Old 05-16-2013, 07:16 PM   #4771
Auto-X Fil
Oddometer: 693
Buzzing is usually the relay, but could be a bad connection. I had a Suzuki ATV that buzzed instead of starting, and it turned out to be a loose battery lead.
Auto-X Fil is offline   Reply With Quote
Old 05-16-2013, 09:35 PM   #4772
Fytclub
Oddometer: 17
Thanks guys, I'll give it a try.
Fytclub is offline   Reply With Quote
Old 05-17-2013, 12:18 AM   #4773
Wanderlustking
___
Oddometer: 8
Is there any Domestic
sites i could order a shift lever from?
Ive seen that the 250l has the same crf150r is there any confirmation on that? Is there a specific year that works?
I've combed through a bunch of posts about it but couldn’t find a confirmation.
Thanks yall.
Wanderlustking is offline   Reply With Quote
Old 05-17-2013, 03:54 AM   #4774
Dirtbikekid98
Oddometer: 2
Thanks yall.
i could not find a website but im sure someone on here has found one but here is one on ebay that i saw someone using
http://www.ebay.com/itm/RFX-Forged-G...item3ccf62f820
Dirtbikekid98 is offline   Reply With Quote
Old 05-17-2013, 04:05 AM   #4775
Dirtbikekid98
Oddometer: 2
here is a shift lever that i have seen someone using
Old 05-17-2013, 04:35 AM   #4776
Ed@Ford
Oddometer: 1,664
Originally Posted by Fytclub View Post
When I went to start my bike today I got a buzzing sound from the little black box near the battery and no turn over. I took apart the box and the fuse looks good. Battery is good too as it's been on a tender and showed full charge.
Anyone know what it may be?
check battery voltage...sounds like you have a low or near dead battery...if you're down under 11.5 volts or so, your battery is dying.....or has lost it's charge
Ed@Ford is offline   Reply With Quote
Old 05-17-2013, 08:01 AM   #4777
mulausk
Oddometer: 7
Thanks yall.
I am waiting on the MSR folding shift lever from motorcycle-superstore.com (SKU#162068) It is indeed the one that fits the crf150r. $23.99 + S/H. There is a picture of it in the CRF250L Adventure Travel thread.
(I mistakenly ordered the one that fits the crf250r initially, which does NOT fit the crf250l.)
mulausk is offline   Reply With Quote
Old 05-17-2013, 10:39 AM   #4778
Buckshot77
Buckshot77's Avatar
Oddometer: 42
Here's my shifter
Buckshot77 is offline   Reply With Quote
Old 05-17-2013, 10:41 AM   #4779
Buckshot77
Buckshot77's Avatar
Oddometer: 42
Reusable air filter
Old 05-17-2013, 02:08 PM   #4780
mulausk
Oddometer: 7
Originally Posted by Buckshot77 View Post
Here's my shifter
Yep, that be the one. Came today, already on the bike. Thanks for your post; it inspired me to pull the trigger on that shifter.
Old 05-17-2013, 02:20 PM   #4781
MBRedline
Oddometer: 14
I was told by my local dealer that you can not push/bump start these bikes due to the clutch switch.
Has anyone tried to bypass the clutch switch like it has been done on the side stand switch?
I know without the clutch switch that there is the possibility of overloading your starter by starting in gear, but is there any danger in roll starting these bikes other then that?
Sent from my rooted XT912 running AOKP Aviator
MBRedline is offline   Reply With Quote
Old 05-17-2013, 03:18 PM   #4782
Buckshot77
Buckshot77's Avatar
Oddometer: 42
I've stalled while moving
Let the clutch out and starts so ???
Can't see why not
Try it
Buckshot77 screwed with this post 05-18-2013 at 01:54 AM
Old 05-17-2013, 04:10 PM   #4783
jsonder
Tired Old Fart
jsonder's Avatar
Oddometer: 535
Doesn't the 250L have an electric fuel pump? I would imagine that a really shot battery wouldn't pressure up the fuel system. That would prevent bump starting the bike.
John
2009 Honda CRF230L (L'il Red Piglet)
2014 Honda CB500XA (Daily Rider)
jsonder is offline   Reply With Quote
Old 05-17-2013, 05:16 PM   #4784
Buckshot77
Buckshot77's Avatar
Oddometer: 42
That's right,a weak battery that will start and run another bike will not run this system.
Needs good juice
Haven't tried on this bike
But I just sold a fi hd it's battery would run another bike no problem..boosted the fi bike with the weak battery and as soon as booster battery was unhooked bike would die.
Sold the bike kept the battery it still works fine on a non fi bike
Old 05-17-2013, 08:28 PM   #4785
positron007
Oddometer: 66
Got the bike
Had it for a little while now. Definitely happy with the bike. A lot of fun with potential for improvements.
Here is just a small part of a ride on some dirt roads.
http://www.youtube.com/watch?v=W4o7GspCHXg
positron007 screwed with this post 05-17-2013 at 08:52 PM
positron007 is offline   Reply With Quote
Times are GMT -7.   It's 05:14 AM.
