Old 02-20-2013, 06:07 PM   #466
PineyMountainRacing
Oops....
PineyMountainRacing's Avatar
Oddometer: 2,204
Originally Posted by Slideways#96 View Post
Put me down for tool and adaptors.
Thx
You're already down for a set, do you want a second set?
PineyMountainRacing is offline   Reply With Quote
Old 02-20-2013, 06:42 PM   #467
Slideways#96
scooter trash
Slideways#96's Avatar
Oddometer: 539
Nope, just the one set.
Slideways#96 is offline   Reply With Quote
Old 02-21-2013, 01:27 PM   #468
knobbyjoe
knobbyjoe
knobbyjoe's Avatar
Oddometer: 510
Worked!
Tool Report: Standard no adapter.
Changed out Mefo's for Dunlop 906 front (21”)and 908 back (18”) on KTM Adv 990.
The back tire went on as advertised. The tool worked very well and had the tire on in record time.
The Front had some issues. Front tire is 21" and the length of the tool needs to be 1/2" to 1" longer! Also the axle is a larger diameter than the back. The tool fit in sloppy. So need an adapter. I used the sloppy fit to my advantage and shimmed the tool about 1/4" in the axle so that I got a longer reach. That was just barely enough length to push the tire onto the rim.
Conclusion: This tool is great except...for 21 inch front rims the tool needs to be about 1/2 inch longer. Why the tool maker kept it this short is a wonder. When I get around to it I will extend the tool about an inch with a welded in piece. Think I'll go 1" longer.
I do recommend this tool as it makes a beastly spoon job into a “Watch this” simple and easy job. KJ
KTM 400 XCRW with Thumper Racing 450 kit and 450 cam 2007
KTM 450 XCRW with Christini AWD and Plated 2008 now has 520 Thumper Racing kit
KTM 990 Adventure 2008
knobbyjoe screwed with this post 02-21-2013 at 01:34 PM Reason: baad speler
knobbyjoe is offline   Reply With Quote
Old 02-21-2013, 03:48 PM   #469
PineyMountainRacing
Oops....
Oddometer: 2,204
I've changed a couple rears and did a 19" front, it looked to me like there was enough tool to do a 21, but maybe not. Since it's geared to dirtbikes, I'd think 21's would be a given. I'll have to look at it again tomorrow.
Old 02-22-2013, 06:41 AM   #470
PineyMountainRacing
Oops....
Oddometer: 2,204
I sent an email to Are regarding pricing and availabilty, want to start finalizing our order next week - PMR
Old 02-22-2013, 07:37 AM   #471
knobbyjoe
knobbyjoe
knobbyjoe's Avatar
Oddometer: 510
PMR,
Will you ask Are about the tool's length. I'm thinking that the short length is so it will fit small tires, like kid bikes etc.
kj
Old 02-22-2013, 08:21 AM   #472
PineyMountainRacing
Oops....
Oddometer: 2,204
PMR,
kj
he does make and sell a shorter bar, for like mini-bikes and scooters. when he gets back to me I'll ask about the 21's, & I may just play with one this weekend
Old 02-22-2013, 08:36 AM   #473
Bonerov
Damned dirty ape
Bonerov's Avatar
Oddometer: 424
Bonerov is offline   Reply With Quote
Old 02-22-2013, 09:44 AM   #474
foxtrapper
Oddometer: 752
As long as you're asking, I've got a 23" tire on one bike. An extra-long model could be of interest to me.
foxtrapper is offline   Reply With Quote
Old 02-22-2013, 06:27 PM   #475
HeatXfer
Bad knees
HeatXfer's Avatar
Oddometer: 638
Thank you PMR.
I'm in no hurry, whenever the deal goes through I'll be ready.
HeatXfer is online now   Reply With Quote
Old 02-23-2013, 05:17 AM   #476
75bronco
Oddometer: 322
making sure i'm on the list. I sent you a PM some time ago. Thanks bill
75bronco is offline   Reply With Quote
Old 02-23-2013, 06:02 AM   #477
GSteve
GSteve's Avatar
Oddometer: 1,285
I'll take one also, plus both adapters. If it's determined that a longer one is available, that's the one I prefer. Thanks!
Steve
Little Rock, AR
GSteve is offline   Reply With Quote
Old 02-23-2013, 07:12 PM   #478
gspdbill
noobie allover again
Oddometer: 404
I'm going to cancel my request (I'm # 6 on your list IIRC) for the tool. Someone else can take my slot.
Thanks.
Bill
'05 R1200GS for now......
gspdbill is offline   Reply With Quote
Old 02-23-2013, 08:37 PM   #479
seniorasi
Oddometer: 816
Put me down for the tool...not certain what I need for a 2012 GSA. Where do I send the PP?
seniorasi is offline   Reply With Quote
Old 02-24-2013, 04:54 AM   #480
PineyMountainRacing
Oops....
Oddometer: 2,204
I have you down for the tool, as well as both adapters. He offers the shorter rod, I will ask about a longer one. I'm going to mess around with a 21" rim today and see how much longer the tool arm needs to be. Because of the different countries, language barriers, delay in communication, etc., it's not like I can just ring him up and ask him a simple question. In fact, I have never spoke with him. usually it's a few days before he responds, but I'll let you know.
Thanks.
appreciate the heads up
Got you down for a tool, safest thing to do would be to measure the diameter of your axles. The tool, or adapter can be a little smaller than the ID of your bearings, but the more "slop" you have, the easier it is for the tool to slip. And you can always shim your rod up with something, you don't actually need the specific adapter (YMMV) - but the adapters are pretty cheap...
Times are GMT -7.   It's 03:36 PM.
