Old 06-06-2011, 11:12 PM   #61
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,878
The optical device...
Originally Posted by Dr_Bean View Post
IF the optical detection fails completely (e.g. because the optics are to dirty)...
I believe the "optical" sensor is using infrared signal and so is not blocked from dust (mud). I think the normal death of these pumps (excluding flooding with salt water or mud) would come either from rupture of the membrane or from Mosfet death that is probably operating the switching. I wonder how long is the life of these two components.
gefr screwed with this post 09-13-2011 at 02:28 AM
Old 06-06-2011, 11:46 PM   #62
cpmodem
Orange Caveman
cpmodem's Avatar
Location: masa yee yah tee 59° 14' 9" N / 135° 26' 42" W
Oddometer: 7,103
Take some pictures Jeff...
Please
-cp
DISCLAIMER: All observations made in this post are mine and based solely on my own anecdotal experiences, and may contain large doses of facetiousness. YMMV, of course. You are "on your own", and I take no responsibility if someone tries anything in this post and gets into trouble with the law, damages their person or property, or goes blind. Take everything you read or hear "anywhere" butt especially on the Web with a large dose of salt.
cpmodem is offline   Reply With Quote
Old 06-07-2011, 11:57 AM   #63
Dr_Bean OP
Dr_Bean
Oddometer: 105
Originally Posted by gefr View Post
I believe the "optical" sensor is using ultrared signal and so is not blocked from dust (mud). I think the normal death of these pumps (excluding flooding with salt water or mud) would come either from rupture of the membrane or from Mosfet death that is probably operating the switching. I wonder how long is the life of these two components.
Well.. you are correct, but mud is mud.. when there is enough mud, it will be blocked :-) (but then you just rinse it... np)
I haven't seen any membrane rupture. Old pumps (>50tkm) do sometimes pump a little less volume (membrane/valves do not close perfectly), but since the pump is about 3x oversized, that will not be a problem.
pomp-bearings wear! (the rod gets clearance)
I have seen the pump rod getting stuck from corrosion.
Mosfet has a 10 years lifespan in normal use... and that is how it is designed.
ps.: The mechanical switch (contact breakers) does actually do a great job: MTBF is around 3'000'000 switches (which is quite good for a mechanical switch switching a 8 Amp inductive load)... But: If the pump switches around 1x per second that still means after 1000h it is done... 1000 h is 50tkm / 30t miles and that is just not enough! (so failure by design)
Losses in the mosfet are negligible, so it doesn't heat (proper switching, the correct fet).
The only heat comes from the pump itself and the engine. basically the whole pump should not get over 90 C (~200F): then there are no problems for sure.
I also use the pump for Honda Africa-Twin, Transalp and Varadero: There the pump is mounted behind the cylinder... hence running a lot hotter: No problems there.
From my design I think the LED from the optical detection is the most critical part.
But hey.. what is the real 'operating time' on a bike: 100'000 kms is about 2000 hours : thats peanuts for electronics.
Dr_Bean is offline   Reply With Quote
Old 06-08-2011, 12:48 AM   #64
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,878
The membrane.
I have seen mechanical fuel pumps on cars getting their membrane torn at high milliages, that is why I brought this up. I refer to big milliage of 150k kms. I believe your device is pushing reliability to this kind of milliage. Thnx for that.
Cheers.
gefr screwed with this post 06-09-2011 at 03:56 AM
Old 06-08-2011, 12:57 PM   #65
Dr_Bean OP
Dr_Bean
Oddometer: 105
I have seen mechanical fuel pumps on cars getting thei membrane torn at high milliages, that is why I brought up this. I am talking for milliage of 150k kms. I believe your device is pusshing reliability to this kind of milliage. Thnx for that.
Cheers.
Ah thanks for the confidence on that !
I don't give 300'000km warranty, but if you make that with your 950, you get a free kit from me (If it is still available)
Old 06-08-2011, 04:40 PM   #66
ktm950se
ktm950se's Avatar
Oddometer: 1,385
'Received my kit in the mail today!
ktm950se
ktm950se is offline   Reply With Quote
Old 06-09-2011, 01:15 PM   #67
Dr_Bean OP
Dr_Bean
Oddometer: 105
Great !
For all from USA ... I am not going to send mail, chase you, etc.
If you want a kit, you send a forum PM to me. I will reply on that only.
Old 06-09-2011, 03:04 PM   #68
Modder
Modder's Avatar
Oddometer: 17
Thumb
I replaced the melted points on an old 950 fuel pump with the optical solution from Dr Bean. An easy enough job thanks to the clear instructions.
The pump has been working flawlessly for thousends of km's.
I shrink bikes
Modder is offline   Reply With Quote
Old 06-12-2011, 07:48 AM   #69
ktm950se
ktm950se's Avatar
Oddometer: 1,385
Originally Posted by crazybrit View Post
Gerben: about 1/2 way through improving the English instructions, try and finish tomorrow and I'll e-mail you them.
Greetings CB,
Did you complete the English instructions?
If so, would you mind posting them or sending them to me?
ktm950se
Old 06-12-2011, 08:39 AM   #70
crazybrit
crazybrit's Avatar
Oddometer: 8,553
Originally Posted by ktm950se View Post
Greetings CB,
ktm950se
There are already English instructions. I was just polishing them as English isn't his 1st language. I got sidetracked. Do you have Dr.Beans version?
crazybrit is offline   Reply With Quote
Old 06-12-2011, 10:11 AM   #71
ktm950se
ktm950se's Avatar
Oddometer: 1,385
Yes, I do. Is there anything in particular that you felt could be described more clearly after having installed his kit?
ktm950se
Old 06-13-2011, 11:12 AM   #72
Pax
shazam.
Pax's Avatar
Oddometer: 812
Received!
I received my Dr. Bean pump by normal post. There was green custom's tape on the outside informing me that it had been opened and inspected. Everything looked good and was inside. Sometime in the next few months I'll get around to installing it.
Thanks Doc!
See ya,
Pax
Pop & Pax - West TAT 2009
The Dean of Adventure Routes
“Character is much easier kept than recovered.” –Thomas Paine
Pax is offline   Reply With Quote
Old 06-13-2011, 01:41 PM   #73
Dr_Bean OP
Dr_Bean
Oddometer: 105
AH, thanks for the feedback:
Looks like they have no trouble with it, thats good to see.
Thanks Doc!
See ya,
Pax
Old 06-16-2011, 01:39 PM   #74
Grundy
Oddometer: 96
Got mine too!!
Took 6 days from the Netherlands. Customs green sticker included. looks like a quality product, even included solder. Thanks Dr.
Grundy is offline   Reply With Quote
Old 06-18-2011, 04:38 PM   #75
cpmodem
Orange Caveman
cpmodem's Avatar
Oddometer: 7,103
Just checked the mailbox and my circuit kit was waiting for me. No indication of the envelope being opened by anyone before me. I'm installing it this afternoon and will document with photo images. Thanks for the hard work and consideration on your part, Doc.
-cp
Times are GMT -7.   It's 03:03 AM.
