01-16-2013, 10:16 AM
#2221 |
Oddometer: 354
Glad our LRP is running good, a man or a woman could go crazy trying to figure this out.
Fixed.
CRF250L, always cleaned while it's raining C14 |
01-16-2013, 12:28 PM
#2222 |
Oddometer: 2,942
Here's a nice video which demonstrates some good, general tips for changing the drive chain and both sprockets. In particular, note the good information starting at the 4:29 time mark regarding the correct way to loosen and tighten the rear sprocket bolts for the CRF250L.
![]() Spud
2005 XR650L: Shorai Battery Relocation, Spud Oil Cooler, XR650R C/S Sprocket, Reinforced Subframe, Chain Slipper Roller, Performance Design Lowering Link, Baja Designs Headlight, FMF Hi-Flo Header, ManRacks SD Rack, CST Surge I Front Tire, D952 Rear Tire, Tusk D-Flex Handguards, Uni Air Filter, No-Toil Evolution air filter oil |
01-16-2013, 12:57 PM
#2223 | |
Kulia i ka nu'u
Oddometer: 742
COHVCO/BRC/AMA 2011 BMW F650GS Twin 2013 Honda CRF250L Little Red Pig! |
01-16-2013, 01:35 PM
#2224 |
Oddometer: 354
Spud, great post
+1 This showed how removing the bolts, while just holding the allen in place works better. I think Ramz said 20/20 hindsight, this would have worked better. Some of us like to do this stuff our on our own, and get a better understanding of what is going on with our bikes, in case "stuff" happens miles away from where anybody can help. I am thinking of doing the 13/42 like Sugardust has, and while I'm at it, do the Tubliss conversion. Still hopes of actually riding here, I would rather do the conversion and check the air pressure, then wait 24 hours and check again, before slapping the wheels back on. If I get 3 days where I can't ride, that would probably be the time. I only did that once to fix a flat, put it all back together, then it's flat the next day. You get better at stuff the 2nd time around, live and learn.
CRF250L, always cleaned while it's raining C14 SAPB screwed with this post 01-16-2013 at 02:00 PM |
01-16-2013, 02:11 PM
#2225 |
Oddometer: 94
Sprocket change
Yeah, that was a good video. Just how much force is required to break loose the nut on the back of the sprocket bolts on a 250L? Do I need to hire a gorilla or if done properly by two people like in the video, can it be done with standard tools (no cheater bars, pipes over wrenches, etc.)? I wouldn't mind a 42T rear sprocket, but some of the horror stories about rear sprocket removal on here have kinda steered me clear of it so far.
01-16-2013, 03:10 PM
#2226 |
Oddometer: 39
Rear sprocket removal was pretty easy. Like 10 min including wheel removal!
![]() ![]() Not sure if the photos uploaded but a socket wrench with Allen key attachment in on hand and wrench in other. |
01-16-2013, 03:13 PM
#2227 | |
Kulia i ka nu'u
Oddometer: 742
you can do it without a cheater bar - I did it, and while i was one who had a a problem with the rear sprocket bolts, my dealer took them out for cheap, then I just replaced them all with XR650L bolts (at the time you couldn't get the rear bolts you probably can now)
01-16-2013, 04:00 PM
#2228 | |
Oddometer: 2,942
Even if the first sprocket removal is difficult, you shouldn't have further problems if you follow the proper technique demonstrated in the video. I use a short, T-handle, Allen wrench and a short, box end wrench to perform the procedure. You don't need to torque the bolts very tight; just snug them up, as demonstrated in the video.Spud
01-16-2013, 04:19 PM
#2229 |
Oddometer: 94
Rear Sprocket
OK, thanks for the encouragement JR, Sugardust and Spud Rider! What rear sprockets are you folks using....I've seen the one's from Sprocket Center....JT's and Superlite. The Superlite 42T looks interesting. Also, CRF's Only has rear sprockets in 42T listed as well but don't state what brand it is. I assume it looks like the one in the picture?
http://www.crfsonly.com/catalog/prod...oducts_id/4743 Also, refresh my memory that the stock chain works with a 13/42 setup and no other mods to the chain guides, etc., right?? |
01-16-2013, 04:26 PM
#2230 | |
Oddometer: 126
I did it alone as follow : unlocked all the nuts when the wheel still in place with my foot, standing all my weight on the 17mm ring wrench. 1st gear should be engaged to prevent wheel spinning, too. ![]() L
'10 Husky 510 SMR |
01-16-2013, 04:42 PM
#2231 |
Oddometer: 178
Oil Filter
Anyone know which K&N oil filter this bike takes..? I've seen some say KN-111 and others KN-112.
01-16-2013, 04:57 PM
#2232 |
Oddometer: 35
![]() ![]() ![]() ![]() Hopefully this works, first time posting pics. I've been wanting to install my Emperor Racing skid plate but it has been really cold out. Today I figured the hell with it I've been waiting long enough, time to get it on. Install went well. Front and back use brackets to mount the plate to so it takes a little bit of time getting it lined up properly. Other than that everything looks good, should provide decent protection. |
01-16-2013, 05:08 PM
#2233 | |
Oddometer: 39
01-16-2013, 05:34 PM
#2234 |
Oddometer: 39
Emperor skid plate looks nice, I like how the coverage goes between the down tubes. Looks light as well. i have The ricochet plate and found that leaves a gap there so it constantly picks up mud and leaves off the trail.
01-16-2013, 06:15 PM
#2235 |
- Jinksy
Oddometer: 56
What are you doing to the bike?
Honda CRF 250l Honda Shadow Spirit 750 Honda XR 80 |
