Old 03-28-2013, 05:57 PM   #4066
kb7tgr
Oddometer: 58
brake snake
Originally Posted by SAPB
Just thought of the route I'm going with the snake brake/shifter. Go to where they sell single guitar strings, the kind with a eyelet on the end. Put the end through loop to make a hangman's knot. Pull it tight over the shifter, and secure it with bailing wire (the kind we used to put where the spokes crossed, or similar), to make sure it can't back off. Drill a hole somewhere on your skid plate, nut and bolt from hardware store/Locktite, trim off excess. On the brake side, I'll drill a hole through the lever. Hey, if you know someone who plays, it's free, they're going to trash them anyway, except for the hardware. Leave a little slack, you won't even need a tuning fork. Hey, the blue bike guys have tuning forks on the tank.
19 cent worth of 1/16 inch cable and two crimp cable clamps at 19 cents a piece and the snake is installed. If ya break it you have bigger problems than a broken snake.
kb7tgr
Jim
kb7tgr is offline   Reply With Quote
Old 03-28-2013, 05:58 PM   #4067
SAPB
SAPB's Avatar
Oddometer: 1,583
Originally Posted by SugarDust View Post
Well as a guitar player - no matter what gauge guitar string, they aren't going to be stong enough - same with the bailing wire - my brake snakes appear to be braided steel(?) wire
I'll let you know if they hold up. I'm going with Ernie Ball .050 phosphor studio bronze. Maybe it should be a bass string. Could be a while, I'm not looking to intentionally hit something. They held up OK when Beluchi smashed that axe in Animal House. Anyway, at $1.15, it's worth a shot, errr a pluck. Oh well, CRF's only would only charge $40 to ship me a couple.
C14 - CRF250L, always cleaned while it's raining
CRF250L Service Manual http://www.hondampe.com.au/docs/owni...F250L13_OM.pdf
SAPB screwed with this post 03-28-2013 at 06:04 PM
SAPB is offline   Reply With Quote
Old 03-28-2013, 06:20 PM   #4068
Spud Rider
Spud Rider's Avatar
Oddometer: 3,785
Originally Posted by billfires View Post
Has anyone mounted a removeable top box yet? I am going to start riding the bike to work and need secure, waterproof storage, but I would like it to be easily removeable when not needed. I don't need a lot of capacity (change of clothes, lunch, and my portable radio). Thanks, Bill
I really like my J.C. Whitney Travel Trunk.
This travel trunk locks to a metal mounting plate, and is easily removed after you reach your destination, or return home. Unfortunately, J.C. Whitney no longer sells this item, so one needs to buy the equivalent travel trunk from eBay, or another vendor. If you decide to purchase a copy of this travel trunk, make sure you get a travel trunk with a metal mounting plate; the plastic mounting plates will fail.
Spud
Old 03-28-2013, 06:22 PM   #4069
SAPB
SAPB's Avatar
Oddometer: 1,583
Spud
Even if secured with a guitar string?
Old 03-28-2013, 06:39 PM   #4070
BlueLghtning
Riding is my passion
BlueLghtning's Avatar
Oddometer: 5,264
Originally Posted by SAPB View Post
The Givi, or Coocase, while more expensive, have the feature of the two red buttons you can see on the back. The top one opens it up, while the bottom one releases it from the base unit. Some of them have a handle incorporated , so you can carry it like a briefcase. I have a Givi top case on my street bike, made by Givi, sold as an accessory through Kawi. http://www.twistedthrottle.com/shop-...=3019&limit=48
That Coocase doesn't seem too badly priced, but I don't think that's actually a Givi case. Probably very similar to many of the knock offs. - http://www.twistedthrottle.com/cooca...on-matte-black
We have about 9 givi cases between my wife and I and really enjoy them, but they are pretty pricey and wanted to let the OP know of some cheaper knock off's if he didn't want to spend that much for a Givi.
BlueLghtning - Follow me on my SPOT Messenger
Mine: KTM 650 ADV (Katuki), 09 DL650, 08 Husky TE610, 08 WR250R
Hers: 07 Ninja 650R, 13 CRF250L
Smugmug Pics - Save $5 <-- Click Here
BlueLghtning is offline   Reply With Quote
Old 03-28-2013, 07:47 PM   #4071
Spud Rider
Spud Rider's Avatar
Oddometer: 3,785
No, I wouldn't use a guitar string to secure my loaded travel trunk.
