Old 07-29-2013, 07:24 PM   #5581
Wargasm
Wargasm's Avatar
Oddometer: 195
Originally Posted by Kray View Post
Juice,
IMS sells a 3.1 gallon fuel tank upgrade [/URL].
The better part of $300 for an increase of only 1 gallon, and it's pre-order so you could get it in a week or ten years. not much of a good deal.
Wargasm is offline   Reply With Quote
Old 07-29-2013, 07:38 PM   #5582
siyeh
Lawn Nazi
siyeh's Avatar
Oddometer: 1,644
Speaking of seats and Wally World pads, I just did 1069 miles in three days on a Seat Concepts low version on my CRF.
No pad
No sheepskin
No butt burn
No numb ass
love that seat it fits me like a glove
siyeh is offline   Reply With Quote
Old 07-29-2013, 08:00 PM   #5583
siyeh
Lawn Nazi
siyeh's Avatar
Oddometer: 1,644
Just finished packing the back end of a Toyota Tacoma for an 18 day wander in Colorado
At sun up, gonna hook a trailer behind it and throw a bike on the trailer and head west
I will let you guys figure out which bike I am taking
*hint* I gonna ride a ton of dirt
Old 07-30-2013, 12:32 AM   #5584
Woody2627
Skinny Decaf Latte Thanks
Woody2627's Avatar
Oddometer: 1,014
Juice,
IMS sells a 3.1 gallon fuel tank upgrade here.
Seat Concepts makes a comfy seat replacement that doesn't raise the bike's seat height at all here.
That has been on pre-order for 6 months, but no sign of an actual tank..:
Woody2627 is offline   Reply With Quote
Old 07-30-2013, 04:14 AM   #5585
Woody2627
Woody2627's Avatar
Oddometer: 1,014
Juice,
I daily commute on my CRF250L -14 miles each way. With a few driveway mods it's a very capable touring bike. Off the showroom floor it struggled at speeds above 60mph but after changing just a few things, and breaking the motor in, the bike is brilliant. I highly recommend this bike to anyone who doesn't need 50hp. With a simple EJK programmer you can almost reach 30hp on this motor which gives you plenty of power for pulling on the interstate or romping through the woods. Many regear down to a 13 tooth but I personally dont understand why. I guess it feels more like a woods bike but I didn't buy it for that. Hope you find what you're looking for! Cheers
If you tried it you would understand why. This little critter is way overgeared so they get good fuel consumption (coz they put such a tiny tank on it). A 13t sprocket puts the gearing where it should be, and its cheap as chips. Improved mine out of sight.
Old 07-30-2013, 04:24 AM   #5586
Auto-X Fil
Oddometer: 662
If you weigh 125lb and stick to flat tarmac at low elevation (say, Florida), the stock gearing works well. Otherwise, a 13t is pretty much required. I'm only 150lb and run the CRF at high speeds (75mph), but won't go back to the 14/40.
Auto-X Fil is offline   Reply With Quote
Old 07-30-2013, 04:36 AM   #5587
SAPB
SAPB's Avatar
Oddometer: 1,583
Way less slipping the clutch getting started in 1st with the 13t. I'm sold.
C14 - CRF250L, always cleaned while it's raining
CRF250L Service Manual http://www.hondampe.com.au/docs/owni...F250L13_OM.pdf
SAPB is online now   Reply With Quote
Old 07-30-2013, 04:41 AM   #5588
Ed@Ford
Oddometer: 1,630
Another reason for the gearing is noise. Many countries, like Switzerland and Austria use a "drive-by" noise standard, where the motorcycle goes thru a set of microphones, then must go to wide open throttle. The pass/fail at one time was 78 dB. That's an extremely quiet standard. The US test process/standard is very different.
Ed@Ford is offline   Reply With Quote
Old 07-30-2013, 09:05 AM   #5589
The_Precious_Juice
In Garrison.
The_Precious_Juice's Avatar
Oddometer: 2,157
Thanks for the feedback on the tank
I feel like this bike fits into my "must" bullets for an adventure touring vehicle.
1. Great gas miliage
2. Reliable engine
3. Low cost on maintenance, and low mainenance, and easy parts to find.
4. Less than 400lb bike with enough fuel on board to go 300 miles.
>>>>>Note: @ 75mpg the 250L would need 2 more gallons on board to go 300 miles. When you factor in fuel weight and the container to hold it, the total weight is 335lbs. So 65lbs under weight!
5. Reliable Start-ups
6. 21" Tire. I do not plan on shredding the dirt, but would like the control that comes with the tire size.
7. Adequate highway speeds around 60mph with good fuel economy still there, and no "buzzing."
As you can see, this narrows it down to only about four Bikes.
1. The Mighty DR (fuel economy is not where I need her to be).
2. the little dr (top speed is not where I need her to be.)
3. CRF250L (achieves all catagories).
4. DRZ400. (fuel economy is not where I need her to be.)
___
Pleasant surprises with the 250L:
1. $4,499. That's just $300 more than the little dr!
