Old 07-27-2011, 05:18 PM   #91
biker_mike
biker_mike's Avatar
Oddometer: 10
got it!
I received my pump upgrade kit today from Dr.Bean. The package was opened by customs,but things look fine. Thanks for the fast turnaround time..barely a week.
The only down side was the instructions were missing. Thats no big deal,there is enough info and picts on this thread to cover the installation.
Again thanks Gerben.Can't wait to install it.
Mike
biker_mike is offline   Reply With Quote
Old 07-28-2011, 04:51 AM   #92
ACP
ACP's Avatar
Oddometer: 74
Mike
The instructions are a print-yourself job. Here>>> http://www.lc8.nl/download/fuelpump%20manual.PDF
or take the laptop out to the garage with you...
Good luck
950 GO!!!!!!!
690 Enduro R
ACP is offline   Reply With Quote
Old 07-28-2011, 10:54 PM   #93
Dr_Bean OP
Dr_Bean
Oddometer: 107
As mentioned in your my PM/Mail: I don't print the instructions.
you can download full instructions in english (or dutch if you want) in pdf:
regards
Mike
Dr_Bean is offline   Reply With Quote
Old 07-29-2011, 05:30 AM   #94
Bumpaman
Location: Foot of the Sangre de Cristos and Music City, TX.
Oddometer: 157
Pump fix........
Sounds like a great fix Dr. Bean. How do I order one of your kits?
Bumpaman is offline   Reply With Quote
Old 07-29-2011, 06:25 AM   #95
brewer90
brewer90's Avatar
Oddometer: 586
I'd like to buy one. Sent you a PM.
brewer90 is offline   Reply With Quote
Old 07-29-2011, 05:07 PM   #96
biker_mike
biker_mike's Avatar
Oddometer: 10
Thumb what he said
I went back and (REALLY) read my PM. It was just like Dr.Bean said,he does not print the instructions. Wasn't blameing him anyway,kind of thought customs lost them when they opened the package.
Anyways,its all good...sorry for the confusion.
Thanks again Dr.Bean
Mike
Old 07-30-2011, 05:49 AM   #97
Dr_Bean OP
Dr_Bean
Oddometer: 107
Don't worry, no problem.
I don't include the manual: That would increase the weight and (in some cases) go over the limit of shipping it as letter-mail, making it a lot more complicated.
Old 08-01-2011, 05:40 PM   #98
slammer218
Slammer
slammer218's Avatar
Oddometer: 135
Thumb Happy Me
Took the bike out this weekend for the first time after the pump fix. Rode some dirt roads, water crossing and had not one problem. Sure is nice to go for a ride and wonder if you are going to make it back with only 20,000 miles on the bike. Points were shot. Thanks Mr Bean.
slammer218 is offline   Reply With Quote
Old 08-07-2011, 09:38 AM   #99
Kenbike
Oddometer: 703
Does my 2007 adventure still have points in the fuel pump?
Anyone have a link to the o rings on the pump other than the KTM dealer?
Has anyone had any luck using an external fuel filter on a 2007 or newer 990?
My bike act as if is starving for fuel around 5000 rpm's and higher in any gear so trying to get repair parts lined up. What is the correct pressure for the pump to make?
Current Bikes: 2014 BMW GSA, 2010 Vespa 300 Super scooter ( hers), 2012 Vespa 300 Super (his)
Kenbike is offline   Reply With Quote
Old 08-07-2011, 10:47 AM   #100
Dr_Bean OP
Dr_Bean
Oddometer: 107
a 990 is injection and has a completely different pump.
only 950 is carburator and ALL 950 have the same fuelpump.
Probably you should check the filters before and in your 990-injection fuelpump: Likely you find that in another topic/thread.
Old 08-07-2011, 12:13 PM   #101
Kenbike
Oddometer: 703
Thanks Dr Bean!
Old 08-07-2011, 12:26 PM   #102
ridewestKTM
ridewestKTM's Avatar
Oddometer: 1,706
pump stop circuit
Originally Posted by Dr_Bean View Post
2 things stop the pump from plopping:
- the ECU of the lc8 switches it of after 3-5 seconds when the engine is not running
- when the fuelpressure is enough (carb is full) the pump isn't 'loosing' the fuel any more and slows down pumping to the very minimum (less then 1x per second)
If you test it with a clip-on fuel-line, line the SMT has, it only plops 2-3x.
grts
I believe there is a tip over switch too. Feel free to correct me.
My 950KTM makes me feel like a little kid again......because it's so tall!
ridewestKTM is offline   Reply With Quote
Old 08-07-2011, 12:38 PM   #103
StevenD
Hmmmm, dirt!
StevenD's Avatar
Oddometer: 1,144
The tilt sensor only applies to fuel injected bikes, it is not found on the 950 ktm's.
999 LC8 Rat-Rally custom - 500 EXC - XR666R '85
StevenD is offline   Reply With Quote
Old 08-09-2011, 01:22 PM   #104
rider914
Agnostic Adventurer
rider914's Avatar
Oddometer: 2,455
Originally Posted by rider914 View Post
Received my kit last week via fmfpunk
Performed the pump surgery over the weekend and bench tested with an old battery... tooka~tooka~tooka~tooka~tooka
I've been running a Facet for the last couple years, but i'll swap the modified stock pump back when convenient.
-M
Finally got the modified pump back in last week, then went for a short (1100mile) weekend trip. Gravel, sand, mud, and tarmac. Rocks, ruts, bumps, and jumps. Near-zero to triple-digit speeds. Bike ran great and I like the clean install of the stock pump.
Thanks Dr Bean
-M
'05 950ADV
'04 525EXC D/S
'07 Tiger1050
Will herd cats for beer (... but I rescue puppies for free )
SmugMug (coupon: bLfv2vBXZicd6)
rider914 is offline   Reply With Quote
Old 08-28-2011, 01:44 PM   #105
666
Agnostic and Orange
666's Avatar
Oddometer: 1,316
Installed . Without disconnecting from the bike - didn't feel like pulling gas tank off.
I had a scare moment when test didn't pass - turning ignition and nothing! Apparently I forgot to flip the kill switch.
Points were pretty much shot - only half of each left, 17k miles.
2006 KTM 950 ADV; 2006 KTM 525EXC; 2013 Tiger 800 street
Moab Ride Report http://www.advrider.com/forums/showthread.php?t=629423
Dusy Ershim Ride Report http://www.southbayriders.com/forums...ad.php?t=99109
666 screwed with this post 08-28-2011 at 07:16 PM
666 is offline   Reply With Quote
Times are GMT -7.   It's 05:27 PM.