My J.C. Whitney Travel Trunk has taken a lot of abuse for several years. I like it so much, I bought a spare when they were on sale for $48, delivered.
However, I do recommend the purchase of a travel trunk with a metal mounting plate. The plastic mounting plates will fail.
You can pack a lot of stuff in the large travel trunks, and they are very easy to remove for the evening, or for hiding in the brush while taking an impromptu, off road excursion.
These travel trunks are very handy when taking a multi-day excursion.
These travel trunks are also quite handy for grocery shopping, or running other errands around town.
Spud
Old 03-28-2013, 09:43 PM   #4072
gaw777
Oddometer: 59
Cycra Handguards
Anyone mounted the Cycra Series One Alloy Bar Pack hard guards with the triple clamp front mount system. Do they work together??
Like these:
http://store.cycraracing.com/seonealbarpa2.html
2010 ktm 690smc, 2013 crf250l
gaw777 is offline   Reply With Quote
Old 03-28-2013, 10:44 PM   #4073
cat
cat's Avatar
Oddometer: 1,323
Thumb
Spud Rider, is that Idaho?
When are you going to make a nice chain guide roller for the CRF-L?
cat is offline   Reply With Quote
Old 03-28-2013, 10:49 PM   #4074
Spud Rider
Spud Rider's Avatar
Oddometer: 3,785
Yes, the photos are from Idaho, Cat. Thanks for asking, but I'm out of the chain roller business.
Spud
Old 03-28-2013, 10:53 PM   #4075
CRFSoCal
Oddometer: 43
So I took the LRP on the freeway today and it wobbles a little. Is it the wind or the knobby tire?
CRFSoCal is offline   Reply With Quote
Old 03-28-2013, 11:23 PM   #4076
cat
cat's Avatar
Oddometer: 1,323
Question
Is the DRC tail light bracket made of steel or aluminum? (It looks like steel but in one of the catalog descriptions it says alloy.)
Old 03-29-2013, 12:13 AM   #4077
emreturkeli
emreturkeli's Avatar
Oddometer: 120
I'm pretty sure that mine was steel..
Emre Turkeli
"Specialist"
ARh-
emreturkeli is offline   Reply With Quote
Old 03-29-2013, 01:37 AM   #4078
cat
cat's Avatar
Oddometer: 1,323
ah ok, i thought so. So it is not much less weight than the original heavy bracket.
Spud, lovely place to ride.
The chain roller, maybe i'll get to making a chain guide that fits with bigger sprockets, and use the best roller wheel i can find - maybe.
CRFSoCal...
I think it's the tire. My KDX is really stable with more knobby tires, though. So i think it's just something with these tires.
Old 03-29-2013, 06:07 AM   #4079
tilliejacques
tilliejacques's Avatar
Oddometer: 404
Leo Vince exhaust pic
I emailed Leo Vince about the upcoming exhaust that tirebiter mentioned . They sent me a nice pic and said that it'll weigh 5.64 KG stock vs 2.82 KG (or 12.43 lbs vs 6.21 lbs for us less metrically inclined people ).
To start fitting my MoJavi, I had removed the white plastic and heat shield from the stock exhaust. It weighed just over a pound by itself fwiw if you want to somehow mount the stock heat shield on the aftermarket exhaust; I assume with pipe clamps or some such . There are standoffs on the stock pipe as well of course.
The Leo Vince is so pretty, kind of a shame to cover it up! No mention of db's so I hope that tirebiter, you can still persuade them to get a reading at their place.
11 Husky TE250
08 Beta Rev3 125
tilliejacques is offline   Reply With Quote
Old 03-29-2013, 06:43 AM   #4080
BlueLghtning
Oddometer: 5,264
It's mostly the rider and the wind affecting the rider. The wind hits the rider moving them around and allowing it to transfer back into the bike. When riding a small lightweight bike like the LRP, rider inputs have a lot of effect at higher speeds.
Now with that said, certain knobbies are less stable than others, but pay attention to your input to the bars and how relaxed you are or how much you are fighting the wind. Loosen up your grip on the bars and relax some. Lean into the wind so you aren't having to hold on to stay on the bike.
Times are GMT -7.   It's 01:47 AM.
