Old 07-03-2013, 06:07 PM   #5176
jab1026
jab1026's Avatar
Oddometer: 92
Originally Posted by gore-tx View Post
I've been lurking for a while now. Today I sat on one. I'm thinking...I'm thinking...
Perfect bike for you mate.....
jab1026 is offline   Reply With Quote
Old 07-03-2013, 06:55 PM   #5177
r6realtor
Oddometer: 251
My new 2014 CRF250l with my wr250r supermoto
r6realtor is offline   Reply With Quote
Old 07-03-2013, 08:37 PM   #5178
Wargasm
Wargasm's Avatar
Oddometer: 209
couple things
1. Has anybody seriously looked into swapping out the front end for a CRF250X or 450X front end, no speedo take off so should be either a straight forward bearing swap or stem swap.
2. Has anybody looked at CBR250 wheel axle sizes for a motard setup? Might not be but could very well be same axle sizes therefore quick swap for back road hooning.
3. Where oh where can I get a stiffer rear spring, this poor thing is gonna die on me soon. NOt too concerned with dampening yet as I'm used to old bikes with crap suspensions anyway.
Wargasm is offline   Reply With Quote
Old 07-03-2013, 09:09 PM   #5179
nhrallyL
Oddometer: 37
Been debating on one of these for a few weeks haha can't find one in stock anywhere so far up here haha
nhrallyL is offline   Reply With Quote
Old 07-04-2013, 02:35 AM   #5180
Turk
'Bab Man
Turk's Avatar
Oddometer: 119
Originally Posted by SAPB View Post
That rear tire looks just about like mine was before I replaced it. Cuts in various places, that didn't quite go through.
They have lots of small rips and are shredded a fair bit, after only 2k kms...
Turk is offline   Reply With Quote
Old 07-04-2013, 03:21 AM   #5181
SAPB
SAPB's Avatar
Oddometer: 1,622
http://www.cycletrader.com/New-or-Us...014&zip=03887&
I know Razee had one last week. http://www.razeemotorcycle.com/new.asp
C14 - CRF250L, always cleaned while it's raining
CRF250L Service Manual http://www.hondampe.com.au/docs/owni...F250L13_OM.pdf
SAPB is offline   Reply With Quote
Old 07-04-2013, 03:23 AM   #5182
SAPB
SAPB's Avatar
Oddometer: 1,622
I managed 3,600 on mine, but sadly only maybe 20% off road. The D606 has way more bite in dirt. 120/90-18.
Old 07-04-2013, 03:38 AM   #5183
SAPB
SAPB's Avatar
Oddometer: 1,622
Don't think too long, I missed the 1st one my dealer had, an put a deposit to get the next one, 14 week later. They got a 3rd one, and that went right away.........
Old 07-04-2013, 08:59 AM   #5184
EEKAMOUSE
EEKAMOUSE's Avatar
Oddometer: 341
Question does the fmf powercore and q4 come with an adapter to fit the stock header if im not using an aftermarket header?
EEKAMOUSE is offline   Reply With Quote
Old 07-04-2013, 10:32 AM   #5185
siyeh
Lawn Nazi
siyeh's Avatar
Oddometer: 1,673
Funny you should mention this. I just spooned that exact tire on this morning. I used my trailer for a work station.
I got 2500 miles out of the stock rear. It was getting pretty bad. I am now ready for a three week trip to Colorado. I think the front will make it if not I can find one out there I am certain.
The bike does lean a little more into the kickstand but not enough to cause any trouble I hope.
siyeh is offline   Reply With Quote
Old 07-04-2013, 11:38 AM   #5186
SAPB
SAPB's Avatar
Oddometer: 1,622
More of a "song" coming off the tire now. Hard braking with the rear on pavement, you can hear the knobs springing back to position at low speed. I've heard they are not so great on wet pavement, so I'm taking it easy until I get used to it. Also heard they tend to flat spot if you do a lot of street. I've got to figure out air pressure also, it's different with the TUbliss system. 91 degrees here now, I was out early to beat the heat. I carry one of these in my Wolfman tank bag in case it's soft off road, or better yet, flip the KTM mirrors in, and lean it up against a tree. http://www.lowes.com/pd_55761-53911-...7C1&facetInfo=
SAPB screwed with this post 07-04-2013 at 11:50 AM
Old 07-04-2013, 12:07 PM   #5187
SAPB
SAPB's Avatar
Oddometer: 1,622
SpeedoDRD
When I did the 13t swap, I did the GPS/trip gauge method, and re-programmed it, then re-checked it with the Garmin, and it was off. Did it again, and it was good. Just this week, with the D606 swap, I did the GPS/trip thing again. It seemed to be pretty close on mph, but I had Garmin/trip 82.0/79.1. Plugged that into the website, they said plus (green) 3.7, and then, it was way off. Did the Garmin/trip thing again,and it was Garmin/trip 66.1/79.1 and it indicated plus (red) 8.1. Just programmed it, we'll see. Too fn hot to ride now, I'll go out early tomorrow. I'm thinking the odo/speedo are off at different rates. I'd rather have accurate speedo, since the LEOs are out in force with radar to bring in extra funds to the town budgets.
Old 07-04-2013, 12:29 PM   #5188
callison
callison's Avatar
Oddometer: 120
I'm not sure if it comes with an adapter, but I just took my stock header off and there was an adapter in the FMF silencer, I bought it with the FMF installed by the dealer. You're welcome to it if you don't see one included when you get your silencer.
As an aside, I would recommend using some of the hi-temp RTV on the joint between muffler and adapter, and adapter and header. I had a lean pop on decel while riding, pretty sure it had to do with air getting sucked in at this joint. When I installed the FMF header I sealed this joint, I think my bike is quieter now with full FMF exhaust than it was with the stock header and FMF silencer.
Cory
Cory
callison is offline   Reply With Quote
Old 07-04-2013, 12:56 PM   #5189
dalehazelton
Oddometer: 47
Agrisupply Manual Tube on CRF?
I did a search and didn't see this come up - has anyone mounted the Agrisupply manual tube on their LRP yet? I ordered a few (you might as well get a bunch - they'll charge you a small fortune to ship just one) and am trying to think of the cleanest way to install. I don't really want to take off the bikes locked tool holder as that white plastic completes the body work nicely. I thought of extending a flat panel of black plastic (cutting board or corian?) under that box so I have a surface to mount the tubes ears onto. If I had the Wolfman million dollar rack things would be simple. Any photos of what you did would be great.
dalehazelton is offline   Reply With Quote
Old 07-04-2013, 01:16 PM   #5190
xjon
Pedantic Bastard
xjon's Avatar
Oddometer: 387
dune riding?
anyone has taken their lrp to sand dunes? Thinking about taking mine out to Oceano dunes in Pismo Beach CA. wondering about power issues or paddle tires with this ride.
thanks
06 1200GS (since day 1)
13 CRF250L (3/2013)
xjon is offline   Reply With Quote
Times are GMT -7.   It's 04:05 AM.
