Old 01-20-2013, 10:04 PM   #2386
cat
cat's Avatar
Oddometer: 1,323
Krono,
good job with the headlight mask. i wish i could do that with the standard mask, get rid of the heavy brackets.
cat is offline   Reply With Quote
Old 01-20-2013, 11:00 PM   #2387
Krono
Speed Junkie
Oddometer: 193
Originally Posted by cat View Post
Krono,
Not only the bracket, but the whole assembly is heavy (1.47kg).
The UFO stealth w/ homemade speedo alu plate is only 0.57kg
... and as the new headlight mask includes led blinkers, thats get rid of 0.33kg more
--> All in one, that's a 2.7 lbs gain. Most important is thats high placed weight.
Downside is 35W only H4 bulb now, but usually i dont ride at night
Since there's lot of ice & snow here, i couldn't even give a try. Cant wait ..
I should find another mod to keep me busy
L
SM510R
Krono screwed with this post 01-21-2013 at 05:06 AM
Krono is offline   Reply With Quote
Old 01-21-2013, 08:44 AM   #2388
Bob80
Oddometer: 80
hi guys :)
Does anyone know how much fork oil (how far from the top), and what viscosity?
I wonder if they have different amounts, right and left, because the one doesn't have a spring. Even the same amount would come to a different height, with spring and no spring.
The service manual, from Helimos or whatever it is, is it the genuine Honda part or is it a scanned copy?
Service Manual (Helms) :
Recommended Fork Oil
: Pro Honda Suspension Fluid SS-8 (10W) or equivalent
Fluid level
Right-122mm (4.8 in)
Left- 38mm (1.5in)
Fluid capacity
Right- 658 +/- 2.5cm3
(22.3 +/-0.08 US oz,23.2 +/-0.09 Imp oz)
Left- 683 +/-2.5cm3
(23.1 +/-0.08 US oz,24.0 +/-0.09 Imp oz)
If this is any help to ya, I believe that Helms is the publisher for the Honda manuals...same thing, so I've read
Bob80 screwed with this post 01-21-2013 at 08:52 AM
Bob80 is offline   Reply With Quote
Old 01-21-2013, 08:57 AM   #2389
strongbad
Oddometer: 491
I've found that it's more accurate to measure what drains out of the fork and replace the same amount.
strongbad is offline   Reply With Quote
Old 01-21-2013, 09:23 AM   #2390
Ed@Ford
Oddometer: 1,683
Originally Posted by Krono View Post
L
I believe 35/35 W H4 and normal 55/65W H4 are identical and interchangeable....BUT if the lens and reflector is plastic, the bigger wattage bulb might melt it
Ed@Ford is offline   Reply With Quote
Old 01-21-2013, 09:27 AM   #2391
Ed@Ford
Oddometer: 1,683
Fluid level
Left- 38mm (1.5in)
Fluid capacity
Left- 683 +/-2.5cm3
Thanks for the fork info. I wonder how many folks have spent $$ adding gold valve...singular...and it's HELM...no S...when I called them last week I asked if they planned to provide it on CD....they said no....and they were out of stock on printed copies
Old 01-21-2013, 09:30 AM   #2392
Ed@Ford
Oddometer: 1,683
Problem with that is solid crap gets to hide here and there in the mechanism....so drain, add solvent, drain, add cheap oil...like trans fluid, pump it around, drain, then add the appropriate quantity of the good honda or bel ray fork oil....this washes the crap out a little better
Old 01-21-2013, 09:43 AM   #2393
Bob80
Oddometer: 80
Sorry on the "S"...please forgive me...Did you try CRF's Only? Its a bit of a maze to find it in the site, but that's where I got mine a couple weeks ago.
Old 01-21-2013, 09:51 AM   #2394
Bob80
Oddometer: 80
They must be out of stock also...just tried to find it, and it's not even listed anymore...
Old 01-21-2013, 09:52 AM   #2395
Ed@Ford
Oddometer: 1,683
Last week CRF's was sold out, expecting more late this month...and I'm on the wait list at Helm....their shop...or at least one of them, is 20 miles away...so, I'm good with one or the other
Ed@Ford screwed with this post 01-21-2013 at 09:55 AM Reason: spelling
Old 01-21-2013, 10:42 AM   #2396
NJ-Brett
Brett
Oddometer: 6,860
Maybe if the right amount is in there to start with.
