Go Back   ADVrider > Bikes > Battle Scooters
Old 08-29-2012, 10:38 PM   #1
crazyray OP
Oddometer: 4
Reflex Kmod vs. Dr. Pulley
Has anyone here had any experience comparing the performance characteristics between the Kmod and Dr. Pulley sliders? I'm sure the Dr. P will out perform the stock configuration. I am curious if the extra cost would be worth it when compared to the Kmod. If so, what is the perferred weight for around town driving (250cc). Thanks.
Ray
crazyray is offline   Reply With Quote
Old 08-30-2012, 12:09 AM   #2
kyhillbilly
kyhillbilly's Avatar
Oddometer: 133
I thought about trying the kmod on my morphous. Not sure it would work the same.
kyhillbilly is offline   Reply With Quote
Old 08-30-2012, 06:54 AM   #3
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 4,199
I did the K-Mod on my Reflex but have no experience with Dr. Pulley. The main attraction is the cost of the K-Mod (< $10 - you have to fab a tool to help remove the variator). I really like the way the scoot responds compared to stock.
There are some simple thruths......and dogs know what they are - Joseph Duemer
Andy holds the lead. And he will, all the way to the Highway. Today is his day.
Bronco638 is offline   Reply With Quote
Old 08-30-2012, 07:44 AM   #4
The PacRat
I'm that other guy
The PacRat's Avatar
Oddometer: 2,733
Try the K-Mod first - it really wakes the bike up. It's almost free and easily reversible.
If a hammer don't fix it, then it's an electrical problem.
The PacRat is offline   Reply With Quote
Old 08-30-2012, 08:10 AM   #5
HisMajesty400
Oddometer: 21
Alternative
Hi,
My wife has a Reflex. There is a third alternative for you... swap out part of the variator, plus Dr. Pulley Sliders. My wife and I were considering taking 2,000 mile plus trip, and I was concerned about the engine rpm at Freeway speeds.
First of all, for the Reflex... why it is doggy. It is my understanding that the Reflex was designed that way by the factory to reduced engine noise emissions for another market (not the US). It has 2 sets of rollers... 2 different kinds of ramps in the variator. The 2 different kinds of rollers have 2 different weights. The results of all of this is essentially shifting in high gear at around 30 mph or something.
There are disadvantages to Honda's design ... it accelerates slower, and I personally believe it allows the engine to spin faster at highway speeds (I suspect the belt is unable to travel all the way up the pulleys, essentially resulting in going down the road in a lower gear.
What I learned about, and ended up doing, is replacing the ramp side of the variator with a Big Ruckus' "B" face, and Dr. Pulley Sliders. The results were faster acceleration plus the Freeway rpms dropped around 1,000 rpm. I was pleased, pleased, pleased!
I haven't tried the K Mod; however, I suspect that the K Mod is faster, and it is free, and reversible. The Big Ruckus part, and the Sliders would cost around $100. The Big Ruckus mod is reversible too; just put the old parts back in.
Sorry, off hand I do not had the Dr. Pulley Slider weights. I believe the guy that gave me this idea is also a member on the ADV website, so he may stop in to chat, and give you that info.
HisMajesty400 is offline   Reply With Quote
Old 08-30-2012, 08:23 AM   #6
HisMajesty400
Oddometer: 21
I think what you would end up doing isn't exactly the K Mod. That would be Honda Reflex specific. However, what you are referring to would be taking out your rollers and putting in lighter ones, or putting Dr. Pulley Sliders in. The lighter rollers allows you, for example, to take off at 7,000 rpm instead of 6,000 rpm. The more engine hp at 7,000 rpm allows your scoot to accelerate faster.
Dr. Pulley Sliders are a great advantage. Their design allows you to use a lighter weight than stock, but still retain the original cruising speed. Because of the unique design, you have to experiment to get the weight you are happy with. You could find a Morphous forum and find out which weight they have discovered works best.
This is a fairly common mod that people do.
Old 08-30-2012, 08:31 AM   #7
kyhillbilly
Oddometer: 133
Thanks for the info!
