Old 02-13-2013, 06:46 PM   #3196
Lost Rider
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,237
Originally Posted by goondock View Post
YES MORE BLINKER RELATED QUESTIONS..
does anyone know where the blinker relay is located and what it looks like? i was told it is is located under tank, between resistor and ECU. but i pretty much have the bike in peices and cant find it.. i am trying to do it without removing the tank. any help would be great.
I haven't seen the LRP relay, my relay in other bikes have been small and hard to spot, here's something that might help. Or maybe confuse you even more.
Post some photos when you find the elusive Honda relay please.
Relay on different bike, probably much different though.
Photography for me is not about recreating what I saw through
the viewfinder but to show people the way I want to see the world.
LostRider.com
Lost Rider is offline   Reply With Quote
Old 02-13-2013, 07:20 PM   #3197
goondock
Oddometer: 68
LED's
Thanks lost! i found a diagram of the wiring harness (couple posts back is the link), and figured it out from there it is right above the horn mounted to a little rubber piece. unhooked the relay and unhooked the horn so i could get some slack. cut off the stock plug, kinda scary. hook up the IRC relay and POW! all the blinkers work and blink at stock tempo... Wheeling cycle supply was great help on this as well. I know you aren't into mods ha ha ha kidding, but I will post pictures when i get a chance. looks slick IMO
man i have installed engines in jeeps, changed timing belts on bimmers and subarus, and those damn marker lights kicked my ass. ha.
goondock is offline   Reply With Quote
Old 02-13-2013, 07:40 PM   #3198
Harcomo
Oddometer: 119
Originally Posted by 'Flagger View Post
It appears that since the disk that sits outside of the exhaust isn't inserted into the pipe exit, all that would be needed is rotate the dbDawg so as to avoid interference with the part that does go into the pipe exit.
I think you're correct about the dbDawg......from the picture of it, I can see how it would probably work if you got the one that was the right diameter for the inside of the pipe.
Harcomo is offline   Reply With Quote
Old 02-13-2013, 07:47 PM   #3199
Lost Rider
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,237
LOL, glad to help...
yeah, I'm not into Mods.
This started out life as a yellow F800GS.
Won't be doing anything like that to the trusty LRP though.
LostRider.com
Old 02-13-2013, 08:01 PM   #3200
gaan
Oddometer: 8
emissions label
Anyone know where the emissions label is located? Went to get my out of state LRP inspected at California DMV and inspector was unable to locate it. He thinks it's under the seat but I didn't see it. I don't have the owner's manual.
gaan is offline   Reply With Quote
Old 02-13-2013, 08:18 PM   #3201
trainman
trainman's Avatar
Oddometer: 397
What's that label on the back fender, isn't that the emission label.
http://rickramsey.net/CRF250Lmods.htm#labels
John
trainman screwed with this post 02-13-2013 at 08:27 PM
trainman is offline   Reply With Quote
Old 02-13-2013, 08:23 PM   #3202
gaan
Oddometer: 8
It was purchased with an aftermarket fender. great.
Old 02-13-2013, 09:19 PM   #3203
gaw777
Oddometer: 59
I'm not sure if you guys wanting to mount a GPS on the fatbars are using a RAM type mount, most GPS mounts are compatible with them, but this could be an option.
I like this setup on my other bikes, nice and clean. I happened to have an extra standard u-clamp mount to put on the LRP, or else I'd have bought the cleaner option, would work with any bars since it goes into the top clamp.
http://www.rammount.com/CatalogResul...5/Default.aspx
Similar to this, but cleaner and not bar restricted.
Perfect, I had forgotten about the Ram Mounts.... and I have one
Thanks for the reminder!
2010 ktm 690smc, 2013 crf250l
gaw777 is offline   Reply With Quote
Old 02-13-2013, 09:29 PM   #3204
Irish769
Wanna-be
Irish769's Avatar
Oddometer: 63
13T installation
If someone wouldn't mind dumbing it down and indulging me for a moment....I have a 13T front sprocket on order. The installation seems pretty straight forward. Please correct me if I'm wrong; slack the chain by way of the adjusters on the rear axle, remove the old sprocket, install the new sprocket, adjust the chain - done. Am I missing anything?
