Old 09-01-2012, 03:35 PM   #1
bigmd OP
Oddometer: 66
front end help
hey guys been working on my 82 cb450 for the past few months and like all my projects it has spiraled out of control.after snapping a bolt in my freshly powdered upper triple tree and had to purchase another one from ebay.i bought the complete upper and lower for the same year cb.when i got it i wasnt just able to use the upper because it was slightly narrower then the one that came on the bike.so both the new upper and lower are at the powdercoaters.my question is since the new clamps are slightly narrower is that gonna throw everything off when it comes to mounting the wheel and lining up the brake?if i have to i will get rid of the sppedo cable gear.
bigmd is offline   Reply With Quote
Old 09-01-2012, 06:21 PM   #2
thomas.tc.young
Oddometer: 858
Unless your hitting the ton I wouldn't worry about it too much. Tube blowouts and other old bike problems should be higher on the list of other things to worry about
1969 CL350 permanent project
2013 Ninja 650
1987 XR600R
2001 TTR-125L
the klr/versys project: http://advrider.com/forums/showthread.php?t=810279
thomas.tc.young is offline   Reply With Quote
Old 09-02-2012, 12:57 AM   #3
chollo9
Screwed the Pooch
chollo9's Avatar
Oddometer: 1,549
How much is slightly? 5mm? 10? You're going to have to make up for the difference somewhere down below or the wheel won't fit. Ideally, i.e., correctly, you should take half of the total from each side to keep the wheel centered, so half from the speedo drive and half from the spacer on the opposite side. Having said that, there are plenty of bikes running around with wheels that aren't lined up. Bottom line though, the total width of the hub with spacers etc. has to match the distance between the fork sliders--you can't spread or squeeze 'em or the forks won't stroke smoothly.
"It's not that I don't like people...I just find I am happier when they're not around"
chollo9 is offline   Reply With Quote
Old 09-02-2012, 11:44 AM   #4
anonny
What could go wrong?
anonny's Avatar
Oddometer: 5,583
You could probably make up the difference by altering
1) the nut length that the axle mates to
2) take that amount off the speedo drive (you have 2 sides on this to work with)
How much difference is there?
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is offline   Reply With Quote
Old 09-03-2012, 07:17 AM   #5
bigmd OP
Oddometer: 66
thanks for the responses guys.the difference is maybe 1/4 of inch from what i recall.i just tried them out quickly before i took to powder coater.the removal of the sppedo drive gear seems like the easy way to go.can you guys recommend where to get some spacers?
Old 09-03-2012, 08:36 AM   #6
RedRaptor22
Oddometer: 155
I know there is some website people use here that sells nothing but spacers, never been to it myself but with google it should'nt be too hard to find.
RedRaptor22 is offline   Reply With Quote
Old 09-03-2012, 12:46 PM   #7
anonny
anonny's Avatar
Oddometer: 5,583
Aluminum pipe cut to length?
Old 09-04-2012, 03:34 AM   #8
bigmd OP
Oddometer: 66
yeah that might work,thanks
Old 09-13-2012, 09:02 AM   #9
bigmd OP
Oddometer: 66
ok guys thanks for help turns out im an idiot and the triples were the same size.everything fit together nicely.next question is i want to replace frayed speedo cable with something a little shorter.the tach cable i removed is the perfect size.can it be used,when i look online they sell separate cables for speedo and tach so im assuming theres a difference,they do look the same though.
Old 09-13-2012, 09:52 PM   #10
anonny
anonny's Avatar
Oddometer: 5,583
If the tach cable ends screw on to the speedo and speedo drive your 1/2 way home, now all you have to do is measure the inner cables drives and ensure they are the same.
Old 09-14-2012, 11:36 AM   #11
bigmd OP
Oddometer: 66
Thanks I checked them and they are identical so I went ahead and ordered the shorter cable.
Times are GMT -7.   It's 07:28 PM.
