Old 02-15-2013, 01:10 PM   #3256
SAPB
SAPB's Avatar
Oddometer: 1,557
Originally Posted by drtdino View Post
Also, what does "lrp" mean or stand for?
Sent from my iPad using Tapatalk HD
L ittle
R ed
P iggy
C14 - CRF250L, always cleaned while it's raining
CRF250L Service Manual http://www.hondampe.com.au/docs/owni...F250L13_OM.pdf
SAPB is online now   Reply With Quote
Old 02-15-2013, 01:35 PM   #3257
drtdino
drtdino's Avatar
Oddometer: 24
Originally Posted by SAPB View Post
L ittle
R ed
P iggy
LOL!!! That is awesome...
drtdino is offline   Reply With Quote
Old 02-15-2013, 02:09 PM   #3258
drtdino
drtdino's Avatar
Oddometer: 24
Here is a trailer I am building so I can haul the LRP around...
http://www.advrider.com/forums/showthread.php?t=863408
Old 02-15-2013, 07:54 PM   #3259
gaan
Oddometer: 8
Anyone in the socal area that has removed their rear fender with the emissions label want to part with it for a day? I'm willing to pay to borrow it so I can register my bike. Honda doesn't sell the label. Here's my bike at the DMV failing the inspection. :(
They didn't seem to care about the exhaust, just the VIN and emissions label check.
gaan screwed with this post 02-15-2013 at 08:01 PM
gaan is offline   Reply With Quote
Old 02-15-2013, 08:27 PM   #3260
gaw777
Oddometer: 59
The bars look good!
Let me know about the mount, be interested in hearing about it.
Thanks for the update
Originally Posted by Telemarktumalo View Post
I agree that the Easton pad is a dog. I'd rather use some foam pipe insulation and zip ties. I don't know about a GPS mount, but I'll take a look at my RAM mount and see if it will fit on the left bar in board of the mirror. Here are some pics of the set up. I really like the amount of rise that these have. I'll play around a bit this weekend. I had them set rotated forward to -1 position but put them at 0 yesterday. I'm going to try at +1 tomorrow.
2010 ktm 690smc, 2013 crf250l
gaw777 is offline   Reply With Quote
Old 02-15-2013, 11:34 PM   #3261
Lost Rider
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,233
Originally Posted by tirebiter View Post
I know I don't own a 250l, but have been riding bikes since the 60's and if you don't mind would like to shed some light on proper bar position.
What your looking for is flat, equal pressure across your palm from index to outside.
Lightly clamp your bars down so they won't move by themselves.
Rotate the bars forward and you'll find the pressure is on the outside of your palm (Last knuckle, Pinkie finger).
Then rotate the bars back towards you and you'll find all the contact pressure is on your index and thumb (Like making an OK sign, or choking a chicken)
Keep rotating forward and back till you feel the contact pressure of the bars is evenly distributed across your entire palm from index to pinky.
When you finally achieve that spot, it's time to ask yourself if your arms feel comfortable with that position.
If not and your arms are all akimbo, you got the wrong bend-
That's the rub, and the reason for so many different bends.
This of course might be accurate, if your main goal is comfort when in the seated position. For us comfort and stability is most important when in the standing position, where anyone should be most of the time when riding a DS bike off Tarmac. This procedure also could be subjective based on how fast a given rider is going and therefore how leaned forward to achieve perfect balance for where is most comfortable for them. Then you have different helmets and so on with more variables.
There is no one all process to finding the perfect position for everyone, mostly perfect balance and comfort cannot be achieved with anything less than personal experience thru trial and error IMO. MC riding is all about balance, once you learn that, then you know where your controls need to be for you, something not done in your garage, methinks.
Send me a PM, we live in Ventura and can work out you borrowing our fender, glad to help out. Going to be riding in the Malibu canyons this weekend...
Mobile ADV Fix Complete
Photography for me is not about recreating what I saw through
the viewfinder but to show people the way I want to see the world.
LostRider.com
Lost Rider screwed with this post 02-15-2013 at 11:44 PM
Lost Rider is offline   Reply With Quote
Old 02-16-2013, 12:21 AM   #3262
cat
cat's Avatar
Oddometer: 1,323
Yes, so most people pick a CR-Hi handlebar, rotate it forward enough to suit them for standing, and get used to whatever pull-back it has. If you use the adaptors to convert to fat bars, that adds more height than any of the typical bends other than the trials bars.
With a road bike, you need to avoid the bars that are much wider than stock, to avoid problems with the length of the clutch and throttle cables and wiring.
Getting the pull-back to suit you...the usual idea is to sit on the and hold out your arms to a sort of natural position and see how your wrists are, how straight or angled your wrists are. If they're quite angled, you want more pullback (many people do) then you have to look at that when comparing the handlebar specs.
When you look at the specs, comparing the different pull-backs, you see...trials bars typically very straight, less pull-back, because straighter better for standing, with more forward balance; then MX bars, then enduro bars and supermoto bars, more pull-back.
