01-28-2013, 11:11 AM
#2701 | |
Crazy Diamond
Oddometer: 726
Maybe this will help. Here's some background... 4 level neck fusion, 3 level lower back fusion, every disc degenerated, 4 are bulging, 2 heart stents, a heart arthmia, 3 episodes of acute brain trama, 20+ concussions, a brain tumor and more... I'm screwed up in the head and admit it. Sometimes I'm an idiot other times a savant, Probably both soon... ![]()
Praise the Lord!!! I have seen the light!!! He has shown me the promised land!!! TT for now...
MentalGuru screwed with this post 01-28-2013 at 11:59 AM |
01-28-2013, 11:19 AM
#2702 | |
Crazy Diamond
Oddometer: 726
The injector only needs to squirt every other revolution. It needs a cam sensor or fancy programing do do this. This system is very close to a pre 0BD2 system but not as advanced. It is very simular to Dodges system they used on early 4 cylinder MPI cars.
01-28-2013, 11:20 AM
#2703 |
Brett
Oddometer: 4,786
If you change things like intake, exhaust, or bore size, you have to change the amount of fuel going into the motor.
Most FI mixture corrections do not add a lot of power, but give better response, less surging, eliminate backfires, make the motor run cooler, but do not add a lot of power. Some systems like what is on Harley's are set really lean (no cats to clean things up) and you can not do much without having problems. Bikes with cats seem to be able to run richer and deal with some changes ok, my TU250 does. And I do not think any system on bikes is anything like anything ever used on a car, cars were always wideband systems I think, even the early ones, while there are no wideband systems on bikes that I know of. The systems in use on bikes are simple carb replacement systems using maps to set the mixture, with very limited input from the oxy sensor. |
01-28-2013, 11:26 AM
#2704 |
Oddometer: 105
01-28-2013, 11:40 AM
#2705 |
Brett
Oddometer: 4,786
Even some systems on cars would pulse the injectors with a closed intake valve, the mixture just hangs around before being sucked in.
Some bikes must do that as there are no cam position sensors and there is nothing to tell between TDC on the power stroke or the exhaust stroke. Any thumper without a cam position sensor would HAVE to do this. |
01-28-2013, 11:42 AM
#2706 |
Oddometer: 1,061
[QUOTE=hrcs90;20593436]Honda's PGM-FI doesn't use OBD codes like the car world like you would expect, but a more Honda style. You can pull codes if needed through the RED DLC plug on the bike, by jumping the Brown and Green wires together or purchase Honda special tool "SCS connector". Make the connection and then turn the main switch on and count the MIL blinks.
So, are you pretty convinced Honda does not use the standard OBDII 4 digit codes on production bikes? If so, that means we not only need a way to read the MIL (Malfunction Indicator Light ) blinks....but also a "dictionary" of the code # and their meaning........... |
01-28-2013, 11:55 AM
#2707 | |
Crazy Diamond
Oddometer: 726
The computer can be programed to sense when the combustion stroke happens by monitering the increase in crankshaft speed. With the proper software it is possible to fire the injector at the corect time with only a crank sensor. Some cars do this when the cam sensor fails so they cam still run in limp in mode...
01-28-2013, 12:32 PM
#2708 | |
Speed Junkie
Oddometer: 133
The title is a little confusing where it's placed, though ... ![]() L
'10 Husky 510 SMR |
01-28-2013, 12:34 PM
#2709 |
- Jinksy
Oddometer: 56
Gear radio
If I change the gear ratio from 14/40 to 13/43 will this give me better performance off the line?
Honda CRF 250l Honda Shadow Spirit 750 Honda XR 80 |
01-28-2013, 12:45 PM
#2710 | |
Crazy Diamond
Oddometer: 726
01-28-2013, 12:49 PM
#2711 |
Speed Junkie
Oddometer: 133
About air induction, after having corcked it and disconnected the O2 sensor, following BDSB suggestions here http://bestdualsportbikes.com/dual-s...honda-crf250l/ and installed a dBkiller of my own, i had many stalling problems. That was cured by re-plugging the secondary air system and setting the first EJK parameter to 0, what got me rid of backfires too. Replugged also the O2 sensor, as i was there.
Doesn't seems logical, since i probably leaned at idle, but that's what experimentation concluded in my case. Whatever .. i will try to experiment more with teh EJK setting (which you can emulate here http://www.electronicjetkit.com/demos/HPcurve.swf press mode, then + or -) L
'10 Husky 510 SMR |
01-28-2013, 12:56 PM
#2712 | |
Speed Junkie
Oddometer: 133
What is shown with the little arrows L
'10 Husky 510 SMR |
01-28-2013, 12:57 PM
#2713 |
Oddometer: 1
Derp.
New member, as I was recently granted permission to join from a fellow owner Finally purchased a CRF after about 7,000 kms riding on rented machines in Thailand. Mine has 330 kms on it now. Going to get a new exhaust on tomorrow and new aluminum bar. Got other goodies coming over the next month or two.Look forward to reading about all the mods coming out for the bike. Here's a video I made in Thailand - footage from 2012. Stock CRF riding down doi suthep with a modified KLX enjoy |
01-28-2013, 01:16 PM
#2714 | |
Speed Junkie
Oddometer: 133
'10 Husky 510 SMR |
01-28-2013, 01:40 PM
#2715 |
Oddometer: 150
