Old 01-29-2013, 04:33 PM   #2776
jsmithy
ADV Poser
jsmithy's Avatar
Oddometer: 190
Originally Posted by MentalGuru View Post
So how do you like your LED aux lights???
I like them. They are advmonster model 44s. This is the fourth bike they have been on. I can't run them much in the dark...they really piss other drivers off. I use them mostly for daytime conspicuity and trail rides during twilight.
CURRENT: 2013 CRF250L - 1997 GL1500SE
PAST:
2005 DR-Z400S - 2008 DL650A - 2008 ST1300 - 2009 KLR650 - 2002 DR-Z400S - 1987 RM 250 - 1980 KD-80
jsmithy is offline   Reply With Quote
Old 01-29-2013, 04:39 PM   #2777
jsmithy
ADV Poser
jsmithy's Avatar
Oddometer: 190
Originally Posted by Ed@Ford View Post
J Smitty:
Is that the National Cycle windscreen?
Is that the RotoPax storage pack? Are you satisfied with the amount of goodies you can cram in it? I've got an older 1.25G rotopax gas can...and the storage pack looks interesting.
Have u had any issues with the red gas can (also 1.25G) filler leaking?
Yes. National Cycle Spitfire. It works well. I used it on my DR-Z where it fit and looked a little better.
Yes. Rotopax storage pack. I'm a little disappointed with the room in it. Not quite as much as it appears, but it is secure and convenient. It has room for two tubes and tire tools with room to spare.
I haven't put gas in it yet and I hope it doesn't leak. Most people are happy with them. This is 1.75 gallon size
PAST:
Old 01-29-2013, 04:45 PM   #2778
yyz
Oddometer: 38
Hey Mental Guru, I spotted this on the WRR thread, that's not really a nice thing to do
MentalGuru
Brain Damaged Inmate
Oddometer: 695
Need a good laugh??? Read the following quote from the CRFL owners thread.
Follow the link and share your thoughts... It's only fair....
Originally Posted by mtntrails
CRF250L Owners.... Please chime in on this thread...
http://advrider.com/forums/showthread.php?t=858964
If you don't like my response ask for a different voice.....
Let us consider that we are all partially insane. It will explain us to each other; it will unriddle many riddles; it will make clear and simple many things which are involved in haunting and harassing difficulties and obscurities now. - Mark Twain
yyz is offline   Reply With Quote
Old 01-29-2013, 04:46 PM   #2779
Jinksy
- Jinksy
Jinksy's Avatar
Oddometer: 56
Yoshimura Fender Eliminator Kit?
Has anyone installed a Yoshimura Fender Eliminator Kit? If so, how do you like it? Is it easy to install?
http://www.crfsonly.com/catalog/prod...oducts_id/4873
Honda CRF 250l
Honda Shadow Spirit 750
Honda XR 80
Jinksy is offline   Reply With Quote
Old 01-29-2013, 05:05 PM   #2780
jsmithy
ADV Poser
jsmithy's Avatar
Oddometer: 190
Here is the inside. That is a front tube stuffed under the ledge. There is room for a rear tube In between that and the center post. These are heavy duty tubes...regular duty would obviously fit better.
PAST:
Old 01-29-2013, 06:58 PM   #2781
Jimmy the Heater
Tilting the Horizon
Jimmy the Heater's Avatar
Oddometer: 1,435
Another prospective owner here with a couple of questions for 250L owners.
Anyone here ridden both the CRF230F and the 250L? I have the 230F and like the engine but the suspension, handling and 80% of full size bike are really getting to me.
Does the 250L have a more compliant suspension setup (basically softer, the 230 is massively overdamped) Less twitchy, and physically larger?
I'm 175lbs 6' with a 33" inseam and the 230 is borderline minibike to me.
Jimmy the Heater is offline   Reply With Quote
Old 01-29-2013, 08:09 PM   #2782
NesquikNinja
Oddometer: 174
Put simply, swap it out you will be happy.
To elaborate, see here: http://www.advrider.com/forums/showthread.php?t=818809
Good info and links in that thread.
The best way to search:
1) Go to www.google.com
2) Type the following into the search bar site:advrider.com
3) Follow that up with what you want to find
Example site:advrider.com crf230l vs crf250l
I discovered this not long ago- amazing!
Originally Posted by bungie4 View Post
Psst. Don't tell anybody but the CRF250L pulls women like crazy.
Originally Posted by Sparrowhawk View Post
More stuff will clutter your life and make you poor. More adventure will richen your existence. Make do and make tracks.
NesquikNinja is offline   Reply With Quote
Old 01-29-2013, 08:45 PM   #2783
Bob80
Oddometer: 80
I'm not trolling... I'm a regular on the CRFL threads and do like the bike.
I'm in the process for writing a detailed post about how the engine controller and all the sensors work and diagnois for the backyard wrench can do.
Thats why you haven't seen CRFL owners attack my post.
I do look forward to reading this...hopefully it's info.that we don't "need" to know anytime soon, but, "good" to know, my FI expertise are slim ta none, but enjoy reading about it all....
Bob80 is offline   Reply With Quote
Old 01-29-2013, 11:58 PM   #2784
positron007
Oddometer: 44
If you don't own a crf250l you are not allowed to ask questions about it here. FFS get with the prograam
positron007 is offline   Reply With Quote
Old 01-30-2013, 12:03 AM   #2785
Spud Rider
Spud Rider's Avatar
Oddometer: 2,955
Spud
2005 XR650L: Shorai Battery Relocation, Spud Oil Cooler, XR650R C/S Sprocket, Reinforced Subframe, Chain Slipper Roller, Performance Design Lowering Link, Baja Designs Headlight, FMF Hi-Flo Header, ManRacks SD Rack, CST Surge I Front Tire, D952 Rear Tire, Tusk D-Flex Handguards, Uni Air Filter, No-Toil Evolution air filter oil
Old 01-30-2013, 12:08 AM   #2786
Jimmy the Heater
Tilting the Horizon
Oddometer: 1,435
And you aren't allowed to post anything and be taken seriously unless you can spell correctly. FFS use spell check
Old 01-30-2013, 12:15 AM   #2787
positron007
Oddometer: 44
OK fucker, lesson learned. I must use the fucken spell checker.
Can I apply for an exemption on the use of "fucken"?
Old 01-30-2013, 12:31 AM   #2788
Crafty_D
Oddometer: 12
Now come on gents. I was trolling this thread before I got mine. :) I love my CRF250L, all I would like is a little more power but that im sorting really soon :)
Crafty_D is offline   Reply With Quote
Old 01-30-2013, 12:56 AM   #2789
Jimmy the Heater
Tilting the Horizon
Oddometer: 1,435
I figured the best place to ask a question about the 250L would be in a thread where people actually owned them. I agree, lets keep with the friendly forums and save the swearing for Jo Momma.
Old 01-30-2013, 01:11 AM   #2790
positron007
Oddometer: 44
Well that might sound sensible on the surface but may I refer you to post #2800, and #2804.
Times are GMT -7.   It's 11:18 PM.
