Old 03-08-2013, 11:46 AM   #3661
'Flagger
..this space for rent..
'Flagger's Avatar
Oddometer: 2,429
Originally Posted by SAPB View Post
Good point. Just looking at maintenance interval, probably falls under suspension, Inspect (clean, adjust, lubricate, or replace if necessary), at 8, 16, and 24K. What do you figure, 45 minutes to get it off?
Just to remove it? Less than that. The following is from memory... be gentle.
1) remove wheel
2) unscrew brake clips
3) hang caliper or let rest on floor
4) remove lower portion of chain guide or pop master on chain if you've installed one.. i hate messing with this so go after the guide
5) remove link bolts
6) remove pivot bolt
I've already binned my chainguard so add that if you need/want to remove it each time.
- B
Proud to be an inmate of AdvRider.
'Flagger is offline   Reply With Quote
Old 03-08-2013, 11:51 AM   #3662
'Flagger
'Flagger's Avatar
Oddometer: 2,429
Originally Posted by Ed@Ford View Post
FLAGGER: You might be right....also depends on the bike's usage...if you like cavorting in swamps and muck, having zerks is worth it....or if you have an XR400R that has a segment of the swing arm bolt that can NEVER be properly greased, annual disassembly is the only solution. If you have a KLR that gets high mileage and a huge variety of road conditions...zerks are high value.
If you do plan to grease with the EXPENSIVE high content moly grease specified, start hunting for it...it's hard to find and 3 or 4 times the $ of conventional grease. It's WAAAAY different formulation from the popular boat trailer hub grease most guys use.
Not dismissing zerks completely... had them on a XR650L. Useful... but not a panacea... still should to remove swingarm every so often for inspection.
- B
Old 03-08-2013, 12:44 PM   #3663
Spud Rider
Spud Rider's Avatar
Oddometer: 3,855
Originally Posted by kiwi5 View Post
Thanks for the torque specs, that was my next query! Now, anychance of a brief step-by-step?
I've got to grease the lower shock linkage on my recently acquired, CRF250X. Here are two good videos which illustrate the process, which is very similar on most dirt bikes. The first video demonstrates greasing the suspension on the Honda CRF250R.
The second video also presents some good tips, and demonstrates greasing the suspension on a Suzuki dirt bike.
Spud
Old 03-08-2013, 12:58 PM   #3664
callison
callison's Avatar
Oddometer: 120
Read the comments for that second video, pretty funny...
Cory
callison is offline   Reply With Quote
Old 03-08-2013, 01:05 PM   #3665
SAPB
SAPB's Avatar
Oddometer: 1,661
Spud
Did you notice after inhaling the contact cleaner, is when he went into slow motion? Sorry couldn't resist. Thanks Spud, always great info coming from you!
C14 - CRF250L, always cleaned while it's raining
CRF250L Service Manual http://www.hondampe.com.au/docs/owni...F250L13_OM.pdf
SAPB is offline   Reply With Quote
Old 03-08-2013, 09:51 PM   #3666
kiwi5
Oddometer: 385
Excellent info, I am still not sure what the disassembly sequence is ( due to watching the video on my iPhone ) but I will try to figure it out by watching on the home PC later...
kiwi5 is offline   Reply With Quote
Old 03-08-2013, 09:57 PM   #3667
Irish769
Irish769's Avatar
Oddometer: 88
EJK Installation
I'm ready to install my Dobeck EJK. I think it's possible to do without lifting the tank. My question is, can anybody tell me how the existing connectors come apart? I looked at Rick Ramsey's photos but can't tell how the top (gray) connection separates from the bottom (blue) half. Do you squeeze a particular area of the top connector? There's not much room to work and I may need my wife's small hands so any tips would be appreciated. If she breaks a nail ......
Lord help me!
2008 Concours 14 (Traded)
2004 Yamaha Roadstar
1975 KZ 400
2013 CRF 250L
2014 BMW GSW
Irish769 is offline   Reply With Quote
Old 03-09-2013, 04:16 AM   #3668
Thumper26
Oddometer: 15
I'm in...
Thumper26 is offline   Reply With Quote
Old 03-09-2013, 05:32 AM   #3669
SAPB
SAPB's Avatar
Oddometer: 1,661
Lord help me!
You can see how the gray one comes undone in Rick's 3rd pic, pinch the back part down to raise the front of it up over the part that sticks up on the blue part, and pull. Bet you'll have to take the tank off.
Old 03-09-2013, 05:49 AM   #3670
Kommando
Kommando's Avatar
Oddometer: 7,390
Lord help me!
Get your wife some Lee Press-Ons for her tiny fingers. Trim her stock nails down as close as comfortable, and put her on a protein-rich diet. Have her first practice on some similar connectors that are easier to access, until she can do it in the dark, blindfolded.
'Bet she has no problems getting that sucker apart! Remember to apply the Press-Ons for her after she cleans up. Some women really like having long nails, and feel somewhat incomplete without them.
Kommando is offline   Reply With Quote
Old 03-09-2013, 06:50 AM   #3671
streaks77
streaks77's Avatar
Oddometer: 65
I'm almost embarrassed to admit this now, but I was able to connect the EJK without removing the tank I did however remove a bit of skin doing so! Wasn't too bad, but tank off would sure have been a lot easier.
streaks77 is offline   Reply With Quote
Old 03-09-2013, 08:56 AM   #3672
Rocket123
Oddometer: 21
Just did my valve clearance today at 790 miles
Neither inlet or exhaust were out of spec.
Thanks for Lost's post for some guidance. In fact I didn't need to remove the tank, simply unbolt and rest sideways on the frame.
The rocker cover bolts were virtually hand tight only. As I don't have the manual yet, does anyone have the torque setting for these?
Rocket
Rocket123 is offline   Reply With Quote
Old 03-09-2013, 09:06 AM   #3673
SAPB
SAPB's Avatar
Oddometer: 1,661
Rocket
Cylinder head cover bolts? There's 2? 7 lbf/ft.
SAPB screwed with this post 03-09-2013 at 09:25 AM
Old 03-09-2013, 09:29 AM   #3674
Spud Rider
Spud Rider's Avatar
Oddometer: 3,855
...The rocker cover bolts were virtually hand tight only. As I don't have the manual yet, does anyone have the torque setting for these?
Rocket
Please don't use a torque wrench on those bolts. You risk breaking the bolts in the cylinder head if you use a torque wrench. Seven foot-pounds of torque is only hand tight. Just snug the bolts up; the cylinder head is not going to separate from the engine.
Spud
Old 03-09-2013, 09:34 AM   #3675
SAPB
SAPB's Avatar
Oddometer: 1,661
Spud
That makes sense, you're just squishing the rubber gasket a bit.
Times are GMT -7.   It's 12:07 AM.
