varius spring rates for our specs?
a shipment from Supersplush will definetely cost me as much as the springs themselves
ty for any info
orange spy is offline   Reply With Quote
Old 06-07-2013, 10:48 AM   #41
woodchuckexc
Oddometer: 801
I'll chime in with my $.02 I really like my .64 SPS set up. I worked across the street from there shop for over a year and did a lot of testing on different set ups. .70 is great for spirited road rides of big hits off road but don't move as much as I like for smaller trail junk. Cheers!
woodchuckexc is offline   Reply With Quote
Old 06-07-2013, 11:38 AM   #42
jon6.0
jon6.0's Avatar
Oddometer: 546
ty for any info
If they ship it via US Post Office, it shouldn't be too bad. Call Slavens also. If they won't ship USPS, you can have them sent to my house and I will ship them USPS to you myself.
2013 KTM 690 Duke w/ performance cam, airbox, and Akrapovic full system. 300lbs and 74.5rwhp
2011 KTM 250XC with lots of protection stuff for when I bounce it down a hill.
jon6.0 is offline   Reply With Quote
Old 06-09-2013, 12:28 AM   #43
orange spy
diddly squat
Oddometer: 33
first of all, my respect for your offer.
second, its not the shipping charges that make it expensive. its the custom charges from U.S to Europe.
third I find it difficult to believe that there is no single shop, manufacturer, dealer that doesn't carry a 210mm spring in various rates in the whole E.U
is that true?
Old 06-09-2013, 12:35 AM   #44
Alex_RO OP
Wanderer
Alex_RO's Avatar
Oddometer: 206
I have no idea if it's the same in Greece as in Romania, but if the value of the package is under 100$ or marked as Gift... there's no customs fee. Paired with the offer from the fellow inmate from above...you may want to investigate that :)
I had a friend going to the US that gracefully accepted some extra hardware in his luggage on the return trip so i managed to avoid international shipping charges.
Alex
is that true?
Alex_RO screwed with this post 06-09-2013 at 12:43 AM
Alex_RO is offline   Reply With Quote
Old 02-18-2015, 10:34 PM   #45
2stroked
Oddometer: 86
Searching for info in spring rates I came across this so I guess I'm bringing this back from the dead.
I just got .70 for my 990, I'm 230 and that rate makes sense considering my Beta 400 had .50 and it weighed 275, not sure how KTM came up with .48's for a 475lb bike, I put .45 my Husky WR250 and it's 240lbs?
Can't wait to put these in and try it out.
08 KTM 990 Adv, 07 Husky WR 250
2stroked is offline   Reply With Quote
Times are GMT -7.   It's 08:03 AM.
