09-02-2012, 08:39 PM
#91 | |
prominent underachiever
wont work on this. theres about 1/8 turn free play, and full movement is about 180 degrees. I just have to get used to it.
the good thing is, that the stiff wire thru the bars also doubles as a cruise control, when I get it set where I want it :) Quote:
2011 Magadan (I hope!) (03 Harley 1200 Dirtster) 2010 Europe & the Middle East (75 Harley Bobber) 2009 Around the World ('62 Harley Chopper) 2008 Europe (TDM & Guzzi Falcone) 2007 Europe (TDM850) 2006 Around the World ('48 Indian Chief) 2005 Europe & N Africa (KLR650) 2004 Europe (KLR650) www.motosapiens.org My bike hotel in Bulgaria. ADVriders get 1st beer free! |
09-02-2012, 08:45 PM
#92 | |
Butler Maps
Oddometer: 14,427
Butler Maps - motorcycle maps for riders by riders - Ozarks , Nor Cal , COBDR shipping, AZBDR scouting http://www.advrider.com/forums/showthread.php?t=598717 Facebook: http://www.facebook.com/butlermaps |
09-02-2012, 09:28 PM
#93 |
Justan Nudderboomer
Oddometer: 109
Doug, love the special place designed into your spiffy luggage for your primary tool---The BFH. LMAO. Hope to say hello to you again at the Barber swap meet. Great adventure here.
09-03-2012, 01:20 AM
#94 |
Oddometer: 1,323
I read RTWDoug's road reports to remind myself how dependent I am on modern machinery to complete my rides. This notion of wrecking a piston and knowing someone who knows someone with "all the parts you need" is as lost an art in the 21st century as buggy whip making outside Amish country. Great fun to watch, with hat off and all the best wishes in the world.
http://www.keywestdiary.us |
09-03-2012, 12:15 PM
#95 |
Scooty Puff Sr.
Oddometer: 722
I love those saddlebags - who makes that whole luggage setup?
09-03-2012, 12:53 PM
#96 |
09-03-2012, 03:04 PM
#97 |
Oddometer: 86
Doug and an Indian
Im in. Have a nice one ( 01)
09-03-2012, 03:26 PM
#98 |
MACDADDY!
Oddometer: 395
Missed you in bull city, but I understand you had your own set of problems! It was a good turnout with lots of bikes, but hotter than hell!! Good luck on the rest of the way!
09-03-2012, 03:47 PM
#99 |
Oddometer: 78
Subscribed!
Good luck getting that old Indian back together! I hope to see you all in Wellsboro, Pa on Friday.
Dragon bound from Upstate NY Shake down cruise to the Adirondacks 2003 Honda ST1300 |
09-03-2012, 06:00 PM
#100 |
dont clutter up an indian thread with a bmw!
(nice R35!)
09-03-2012, 06:07 PM
#101 |
sigh-own
Oddometer: 2,761
good luck with the CB Doug...wish I could make it up to Cleveland or Sandusky to cheer you on as you ride by, but I'll be stuck at work.
Rock On!
I say, there's no such thing as a bad day's riding. -metaljockey whats the value of good gear?: http://www.advrider.com/forums/showp...ostcount=49301 |
09-03-2012, 07:34 PM
#102 |
MACDADDY!
Oddometer: 395
09-03-2012, 07:41 PM
#103 |
Gnarly something..
Oddometer: 446
Guess I missed you in VA and WV already. Man, I need to stay on top of your travels, Doug. You really do it the way it's supposed to be done and hopefully I'll get a chance to get a few miles with you or pick up a meal.
Civilization, in fact, grows more and more maudlin and hysterical; especially under democracy it tends to degenerate into a mere combat of crazes; the whole aim of practical politics is to keep the populace alarmed (and hence clamorous to be led to safety) by an endless series of hobgoblins, most of them imaginary. HL Mencken |
09-03-2012, 08:46 PM
#104 |
If I dont get outta here soon, I'm gonna have to change the name of this thread to
dickin around in steve's garage....... So I got the bike up on the lift at Steves, his sons Justin & Jared also helped ![]() the jug was pretty rough looking inside. there were aluminum buttons holding the piston pin in place. one was about 1/3 gone, the other was totally gone! it had turned into the aluminum coating on the cyl wall & piston ![]() We dug around in Steves parts, & found another 101 cyl, some fins had been repaired, but inside was fine. I cut/gapped some .050 rings to go in it, since they were a little bigger, they will have more tension against the wall. ![]() the piston was a bit stuck on the pin, so I made a puller out of some allthread & a piece of pipe ![]() the pin bushing had become a little loose, so we knurled it & put some locktite on it ![]() after cutting seats & lapping the valves, the new cylinder was ready to go on ![]() steve checks it over ![]() then we bored out my old cylinder, to see if it would be usable ![]() we went from +030 to +060, it didnt clean up perfect, but we both deemed it as a suitable spare ![]() I flushed the bottom end out with kerosene to try to wash out the extra bits. ![]() ![]() ![]() after flushing it 5 times, it was pretty clean (I ran the drain thru the paper towels to see what came out) so I installed the new cylinder ![]() and we adjusted the oil flow to be 'extra wet' and I can adjust it down from there. It was definately a 'not enough oil' problem. Odd, because the bike has always been fine. when I redid the motor, I didnt touch any of the settings, and thought that would be ok. seems I was wrong..... and then took it outside to start it up. I kicked it... whoosh-clunk-woosh-clunk..... hmmmm Steve looks at me & starts cussing. when he pulled the piston out of the box, he thought it was an original. nope, its a hi compression bonneville piston for racing, and its too tall, & hits the head. it should be level with the cylinder top.... oops! ![]() No biggie, I tell Steve that when we do something like this in Bama, we just say we were doing a 'test fitting' So, piston replacement, part 2.... ![]() you can see the height difference here.... ![]() so got it all back together & rode it a little bit, but it wasnt running great. Seems like the intake manifold is leaking, so I sealed it with some silicone, & will let it cure overnight. While I'm watching silicone harden, I thought I'd wash some clothes. I'm not used to these new fangled west virginia washing machines, but at least he has a modern electric one!
2011 Magadan (I hope!) (03 Harley 1200 Dirtster) 2010 Europe & the Middle East (75 Harley Bobber) 2009 Around the World ('62 Harley Chopper) 2008 Europe (TDM & Guzzi Falcone) 2007 Europe (TDM850) 2006 Around the World ('48 Indian Chief) 2005 Europe & N Africa (KLR650) 2004 Europe (KLR650) www.motosapiens.org My bike hotel in Bulgaria. ADVriders get 1st beer free! rtwdoug screwed with this post 09-03-2012 at 08:56 PM |
09-03-2012, 08:52 PM
#105 |
Yeah! I want Cheesy Poofs
Oddometer: 17,774
Go Doug Go!
Tomorrow. |