Old 08-30-2012, 07:44 PM   #8
crazyray OP
Oddometer: 4
Oh yeah I've been running the K mod for about 2500 mi or so. For an easy free mod it works great. But as things wear out or need serviced, I like to have an idea of what I would like to go to next. I've heard the BR variator works well in the Reflex. I might give that a try in the near future. What weight sliders with the BR variator?
Old 08-31-2012, 04:04 AM   #9
scooterryder
Oddometer: 17
Reflex Kmod vs Dr. Pulley
Good information. My question is, where did you get the sliders and what weight did you choose?
scooterryder is offline   Reply With Quote
Old 08-31-2012, 06:53 PM   #10
bikeridermark
Oddometer: 2,387
I've got the Big Ruckus face b and 19gram dr. pulley sliders in both my Reflexes. I think it is a great compromise between stock and the k-mod.
I tried the k-mod first, way too many rpms for my riding style. I commute about seventy miles many days, two-thirds back roads.
I tried 21 gram sliders first, but like the acceleration with 19grams better. the highway rpms are nearly identical with both.
I have a few friends who use the big ruckus face b with six black Honda rollers ( 21 grams ). It works fairly well, but I still get them on take-off.
Dr. Pulley sliders can be found at buggyparts northwest. They charge five dollar flat rate shipping.
I get 70+ mpg when I ride 55-60 mph. slightly lower at 65-70 mph.
By the way, my '03 runs better that my '07 with same setup. Go figure.
bikeridermark is offline   Reply With Quote
Old 08-31-2012, 06:58 PM   #11
bikeridermark
Oddometer: 2,387
buggypartsnw.com is the website. I'm going to experiment with some modified sliders when i get time. I'll let you know the results. In the meantime, I'll enjoy my current setup.
Mark
Old 08-31-2012, 08:07 PM   #12
Warney
Warney's Avatar
Oddometer: 568
Here is a graph showing acceleration curves using different roller weights on a Big Ruckus. The info may be of benefit for Reflex experimenters especially if you change over to the BR drive face B.
http://totalruckus.com/phpBB3/viewto...p?f=28&t=58815
Warney is offline   Reply With Quote
Old 09-03-2012, 02:18 AM   #13
Cortez
BAZINGA!
Cortez's Avatar
Oddometer: 7,158
I'm sold on the Dr Pulley stuff since trying it in my scoot.
I think all scooters should come standard with these.
First I went 10% lighter then stock weights on stock CVT and got exactly
what was advertised. Some 1000 revs more at WOT (placing the revs at
exactly the maximum torque point) and 500 less at speeds above 60mph.
It made my scoot go 2 seconds faster to 60mph too (from 11 to 9 sec).
Next I got a Malossi Multivar which made the bike rev at maximum power
revs from zero to top speed, which was also increased a bit, but the engine
was screaming like mad. I went with 15% heavier Dr Pulley sliders in the
Malossi after that, and got about 500 revs less at WOT, and can still do
zero to top speed at same revs.
The malossi works great too.
I can even slide the rear end around now, and my scoot (30hp downtown
300) will beat a stock Tmax 500 from one set of the lights to another.
Dr Pulley + Multivar is expensive tho, and I'm thinking of going back to
just the stock CVT+Pulleys since it worked so well.
'08 Yamaha FZ6n S2 ABS
SOLD: '03 Peugeot Speedfight2, '07 Kawasaki ER6F ABS, '06 Kymco Agility 125, '12 Kymco Downtown 300i ABS
My Flickr gallery --- My 500px gallery
Cortez is offline   Reply With Quote
Old 09-15-2012, 09:32 PM   #14
scooterryder
Oddometer: 17
I tried the Kmod with 29 gram (stock white rollers plus 3 grams of lead). I did make the scooter faster off the line and reduced the engine speed at 55 mph about 500 rpm less than stock.
I have since installed the Big Rukus movable face and standard Big Rukus rollers. Acceleration from a stop is about the same as the stock Reflex setup, but at 5500 rpm I am cruising at just under an indicated 60 mph.
Times are GMT -7.   It's 02:57 AM.
