Old 09-01-2012, 08:21 PM   #1
victor441 OP
victor441's Avatar
Oddometer: 931
DIY tire mounting fixture...
made this from a cut down bucket, a piece of plywood, a length of angle iron, and some 5/8" threaded rod (plus some nuts, bolts, washers, etc)......the tire change was waaaay easier with the wheel clamped down and at waist level.
victor441 is offline   Reply With Quote
Old 09-02-2012, 12:09 PM   #2
vtwin
Air cooled runnin' mon
vtwin's Avatar
Oddometer: 7,394
Hmmm, since your in the neighborhood, I may have to borrow that from time to time.
"Alles hat ein Ende--nur die Wurst, sie hat zwei"
Monroe.
"You only have too much fuel if you're on fire"
unknown
vtwin is offline   Reply With Quote
Old 09-02-2012, 05:08 PM   #3
victor441 OP
victor441's Avatar
Oddometer: 931
no problem, it is in Santa Rosa and Guinness is accepted for rental payment .....actually it would probably be cheaper to make one from crap you have laying around
victor441 screwed with this post 09-02-2012 at 10:05 PM
Old 09-02-2012, 05:27 PM   #4
marine_mike
Oddometer: 315
Can you do a write up on this?
marine_mike is offline   Reply With Quote
Old 09-02-2012, 09:59 PM   #5
victor441 OP
victor441's Avatar
Oddometer: 931
sure, here are a couple of pictures....got the idea from similar stands built from steel car wheels but wanted something smaller, lighter, and that could be clamped in a vice. Cut the top off of a heavy duty bucket, cut a hole in the plywood to match, four screws to attach the bucket to that, three holes in the angle iron, 5/8" threaded rod for the post, two nuts to attach the post to the angle iron and a wingnut to hold the wheel down. A 3/4" drive socket worked well between the wingnut and the hub to clamp down on the outside of the wheel bearing.
Old 09-03-2012, 02:13 PM   #6
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,632
Looks good. And because you got the idea from a car wheel, I just gave a friend of mine one of them space saver spares, just the right size with the tire still mounted, now he is busy finishing his tire machine. He sure has more room than me in his shop.....I think I'll make one like yours.
Have tools, will travel!
Old 09-03-2012, 07:24 PM   #7
BluByU
BluByU's Avatar
Oddometer: 497
Sooo simple, Thanks for the pics,
I will be making one this coming week (new tires are due in in a few days)
BluByU is offline   Reply With Quote
Old 09-04-2012, 11:41 AM   #8
Flashmo
Whatever...
Flashmo's Avatar
Oddometer: 2,583
I've always changed mine with the wheel resting on a 5 gal bucket, or a couple 2x4's on edge. I really like the simplicity and what looks to be effectiveness of your fixture though...may have to make one for myself.
Flashmo is offline   Reply With Quote
Old 09-27-2012, 10:41 AM   #9
JAB
Unsprung Weight
JAB's Avatar
Oddometer: 1,245
How is the stability of your tire changer on the Jawhorse? Love the idea, but I have the HF changer and a Jawhorse. I never set the HF it up because I don't have a good place to bolt it to, but the Jawhorse idea is great if will hold still.
1991 Honda XR628R
1978 Yamaha XT500
JAB is offline   Reply With Quote
Old 09-27-2012, 01:01 PM   #10
victor441 OP
victor441's Avatar
Oddometer: 931
It is good enough in the Jawhorse however it will move if enough pressure is applied, but have mounted two tires so far without trouble....the zip tie method (learned it from another thread here http://advrider.com/forums/showthread.php?t=299597) helps as very little force is required to mount the tire. It is really solid in my bench vise but I like to work outdoors when I can. BTW, I have a HF balancer and that works great in the Jawhorse.
victor441 screwed with this post 10-12-2012 at 11:11 AM
Times are GMT -7.   It's 05:08 AM.
