Old 02-28-2013, 11:51 AM   #3481
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,164
Originally Posted by Ed@Ford View Post
Got a question. To fill the tank, it looks like the zipper unzips from the front left, down the side, then at the rear unzips further from L to R allowing the tank bag to flop to the left for gas cap access. If the bike is on the sidestand, does the tankbag want to flop back into place while filling the tank? Since the CRF has those silly bars across the fill hole, I use 2 hands on the gas filler to make sure the gas flows into the tank and not all over everything. Any commentary on your experiences fueling with this tank bag?
I have this bag on my DR650 (and use it on my KLX250S). It's awesome. I just unzip it partially and flop it over. It doesn't want to flop back over at all.. hang hangs down pretty low, and with the stuff IN the bag, it adds "ballast." I would expect it'd be just as good for the LRP.
Rob
'12 Suzuki V-Strom DL650
'96 Suzuki DR650
'92 Yamaha TW200
Rob.G is offline   Reply With Quote
Old 02-28-2013, 12:10 PM   #3482
SAPB
SAPB's Avatar
Oddometer: 1,511
Originally Posted by kiwi5 View Post
Yeah, I know it's a debatable subject but does anyone pay attention to "carefully" breaking in the LRP during the first 1000K, or do you just ensure to vary the speed and thrash it?
Everybody is all over the place on this subject, but it has been pointed out that Honda knows a thing or two about small engines. Might not be a bad idea to follow the break in period advice on page 10 of the owner's manual. Just my 2
C14 - CRF250L, always cleaned while it's raining
CRF250L Service Manual http://www.hondampe.com.au/docs/owni...F250L13_OM.pdf
SAPB is offline   Reply With Quote
Old 02-28-2013, 01:07 PM   #3483
radiation
Oddometer: 7
Ok this may have already been covered, forgive me. I'm 6ft and 250lbs, anyone here that size with one? How does it do, or buy a bigger bike? I should be back in the 200 range before I purchase but if the right deal came up I'd buy now.
on
Sent from my SPH-L710 using Tapatalk 2
radiation is offline   Reply With Quote
Old 02-28-2013, 02:18 PM   #3484
emreturkeli
emreturkeli's Avatar
Oddometer: 120
Do you think it's possible to combine Cycra and Highway Handguards parts this way?
- Buying the Center Reach Bar version of Cycra HandGuards
- and mounting it to the Fancy TopClamp of Highway Handguards?
Because I really like the bar and the plastic guard design of Cycra, but hate the idea of clamps in the center of my handlebar, on the other hand I again love the topclamp idea of Highway hand guards...
I hope somebody will confirm this..
PS: by the way I'm about to get offended by not getting any reply for my big first message...
Emre Turkeli
"Specialist"
ARh-
emreturkeli is offline   Reply With Quote
Old 02-28-2013, 02:48 PM   #3485
miles44
miles44's Avatar
Oddometer: 17
So in a previous post I noted that my new Lrp was having excessive head shake. Well the bike has accumulated 1400 miles and I am posting to say the problem is getting worse. I've checked the tire pressure but found that it is within spec. And at this point I'm not sure what to check. One thing I do want to note is that the headshake only happens when there is a car n front of me and I'm in their "backdraft". The bigger the vehicle the worse the shaking. If there is no one in front of me the bike rides smooth. I'm thinking maybe I should take it to the dealer I bought it from.
Any insight would be greatly appreciated.
2013 Honda crf250l
miles44 is offline   Reply With Quote
Old 02-28-2013, 03:08 PM   #3486
Ed@Ford
Oddometer: 1,583
I'd suggest reading over chapter 16 of the service manual regarding proper tightening of the fork legs, front axle and the steering bearings...on page 16-27 they discuss steering bearing pre-load....never seen that in other service manuals of bikes I have owned....they seem to want the head bearings pretty snug
Ed@Ford is offline   Reply With Quote
Old 02-28-2013, 03:09 PM   #3487
gnath9
gnath9's Avatar
Oddometer: 260
on
I weigh in at about 195 and my boy is about 110 and he rides with me all the time. The bike pulls just fine with both of us on it.
gnath9 is online now   Reply With Quote
Old 02-28-2013, 04:02 PM   #3488
roundtripping
Adventourist
roundtripping's Avatar
Oddometer: 1,702
Is this your first bike? What your describing seems pretty normal to me.
Sent from my Nexus 4 using Tapatalk 2
12 F658GS
13 Honda CRF250L
My SPOT Tracker
roundtripping is offline   Reply With Quote
Old 02-28-2013, 04:50 PM   #3489
clfarren5944
Oddometer: 41
My KLR's were notorious for approaching "tankslapper" conditions. Easiest fix I found was to either loosen your grip on the bars or take one hand off. Always worked for me.
Chris
clfarren5944 is offline   Reply With Quote
Old 02-28-2013, 05:32 PM   #3490
BlueLghtning
Riding is my passion
BlueLghtning's Avatar
Oddometer: 5,102
on
I'm 6'4"/250lbs and my ride is the WR250R, but we have a CRF250L for my wife. Weight wise, there's no issues; the 250's handle that just fine. The CRF is a "smaller cockpit" though compared to the WRR with a much smaller seat to footpeg height and of course lower to the ground. I could set up the CRF to fit me with some bar risers, but the biggest issue for me would be the seat to footpeg height which feels very cramped.
BlueLghtning - Follow me on my SPOT Messenger
Mine: 09 DL650, 08 WR250R,
Hers: 07 Ninja 650R, 13 CRF250L,
Smugmug Pics - Save $5 <-- Click Here
BlueLghtning is online now   Reply With Quote
Old 02-28-2013, 05:34 PM   #3491
BlueLghtning
Oddometer: 5,102
Chris
I would wonder too if you are just "holding on too tight" and allowing the wind buffeting from being behind a vehicle to pass through you and into the bike. If you are only getting it while behind a vehicle, it boils down to something in the wind that is affecting the bike. If you don't have a windshield and don't have big luggage, then its you.
Old 02-28-2013, 05:37 PM   #3492
miles44
miles44's Avatar
Oddometer: 17
I've tried loosening my grip n it makes no diff. I'm gonna check out the Manuel out n see If nything needs adjustment.
2013 Honda crf250l
Old 02-28-2013, 05:48 PM   #3493
kiwi5
Oddometer: 368
Might pay to try a supermoto front fender- made a huge difference on my DR650 when I got rid of the big floppy OEM front fender....
kiwi5 is offline   Reply With Quote
Old 02-28-2013, 06:31 PM   #3494
gnath9
gnath9's Avatar
Oddometer: 260
here is a good old thread on "head shake"
Old 02-28-2013, 06:45 PM   #3495
Boismj03
Boismj03's Avatar
Oddometer: 39
Here are a couple of pics of my setup...filled it today sitting on the bike with gloves on...no problem...unzip 2 sides fill er up. These are taken with the bike on the side stand. Just dont forget to zip the top up so all your shit does'nt fall on the ground from the main bag!
Boismj03 screwed with this post 02-28-2013 at 07:11 PM
Boismj03 is offline   Reply With Quote
Times are GMT -7.   It's 08:55 AM.
