Old 02-18-2013, 05:29 PM   #3301
AZDavis
Oddometer: 9
Flatland racing skid plat and radiator guard (after) pic
I know that a few people have asked for "after" pics and I am now the unfortunate owner of a couple. The radiator guard performed very well, I can only assume that is because as the bike cartwheeled it came down fully on the skid plate which is bent to 'heck' in a pile of bowling ball and larger rocks. I am happy to report however that the wreck was Wednesday, the bike was ridden for another hour out of the woods and the real damage wasn't discovered until today when I was performing an oil change and had to get a pry bar out to move the skid plate enough to have access to the oil filter. All I can think is that had the plate NOT been installed that the bike would have come down full force on either the engine cradle or the bottom of the engine case, either of which would likely have been catastrophic, in more ways than one. Judging by the cracking paint on the frame it may be a little bent now anyway... I'll post the pics in the morning in the shared google folder I have created. More good news, Pro Taper KX High bars were installed at the same time as the skid plate (without hand guards as yet since they are larger) survived well and un-injured. I have to believe that these bars are as tough as everyone says now.
Just in case anyone knows, I was trying to take the short 5 mile version of Srvc rd 393 from the Beeline highway down to Bartlett Lake in the Tonto NF. The 20 mile long version of that road which starts at the top of Mt Ord looks great and certainly pedestrian (and more enjoyable!) compared to where we last week. I'll let you know in a couple weeks!
AZDavis is offline   Reply With Quote
Old 02-18-2013, 05:48 PM   #3302
Demar39
Demar39's Avatar
Oddometer: 299
Originally Posted by jsmithy View Post
These are model 44s. I used the two top bolts for the headlight shroud. They barely fit without rubbing the turn signals and are able to point straight ahead. I did have to buy an extra flanged washer for the left side to get a solid mount. They have not moved since I put a little blue thread locker on them.
Parts needed were two longer bolts and one flanged washer.
Did you need to install a relay when you added these lights?
La Dolce Vita 15 is my limit on schnitzengruben.
2012 Stelvio NTX
2010 Bonneville T100
Demar39 is offline   Reply With Quote
Old 02-18-2013, 07:45 PM   #3303
DirtyBlackIrish
DirtyBlackIrish's Avatar
Oddometer: 153
WOW! Good thing you had it on there. Good thing your alive. I had mine out today just running in the rain. It's finally warming up some up here. Can't wait for the pics.
Semper Fidelis
DirtyBlackIrish is offline   Reply With Quote
Old 02-18-2013, 09:57 PM   #3304
CRFSoCal
Oddometer: 43
Originally Posted by gaan View Post
According to Best Dual Sports, it's the only Q4 blue titanium with the carbon end cap that FMF makes. I also have the Powercore but it doesn't look as nice. ;) I'm in Walnut.
Nice!! I am located in Glendora.
CRFSoCal is offline   Reply With Quote
Old 02-18-2013, 11:19 PM   #3305
cat
cat's Avatar
Oddometer: 1,323
Thumb
hi :) Please show us more pics. :) What bracket did you use? How did you do the wiring?
Model 44, is that "spot" or "flood"?
cat is offline   Reply With Quote
Old 02-19-2013, 09:50 AM   #3306
Avi8tor
ADV Poser
Avi8tor's Avatar
Oddometer: 218
I can take a few pics, but I just used the stock light bracket, that came with the lights with longer bolts in the top two bolt holes of the headlight shroud. It was a simple installation. I also had to buy another flanged nut for the left side...it does not have one in the stock form.
The Model 44s are floods.
I did. Eastern Beaver 3CS that also powers heated grips and two Powerlets.
CURRENT: None
PAST:
2013 CRF250L - 2009 DL650 - 1997 GL1500SE - 2005 DR-Z400S - 2008 DL650A - 2008 ST1300 - 2009 KLR650 - 2002 DR-Z400S - 1987 RM 250 - 1980 KD-80
Avi8tor is offline   Reply With Quote
Old 02-19-2013, 02:10 PM   #3307
LillaMan
n00b is okay by me.
LillaMan's Avatar
Oddometer: 39
My next bike!
I am so excited... I have found the bike I have been looking for since I started riding in the late 70s... Honda CRF250L.
Don't fear your ignorance - live it, embrace it, write about it.
An American copywriter in Sweden
LillaMan is offline   Reply With Quote
Old 02-19-2013, 03:36 PM   #3308
kubiak
Oddometer: 4,829
they are great bikes and great price too!
Old 02-19-2013, 03:57 PM   #3309
Wallachian Spikes
Wallachian Spikes's Avatar
Oddometer: 937
I'm sure this has been beaten to death but, how much can the 250 L be lowered. I'm thinking about getting one for my 16 year old daughter. It doesn't look like much foam can be cut from the seat.
Wallachian Spikes is offline   Reply With Quote
Old 02-19-2013, 04:05 PM   #3310
Oldtimer
Oddometer: 376
Koubalink.com sells a 1 3/4 lowering link and Seat Concepts has a one inch lower seat.
Oldtimer is offline   Reply With Quote
Old 02-19-2013, 04:09 PM   #3311
klondike300
klondike300's Avatar
Oddometer: 107
Looking at putting on my Trackside 12 volt outlet. Was wondering though if getting a plug that matches my tender plug and just use it when needed is smarter. Seems like the one on my KLX drained the battery quicker.
Also, would it be smart to add a fuse inline or just bolt straight to the battery?
klondike300 is offline   Reply With Quote
Old 02-19-2013, 04:15 PM   #3312
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,219
I would be hesitant to drop it more than an inch, otherwise you risk the rear wheel bottoming into the fender. A revised rear shock, once available, can be set to limited travel so you can drop it more, but until then...
On my KLX250S, I did the 1" drop with lowering links, and got the rest of it by having a custom seat made. I got easily 2" (maybe 3) from that.
Rob
'12 Suzuki V-Strom DL650
'96 Suzuki DR650
'92 Yamaha TW200
Rob.G is offline   Reply With Quote
Old 02-19-2013, 04:32 PM   #3313
AZDavis
Oddometer: 9
Skid plate saved the day and... is my frame bent?
https://docs.google.com/file/d/0B4LX...pNVWJCSnc/edit
Have I finally figured out how to successfully post pics in this treasured forum?
Old 02-19-2013, 04:36 PM   #3314
Lapchik
Tinkeritis posterboy
Lapchik's Avatar
Oddometer: 362
I'm kinda new to dirtbikes. Have owned fourwheelers, but none had the big front brake line loop like the CRF250L. Just wondering what the purpose of that is.....other than catching tree branches.
Lapchik is offline   Reply With Quote
Old 02-19-2013, 04:56 PM   #3315
hicRhodus
Oddometer: 15
Just tried the lowering route with my CRF250L to see if it could fit the wife but even with the Kouba link and 'low' version of the seat concepts seat it was still too tall for her (she's 5'1").
In any case, as far as shaving/lowering the seat just be aware that it effects the seat to foot pegs ratio and knee/hip angle - not for the better in my opinion. I rode the bike for a while this weekend with only the 'low' seat concepts seat installed and didn't care for the cramped feeling in my legs/hips (I'm 5'8"). Obviously someone else might be fine with it...just something to keep in mind.
P.S. Anyone want to buy a brand new (less than 10 miles) Kouba link for the CRF250L? :-D
hicRhodus is offline   Reply With Quote
Times are GMT -7.   It's 04:12 AM.