ZETA website has handlebar "simulator" that illustrates it very nicely. You select the bike (and they have the CRF250L), it displays a diagram showing the standard bar, then you select one of the ZETA bars and it superimposes the diagram for that one so you can compare.
You can see that the CRF250L bars would be quite good for most people - medium high, more pull-back than most.
cat screwed with this post 02-16-2013 at 08:22 AM
cat is offline   Reply With Quote
Old 02-16-2013, 07:40 AM   #3263
TNC
Candyass Camper
TNC's Avatar
Oddometer: 4,629
Depending on how you intend to use the trailer, you can add some options that will expand your hauling capabilities and make camping while you're out with your bike a lot more comfortable. I have a 5X8 homebuilt trailer I made in the 80's. I have the motorcycle offset to the left side and have two diamondplate truck boxes attached to the trailer on the right side in an end-to-end configuration. I call it a kind of "adventure" trailer. I strap a propane bottle to the front end of the trailer and cook off of a Coleman stove on the truck boxes. You can carry a good deal of gear and equipment in the boxes, and it's pretty darned secure in those locked boxes. I camp out in BLM and forest lands for free with my minivan, trailer, solar shower, and portapot in relative comfort. Bring along one of the more modern, efficient ice chests, and you can set up a base camp for 3-5 days and ride out an area on the bike and then move on when complete. Camping is great when you can bring enough stuff, not sleep on the ground, and cook decent food for your meals. These little trailers can make life much nicer out in the boondocks.
On the 12" tires that are available for these trailers, they basically suck. They don't last long at highway speeds. On my trailer, I found a used 13" car wheel with the same 4-bolt pattern...and if you have a 5-bolt pattern you can do the same. I then got a pair of the smallest 13" radial car tires that were a 1.55 or such. This wheel/tire is only slightly taller and fits under the fender of most 12" trailers with no issue. You can run a lower pressure of around 32psi for a better ride, and you get a tire that might rot off the wheel way before you wear it out. If you can, get rid of the 12" setup.
TNC is offline   Reply With Quote
Old 02-16-2013, 08:08 AM   #3264
bdolnik
bdolnik's Avatar
Oddometer: 106
Hi everyone, first time posting on the board. Have had the CRF250L for a couple weeks now and first thing I bought for it was the Fender Eliminator Kit from Yoshimura. Just got it installed today and thought I would post a couple pics, it was pretty easy to put on, and I really like the way it looks.
bdolnik is offline   Reply With Quote
Old 02-16-2013, 08:28 AM   #3265
Lost Rider
Unsubscribed.
Lost Rider's Avatar
Oddometer: 3,233
That's a clean looking tail, and very nice photos bdolnik!
Welcome to the party!
LostRider.com
Old 02-16-2013, 09:18 AM   #3266
trainman
trainman's Avatar
Oddometer: 397
Bdolnik, your LED rear lamp kit looks great on the bike, did the holes match up on the mounting bracket, or did you have to re-drill the bracket or the bike frame to make the fit. The turn signals look like they clear the stock exhaust ok and no heat or exhausted gas should affect the turn signal. I've used the DRC LED tail lamp kit sold be Wheeling Supply on my DRZ400, but was not totally happy with the way the turn signal brackets mounded to the bracket, your bracket looks like the turn signal ears are made on the bracket. Heads up on any of the above would be appreciated, thanks, John
trainman is offline   Reply With Quote
Old 02-16-2013, 09:43 AM   #3267
bdolnik
bdolnik's Avatar
Oddometer: 106
Wow, any compliment from you on photos Lost is pretty special, I'm constantly drooling over yours!
Trainman, there was no drilling, everything matched up perfectly. Simply unbolt the old one and bolt on the new one. The hardest part was cutting the existing wires, just because cutting is scary :)
The directions that come with it are very good also, step by step... was really easy to do. Here is what the factory bracket looks like when you get the fender off.
bdolnik screwed with this post 02-16-2013 at 09:51 AM
Old 02-16-2013, 10:10 AM   #3268
DirtyBlackIrish
DirtyBlackIrish's Avatar
Oddometer: 153
I used that to check out bar bends when i was looking. It really helped me understand how to visualize different bends.
Semper Fidelis
DirtyBlackIrish is offline   Reply With Quote
Old 02-16-2013, 03:47 PM   #3269
LiquidYogi
Oddometer: 4
Just got back from the dealer. $5,113 for a used LRP with 87 miles on it. Couldn't be happier its got plenty of pull on the freeways for me.
LiquidYogi is offline   Reply With Quote
Old 02-16-2013, 03:56 PM   #3270
Ed@Ford
Oddometer: 1,600
You know, now that I think of it, CARB has to be pretty stupid. Here in MI, the insurance companies know what motorcycles are "born" street legal, as well as emission legal. California and CARB are dumb enough to depend on some frikkin' sticker on the rear fender.....just another sad beaurocratic pissoff.
Ed@Ford is offline   Reply With Quote
Times are GMT -7.   It's 11:23 AM.
