Old 04-08-2013, 06:06 AM   #4231
topping
Oddometer: 19
Originally Posted by Normsthename View Post
Hi Phil
Thanks for the Info, which exhaust did you actually fit?
Fancy one that's not too loud
Andy
Hi Andy sorry for the late reply, I went for the FMF Q4 and megabomb header.
Cheers
Phil
Honda CRF250L
topping is offline   Reply With Quote
Old 04-08-2013, 06:11 AM   #4232
callison
callison's Avatar
Oddometer: 120
Originally Posted by emreturkeli View Post
Exact same thing happened to a friend of mine, we took it to the service and they controlled and tightened all the screws, etc.. and said that if that's keep doing then we will go in more detailed.
But luckily it stopped!
Mine is doing the same thing, I'll snap a pic to illustrate later today. I plan on torquing the crank case bolts to spec this evening. Hopefully that sorts the issue out, if not I'll take it in to the dealer and let them dig into it.
Cory
callison is offline   Reply With Quote
Old 04-08-2013, 06:41 AM   #4233
Rocket123
Oddometer: 21
Unfortunately I managed to submerge my LRP save for the right handlebar in deep muddy water. After I had recovered the bike from the water (alone) I removed the side of the airbox and out gushed half gallon brown water. I removed the sodden airfilter and spark plug (which seemed dry) let the bike stand for a while and turned her over on the starter motor. The mud, ruts and water where too much and too far to push the bike to a main road so I kitted up started her on the second or third attempt and rode as gingerly as possible in 2nd for about a mile until to my relief I came to a metalled road.
The oil level glass looked like this!!
Fortunately I managed to freewheel down hill for a couple of miles to a main road and called for a recovery truck to get me home:
......anyway I drained the oil and removed the oil filter replaced with new two or three times just turning the engine over with the starter motor, but couldn't get rid of the white emulsioned oil. I mixed a 50/50 mix of oil and kerosene ran this through on the starter motor and this did the trick so I then added new oil/oil filter and started her up and idled for 10-15 minutes, drained down and was 98% clean. Carried out another refill and new filter took the LRP for a spin. It ran perfectly and the oil was clean in the glass window. I changed the oil/filter once more and this morning came to work. Still managed 75 mph, oil looks like new, small amount of water in the breather but other than that seemingly no damage!!
Lucky? Or just good Honda engineering?
I am sure the water came into the engine via the crankcase breather which is the lowest pipe from the airbox to the engine. I am wondering whether it might be possible to fit a one way valve.
Rocket
Rocket123 is offline   Reply With Quote
Old 04-08-2013, 09:28 AM   #4234
EEKAMOUSE
EEKAMOUSE's Avatar
Oddometer: 369
Originally Posted by xjon View Post
[/IMG]recently purchased a 250l and had a great day on the trail. However dismounting from a hitch rack at home was its first fall (with me) and broke the lever clamp. I know I can just replace the clamp part but I would like to replace the levers with ASV or something (2-3 fingers). I do not know what I need specifically since Ive never looked at replacing one before. I got confused with all the selections such as with or with out hot starts???
Also I would need a mirror mount also and was thinking of folding ones. Any recommendations?
I would also like to get the beefy hand guards and would like to know if anyone here has a combination of all of these together and if they like or dislike the setup.
thanks in advance.
Righteous stunt metal clutch in IMO is best just get rid of the ignition cut out switch on the factory lever.
Sent from my PG86100 using Tapatalk 2
EEKAMOUSE is offline   Reply With Quote
Old 04-08-2013, 10:32 AM   #4235
Turk
'Bab Man
Turk's Avatar
Oddometer: 126
Originally Posted by SAPB View Post
Green is ground. Green/Yellow is brake light.
Cheers fella, all wired up and fitted now
Turk is offline   Reply With Quote
Old 04-08-2013, 12:03 PM   #4236
RayMurdock
Oddometer: 19
Question
Originally Posted by kiwi5 View Post
Highly recommend you do the basic snorkel & spark arrestor screen removal with you EJK - you will need the extra air to compliment the extra fuel the EJK will give the engine. I absolutely noticed a performance increase with the airbox mods. But then again, was I influenced by the extra noise?? I will call EJK and report back.