2. 6th gear. This is the first thumper I've researched with a 6th gear. Clearly this allows the 74mpg. Damn near every bike I looked at, folk have talked about the bike needed a 6th gear. I guess Honda got the message.
It's interesting how the bike looks like it is well over 50% dirt, but the 6th gear swings the bike in the other direction.
the 50hp 2011+ BMW G650GS only has 5 gears.
3. Good ergos. Sure, the seat needs work, but what bike seat doesn't.
4. Bash Plate. For the light trail riding I'll do, this will provide more than enough protection.
5. CBR250 engine. More parts are avaliable, and it has more miles and research on her.
6. such low maintenance! 8,000 miles is the next service after the 600 mile first service. Can't be right.
7. 43mm Fork inverted fork. This is a little bit of an over kill for the dirt riding I intend to do. But, yeah, its there, and maybe I can grow into it. I'm shocked that the 400lbs+ 650 do not have this.
Also, the adjustable suspension is a pleasent surprise, with 8.7" Front/ 9.4" rear.
8. 10" ground clearence.
9. commanding view with the 34.7" seat height. this height is damn near perfect for my less than 6 foot frame.
10. This bike could easily go to any access point on the TAT and provide a great ride.
11. I've had little reason to research what DOHC added to a bike engine, but I have, and like how it allows the 24hp engine to run smoother at higher rpms.
12. Really quite muffler!
13. Engine couter balancer. Very interesting.
___
Annoyances.
1. 2.0 gallon tank. I get why Honda just did 2. That's a 100-200 mile range. It's not built to be a touring bike, so breaks will be plentiful. I also look at it this way, when I drop my "ruck" and go slick, the tank will be perfect.
2. no hand guards
3. slim rear seat area (light cargo storage).
These are all forgivable.
__
The_Precious_Juice screwed with this post 07-30-2013 at 09:18 AM
The_Precious_Juice is offline   Reply With Quote
Old 07-30-2013, 09:16 AM   #5590
Kray
Kray's Avatar
Oddometer: 944
I'm 95% road (I daily commute mine) so need that overgearing to save my poor little wallet/motor.
Kray is offline   Reply With Quote
Old 07-30-2013, 09:35 AM   #5591
philosobrad
problem_solvent
Oddometer: 174
Originally Posted by kiwi5 View Post
looks good- I wonder if they ship to NZ......I'm loathe to give up me sheepskin but it is getting pretty ratty....
I'm open to grabbing one and shipping it to you for actual cost. Will send a pic later.l
2006 R1150GSA/SE, 640 Adventure x2, G650GS Dakar/Touratech Adv, DR650, Multiple airheads, RDs, Titan, Seca Turbo, TW200 x3, SV650 Track machine, etc.
philosobrad is offline   Reply With Quote
Old 07-30-2013, 09:37 AM   #5592
philosobrad
problem_solvent
Oddometer: 174
Originally Posted by dalehazelton View Post
How did you get the Coleman/Walmart pad on your bike? I tried and the plastic clips don't fit UNDER the seat and don't really work on the sides.
All the buckles and straps are under the seat. I flipped it around backward, I.E. back is now the front, and some coaxing and cursing. It's now on, AND I've had the seat unbolted, and bolted back on twice since with no issue.
It's aggravating for a bit, but doable. I'll try and post a pic later. I love the damned thing for ~20$
Old 07-30-2013, 09:43 AM   #5593
philosobrad
problem_solvent
Oddometer: 174
2. Reliable engine
___
___
Annoyances.
2. no hand guards
__
The suspension gets a bit limited on gnarly single track.......there's a fix for it via Racetech, as I'm sure you're aware.
It's gone EVERYWHERE my orange machines have gone....period. It argued a bit more, but did it without much drama.
I can't express how much I love this bike.
I'm an overweight 40 year old that rides rocky, nasty single track most weekends, commute exclusively by moto every day. And track days once a month. My past "enduros" have been high end, with catalogs of parts thrown at 'em. KTM to BMW to Husqvarna........none give me the simple satisfaction of this little rig. I'm transported back to 1979 flying down field rows on the Mississippi delta aboard a Trail 70 everytime I mash the start button. It's that good, mentally. And that, to me, makes up for anything she may lack everywhere else.
Old 07-30-2013, 09:57 AM   #5594
The_Precious_Juice
In Garrison.
Oddometer: 2,157
Thumb Great feedback!
Great post!
Old 07-30-2013, 10:26 AM   #5595
SAPB
SAPB's Avatar
Oddometer: 1,583
Fastrax
I just put my Dowco Fastrax on, after seeing how good it looked on Secondcreekrider's bike. I considered one of the Wolfman ones, as I have a tankbag already from them. but the price was right, and free shipping. I had a knock-off Givi on there, but with the case off, all these nubs stick up and catch you all the time. And I had it off most of the time. I did have to take the Manrack off to get the knock-off removed, but don't think it would be necessary to remove the rack to get the Fastrax on. http://www.amazon.com/Dowco-50144-00.../dp/B000ONZQF2
Times are GMT -7.   It's 06:16 AM.
