Old 09-03-2012, 07:17 AM   #1
rdltmc3 OP
Oddometer: 15
flooding help 78 gl1000
cleaned and set the carbs MULTIPLE times already all new rings and gaskets i even polished up the intake to try and make her happy but still the same thing. any suggetsions?
1st video running fine with petcock off and the second is with it turned on.
Originally Posted by Rdltmc3
http://i111.photobucket.com/albums/n131/RDLTMC3/96F11F86-2F70-4C64-B8DF-6B38343D38EB-8244-00000D0E7147CEC7.mp4
http://i111.photobucket.com/albums/n...0E3E840BCB.mp4
rdltmc3 is offline   Reply With Quote
Old 09-04-2012, 07:18 PM   #2
adiablolex
Lost again
adiablolex's Avatar
Oddometer: 3,531
is your fuel clean?
I'm hunting a similar ghost in my 79 and it seems to be pointing that way
I had the tank cleaned up before but I think some of the rusty fuzz remained so I'll have to pull it out along with the carbs....again......
DRCOOL rides with me
adiablolex is offline   Reply With Quote
Old 09-05-2012, 05:13 AM   #3
DRTT
Oddometer: 12
Sounds like the float valves are sticky or worn, my money is on worn......
good luck,
Paddy
DRTT is offline   Reply With Quote
Old 09-05-2012, 12:51 PM   #4
hugemoth
hugemoth's Avatar
Oddometer: 2,078
It's been a few years since I sold my 79 but I did go through the carbs. The video shows a lot of fuel in the intake box, more than would come from a stuck float needle. Gas from a stuck needle would run into the cylinder, not up into the intake box. Is there some kind of fuel passageway through the intake box that is missing an O ring?
Old 09-08-2012, 05:58 PM   #5
mike in idaho
mike in idaho's Avatar
Oddometer: 67
Did you change the plenum gasket(big o-ring) between the two halves?
'68 TR6R
'69 T100R
'69 T120R
'72 Commando 750
My company car is a Kenworth
mike in idaho is offline   Reply With Quote
Old 09-08-2012, 10:09 PM   #6
dilandau
dilandau's Avatar
Oddometer: 584
fuel can run into the intake box from a stuck float valve needle - did on my fz. Its going into the cylinder sure, but its getting spit back out as well.
sometimes you just got to clean your carbs like 20 times. But yeah, take off your floats, take out the needle valves. Should have a nice clean cone on the top. Then take out the casing that holds the needle- and clean that- you got to get all the crud off the inside. Make it shine. The crud in there will keep the valve from seating.
and of course check your float height- on my recent purchase the guy had set them like 4mm off. So don't take it on faith! Get the correct specs and set it.
good luck. Man I just spent a week on a set of carbs- and feel your pain.
try using pinesol
morini 3.5 strada & sport, fz600, 74 eldo
dilandau is offline   Reply With Quote
Old 03-01-2013, 09:29 AM   #7
Andyvh1959
Cheesehead Klompen
Andyvh1959's Avatar
Oddometer: 125
And don't froget the seals on the bottom of the fuel enrichener plungers (what some call the choke). That seal can dry out and crack, and allow raw fuel right from the float bowl into the venturi. Enough to foul a new set of plugs in 50 miles, AND contaminate the oil.
If that seal is bad, as happened on my 78 GS1000, NO amount of jetting changes or float setting changes can compensate.
When life throws you a curve,.....lean into it!
Andyvh1959 is offline   Reply With Quote
Old 03-01-2013, 09:44 AM   #8
hugemoth
hugemoth's Avatar
Oddometer: 2,078
The old Goldwings just have choke plates rather than an enrichment circuit.
Old 03-01-2013, 09:50 AM   #9
Juanjo_NY
Made in Argentina
Juanjo_NY's Avatar
Oddometer: 2,873
Send a message via Skype™ to Juanjo_NY
check the points behind the left cylinder!
cheers, Juanjo
Juanjo_NY is offline   Reply With Quote
Old 03-04-2013, 12:15 PM   #10
bmwhacker
Still on 3 wheels
bmwhacker's Avatar
Oddometer: 3,382
GL 1000 mystery's!
I'm still struggling with a right side exhaust "pop"....driving me nuts.
Changed the copper exhaust gaskets, removed / checked the "air cut-off valve, checked exhaust valve settings, performed compression test. Can't find a darned thing wrong anywhere. Not sure what else to check????????????
http://jupiterhack.blogspot.com
Living proof you shouldn't play with matches
Old 03-04-2013, 01:01 PM   #11
hugemoth
hugemoth's Avatar
Oddometer: 2,078
Trying to remember if the petcock has a vacuum hose going to one of the right hand carbs. People often disable the vacuum petcock and sometimes forget to plug off the vacuum line.
Originally Posted by bmwhacker View Post
GL 1000 mystery's!
Old 03-04-2013, 01:14 PM   #12
SloMo228
World Class Cheapass
Oddometer: 258
I've rebuilt a couple GL1000 carb racks. They are a pain in the ass when something goes wrong because there is a lot going on and it can be tough to pinpoint the actual cause.
For flooding like you're talking about, the most likely causes are:
1. Stuck floats
2. Bad float needles
3. Failed plenum gasket
4. Failed floats
5. Float height set wrong
#1 you can check fairly easily by rapping on the side of the float bowl with a screwdriver handle. If a float is stuck, it should come loose. They get gummed up with varnish fairly easily on these carbs.
#2 is a common problem with these carb. The float needles have a rubber coating on the tip that can wear and cause leakage. You can check by pulling the needle and inspecting it closely. If the needle is worn out, there will be a line around the tip. Replace them and you're good to go. I would definitely use OEM needles, though - there have been several reports of aftermarket needles not sealing properly even when new.
#3 is pretty common, too. Split the plenum and inspect the gasket. Some aftermarket gaskets are susceptible to the ethanol in modern fuels and can fail prematurely. Usually they swell and block off the fuel passages in the plenum too.
#4 happens sometimes and can cause flooding too. The floats are hollow and occasionally fail, allowing the float to fill with fuel - it's not a "float" anymore when this happens and it won't rise to close the needle valve.
#5 would be the best case scenario since you don't have to buy anything to fix it. Use a caliper to check the float height. I don't recall the proper height off the top of my head, but it will be in the service manual.
Those are the things I'd check first.
- Steve
GL1000 x2
GL1500
DR350
SloMo228 is offline   Reply With Quote
Times are GMT -7.   It's 12:55 PM.
