Old 08-30-2012, 06:35 PM   #16
NeedaSpace7 OP
Oddometer: 21
well i got 2 boxes in . hopefully the rest will be here tomorrow 8/31 or tuesday.
NeedaSpace7 is offline   Reply With Quote
Old 08-31-2012, 07:07 AM   #17
gmtech
Oddometer: 64
yea the head light it looks like it mounts exactly like the wr250r and it looks alot better
i priced out shroud and light housing
126 for the light houseing and 19 for shroud the housing even tho sounds expensive is cheaper than the stock wr250r heaqdlamp
thanks! now make that thing streat legal!
gmtech is offline   Reply With Quote
Old 08-31-2012, 09:14 AM   #18
NeedaSpace7 OP
Oddometer: 21
If you go through with it post pics , I would like to see the end result!
And only thing holding me back is shipping delays :mad:
Old 08-31-2012, 09:19 AM   #19
ecarnell
ecarnell's Avatar
Oddometer: 394
For a little bit more you can get a
Much better light and looks (IMO) - 7" H4 (with optional 80/100w bulb).
2014 KTM 500 EXC
2011 KLR
2012 Dacre Challenge -Team Explore the Bruce - 8th (i.e last) Place. 17:59
ecarnell screwed with this post 08-31-2012 at 09:48 AM
ecarnell is offline   Reply With Quote
Old 08-31-2012, 11:23 AM   #20
NeedaSpace7 OP
Oddometer: 21
Good call! Personally , I don't like the headlight on my wr450. Maybe it will grow on me . I've always loved the look of the big round "baja" style lights
Old 08-31-2012, 12:10 PM   #21
NeedaSpace7 OP
Oddometer: 21
well , i got home from school with an hour to spare before work, so i rode for about 30 minutes when i noticed some one had left me some presents on the doorstep!
so now i have everything , and we can begin! well, kinda. i forgot to order the front hydraulic brake switch, and it should be here tuesday, or maybe later today? oh well. not a problem, i can go on with out it for now ! any guesses as to what's in the big box ?
NeedaSpace7 screwed with this post 08-31-2012 at 12:16 PM
Old 08-31-2012, 12:31 PM   #22
NeedaSpace7 OP
Oddometer: 21
so first thing i bought/ screwed with, was the 12 o'clock labs processor chip:
that goes into the DRC edge 2 taillight , replacing the old board:
now, im not really going to go into this , because the instruction manual that came with board, was extremely well put together, i am very impressed by it. i did however have trouble with two things: 1: the three screws on the back, just wanted to strip. which was also mentioned in the installation book :
and 2 , once you install the chip, the wires are such a pain to feed through this tube! however the instruction booklet gives you a couple of options how to do it.
so the board that I installed into the tail light, makes the tail light brighter , and has integrated turn signals, and has a brake light flasher ability. and o yea, ignore my pants in the last pic, im doing all this in my room
Old 08-31-2012, 12:34 PM   #23
NeedaSpace7 OP
Oddometer: 21
also bought , was a drc edge universal mounting kit :
and it looks like it should use the stock tail light mounting holes , so no drilling.....or at least im hoping
Old 08-31-2012, 02:50 PM   #24
Keith
Slabbing it
Keith's Avatar
Oddometer: 908
Sweet, keep it up.
Random Crap
Keith is offline   Reply With Quote
Old 09-01-2012, 03:58 AM   #25
oldgezzer
Country Rider
oldgezzer's Avatar
Oddometer: 39
Keep the ideas coming.....I'm all in.
oldgezzer is offline   Reply With Quote
Old 09-01-2012, 11:21 AM   #26
NeedaSpace7 OP
Oddometer: 21
Originally Posted by Keith View Post
Sweet, keep it up.
good to know someone is interested!
on another note, i cant keep the front down !
also looked what showed up on a saturday?! the final piece to the puzzle. now we can get rolling. (hydraulic pressure switch for front brake)
Old 09-03-2012, 06:53 PM   #27
123honus
Oddometer: 3
I have a bew WR450 coming.
Anxious to see how your process goes. Mine will start next week.
We do not need signal lights, so hopefully I will have a little less to do.
Does the existing tail lite have a two filiment bulb? Could you have used it?
If so what would you do for a license plate holder?
Does the existing head lite have a hi/ low filiment? Will you use it or modify it?
Why are you installing the front banjo bolt brake switch, and not the rear. or are you doing both?
Anyhow thanks for posting your progress. You made a wise choice.
123honus is offline   Reply With Quote
Old 09-06-2012, 05:11 PM   #28
NeedaSpace7 OP
Oddometer: 21
yes is it does. yes i could have. not sure about the license plate holder. id probably mount it like this
i will be using the stock headlight, it does have High /low filament. also one thing i noticed , the headlight is very easily adjusted. apply some pressure to the top or bottom and it pivots !
ill be doing both. i bought a manual switch for the back, but the hydraulic switch is such an easy install im goin to return the manual switch and get a hydraulic one
[QUOTEAnyhow thanks for posting your progress. You made a wise choice][/QUOTE]
i hope so !
as for not updating this thread, i have been really busy. but hopefully tomorrow after school i will update you all !
Old 09-08-2012, 11:27 AM   #29
mt21
mt21's Avatar
Oddometer: 49
Great lookin bike!
Keep up the good work!
What is the stator output on the new WR ??
mt21 is offline   Reply With Quote
Old 09-08-2012, 12:12 PM   #30
Mikef5000
Oddometer: 2,030
160 watts.
I'm keeping my eyes on this thread, keep up the good work. I desperately would like to see a WR450R in the near future, but I may look into going this route (down the road) if they don't deliver what we the people have been asking for.
2008 990 Adventure
2008 WR250R
www.Mikef5000.com
Mikef5000 is offline   Reply With Quote
Times are GMT -7.   It's 08:30 AM.