2008 Concours 14 (Traded)
2004 Yamaha Roadstar
1975 KZ 400
2013 CRF 250L
2014 BMW GSW
Irish769 is offline   Reply With Quote
Old 02-13-2013, 09:46 PM   #3205
Sharkfan22
Oddometer: 24
Got an email back from Just Gas Tanks, that IMS have a larger tank out next month, No word on size
Sharkfan22 is offline   Reply With Quote
Old 02-13-2013, 09:49 PM   #3206
CRFSoCal
Oddometer: 43
I just installed some new bars and the Highway Dirt Bike handguards. They where a pain to put on. Theres a little bit of tension on them but I assume that is ok. Oh ya I think I like the White plastics better. Does anyone want to trade my extra black ones for some white ones?
CRFSoCal is offline   Reply With Quote
Old 02-14-2013, 12:10 AM   #3207
Krono
Speed Junkie
Oddometer: 193
Isn't this 'insert' you're talking about the dBKiller mentioned in the previous post? Sort of a homemade version of this?
I took my inspiration there https://www.google.ch/search?hl=fr&g...KcqStQbVvoGYAQ (Goggle-Image dbkiller)
Unlike the db dwag, this preserves the exhaust area, but creates some "zig-zag" to brake sound waves. Corks less, and thus does not restrict exhaust flow.
This pict was the prototype, made aluminium and connected w/ a ring inside the spark arrestor of the Q4 (a pain to remove) Result was too loud.
After some tries, i made one of steel, longer and almost same diameter than the spark arrator tube (32mm) that fit inside it.
20x 4.5mm holes seems to hit the spot. Sorry no picts of this one.
The result is just a bit louder than stock when throttle wide open, but quite same when cruise.
Performance dosen't seem noticiably affected vs open. EJK is now setted a bit leaner than factory setting for CRFL.
Im happy with the result, plus the added look and weight loss of the FMF exhaust line.
L
SM510R
Krono screwed with this post 02-14-2013 at 12:20 AM
Krono is offline   Reply With Quote
Old 02-14-2013, 05:20 AM   #3208
Ed@Ford
Oddometer: 1,632
KRONO: Amazing pages of pictures!!! My plan, now that I have disassembled my muffler is to modify the spark arrestor insert that appears to be unique to the USA & Canada and can be seen on the RamZ site with more holes and screen
Ed@Ford is offline   Reply With Quote
Old 02-14-2013, 06:29 AM   #3209
Ed@Ford
Oddometer: 1,632
CRF250L Service manuals are back in print and available at Helm Inc 1-888-292-5393 61KZZ00 is the part #...credit cards only
Old 02-14-2013, 07:27 AM   #3210
cat
cat's Avatar
Oddometer: 1,323
Originally Posted by Charleston View Post
Has anyone had an issue with the clutch slipping when you jump on the gas with the clutch lever out (on a good traction surface like pavement)? I have adjusted the clutch free play twice and still sometimes hear the engine wind up faster than the bike speed.
Iím no expert but understand that the clutch uses a judder spring that is supposed to soften clutch engagement but can cause slip when more HP is applied than designed for. My bike is stock, I donít have the stonkin HP that some of you are getting with your mods (I donít even have the go-fast sticker mod).
I hope you didn't use car engine oil. (i'm jus' sayin'. Don't be offended.) :)
Apparently, that "judder plate" is a potential problem but so far we haven't heard of any cases here. (Other than yours.)
The "Honda Racing Kit" includes the clutch plates and springs from the CBR250R (so the judder plate is replaced by a normal clutch plate) and these "racing" clutch springs show up on ebay sometimes. (I just saw this now, got an email of new items listed...)
http://www.ebay.com/itm/Modify-CRF25...E:B:SS:US:1123
cat is offline   Reply With Quote
Times are GMT -7.   It's 08:28 PM.