Thanks for the advice. The 'basic snorkel' removal is that the complete snorkel or only the part which is on the inside?
RayMurdock is offline   Reply With Quote
Old 04-08-2013, 01:24 PM   #4237
SAPB
SAPB's Avatar
Oddometer: 1,663
Rocket
If you didn't hit the kill switch, then the bank angle sensor killed it, preventing water getting sucked in. THAT would have been expen$ive.
C14 - CRF250L, always cleaned while it's raining
CRF250L Service Manual http://www.hondampe.com.au/docs/owni...F250L13_OM.pdf
SAPB is offline   Reply With Quote
Old 04-08-2013, 01:38 PM   #4238
kiwi5
Oddometer: 385
Try just removing the internal portion (with backfire screen removed as well). That should be plenty, you can try removing the snorkel completely but that only seems to add more noise without a noticeable increase in power.
kiwi5 is offline   Reply With Quote
Old 04-08-2013, 02:11 PM   #4239
Rocket123
Oddometer: 21
I hit the kill switch as I'm sure the sensor didn't kill the engine. I've dropped the bike a few times and had the engine running whilst on its side so I'm not sure it works quite so instantly. If you don't switch the ignition off and back on after a fall the starter motor spins but no start.
Rocket
Old 04-08-2013, 02:15 PM   #4240
SAPB
SAPB's Avatar
Oddometer: 1,663
Mods
I was thinking of getting the SpeedoDRD since I've done the 13t, and also, every tire swap is going to effect the mph. I checked on Ramz' site for info, and he has instructions on getting the evap. can off, but it's a blue link to get you there, I never saw this before. He's done modding to the stock exhaust, and quieted down the FMF here: http://rickramsey.net/CRF250Lcccmods.htm
SAPB screwed with this post 04-08-2013 at 03:33 PM
Old 04-08-2013, 02:18 PM   #4241
SAPB
SAPB's Avatar
Oddometer: 1,663
Rocket
Quick thinking! I've heard the stories of people who have sucked water into the cylinder, not quite as easy to compress as air/gas.
Old 04-08-2013, 03:01 PM   #4242
callison
callison's Avatar
Oddometer: 120
Focus is rather shitty but you can see the dark area spreading out from the crank case gasket. Getting ready to go read up on the torque spec then clean things up.
Cory
Old 04-08-2013, 04:33 PM   #4243
Rocket123
Oddometer: 21
u
It becomes a natural reaction to hit the kill switch when you know of the consequences of keeping the engine running. Hydraulic lock is common place in the UK with the amount of the water we've had this year.
Incidentally I am collecting a thimble full of water in the breather each ride, so there is still some water in the system, plus some emulsioning on the filler cap but the engine oil is still as clear as new.
Rocket
Old 04-08-2013, 05:48 PM   #4244
Boismj03
Boismj03's Avatar
Oddometer: 119
Ejk
Does anyone have the EJK base settings from Best Dual Sports Fuel controller? Is it different than the numbers on Rick Ramseys? 3 3 6 5 4 4.5
1st annual MU Adventure ride!
http://advrider.com/forums/showthread.php?t=1072012
Boismj03 is online now   Reply With Quote
Old 04-08-2013, 06:15 PM   #4245
E365
Oddometer: 28
Am I crazy for thinking I want to sell my 2001 BMW F650GS for one of these? The CRF250L is 100lbs. lighter - I like small and light. The F650GS just feels so heavy at times. This still has fuel injection which I love, plus even better MPGs. This appears to have better suspension (or am i wrong?) and more travel. Plus, I really don't care about power or going fast, as long as I can do 70mph reasonably for short stretches. The taller seat height is appealing too.
I don't travel much. Just tool around town and maybe go for 3 hour max rides. I carry no passengers and only need to carry minimal cargo. No multi day trips for me.
Would I miss my F650GS?
E365 is offline   Reply With Quote
Times are GMT -7.   It's 06:46 PM.