I changed the oil in my TU250 forks, I drained about 365cc's out of each and refilled with thicker oil.
When I went back to thinner oil, I read the shop manual, 2.8 inches from the top, over 500cc's of oil!!!!
Funny, the forks seem to work better with the right amount of oil in them.
NJ-Brett is offline   Reply With Quote
Old 01-21-2013, 11:12 AM   #2397
clfarren5944
Oddometer: 47
Shifters
Does anyone know if the shifter shaft diameter and spline spacing is common on Honda dirt bikes? If it is, then we would have a large selection of replacements for the LRP. I have no other Hondas in my garage to be able to compare.
Thanks, Chris
clfarren5944 is offline   Reply With Quote
Old 01-21-2013, 11:13 AM   #2398
SAPB
SAPB's Avatar
Oddometer: 1,664
Rear disc protector
Does anyone know of someone producing one of these for the CRF yet? Just poking around on the minimalist threat, and a guy doing prep for a major upcoming trip on a "Brand Y" bike has one of these on his. I sorta told myself I wouldn't be spending major amounts of $ on this bike, but so far that plan hasn't panned out so well.
C14 - CRF250L, always cleaned while it's raining
CRF250L Service Manual http://www.hondampe.com.au/docs/owni...F250L13_OM.pdf
SAPB is offline   Reply With Quote
Old 01-21-2013, 11:51 AM   #2399
Spud Rider
Spud Rider's Avatar
Oddometer: 3,855
Originally Posted by itrack View Post
Ok, so I'm going forward with this project. I ordered every seal and bushing I could find for these forks. I am bolting on 43mm KYB forks off a 1995 CR250. I ordered Racetech Type 1 Gold Valves FMGV 2530, AB Fork Bushing Kit 38-6014, MSR Forks Seals and Wipers 56-137, Racetech Springs FRSP 395150, 215.VM2.K5 fluid 54oz, Motion Pro Damper Rod Tool, and a Motion Pro Fork Seal Driver.
I know there are some guys that know way more than me about rebuilding forks, so anything I missed? Any instructional youtube vids or write ups on the KYB 43mm? This will be my first fork rebuild.
I found another tutorial for servicing the KYB cartridge forks.
http://www.easterndirt.com/?p=6
The instructions in this tutorial are very good, and the information is supplemented with photographs.
Spud
Old 01-21-2013, 12:12 PM   #2400
Irish769
Irish769's Avatar
Oddometer: 88
Originally Posted by trainman View Post
Irish769, as far as I know and from probably installing some 20 sets of handguards on probably 20 motorcycles they are all pretty much the same. Since the throttle handle extends beyond the end of the bar you will have to cut the end off so you can get the handguard end clamps into the end of the bar, this can be done 2 or 3 ways, I used my Dremel to cut my end off, you could also use a hacksaw, the third way would be some sort of knife, but since the plastic on the throttle handle is tuff stuff, I'd pass on the knife. You asked about a drill, I guess you could drill out the end, but you are still going to need a way to shorten the plastic throttle assembly and a drill won't do that. You need the end off first so you can see how much extra needs to be cut off so the throttle handle will clear the handlegards you will be installing. You are going to cut the plastic throttle handle back about 3/16" from the end of the bar, this is so the bar end clamp will not interfere with the operation of the throttle when you install the handguards. One note here, since I was installing new grips I took the old grips off first which can make things a little clearer to what you are doing. One thing about using a Dremel is it will cut the grip and the plastic very smooth and you can take off a little at a time and cut as needed for a nice look and fit. Due note that you are going to have to cutoff both handle grips for the handguard to fit into the bars, but only the throttle side will require the extra trimming because of the truing of the throttle. This is like any other job, with the right tools it's easy to do the correct way.
John
Thanks John.....That sums it all up nicely!
2008 Concours 14 (Traded)
2004 Yamaha Roadstar
1975 KZ 400
2013 CRF 250L
2014 BMW GSW
Irish769 is online now   Reply With Quote
Times are GMT -7.   It's 10:36 PM.
