Old 08-02-2013, 02:27 PM   #5656
Avi8tor
ADV Poser
Avi8tor's Avatar
Oddometer: 220
Fender eliminator
Who has installed the DRC fender eliminator kit amd is happy with it? Brighter than stock?
Debating if Yoshi unit is worth extra dough.
CURRENT: None
PAST:
2013 CRF250L - 2009 DL650 - 1997 GL1500SE - 2005 DR-Z400S - 2008 DL650A - 2008 ST1300 - 2009 KLR650 - 2002 DR-Z400S - 1987 RM 250 - 1980 KD-80
Avi8tor is offline   Reply With Quote
Old 08-02-2013, 02:31 PM   #5657
r6realtor
Oddometer: 191
I think its brighter than stock for sure, do yourself a favor and when you install it,, silicon the whole thing up including the sides and front of the clear plastic that shines down on the plate, or you will get moisture/water in it. dont ask how i know.
r6realtor is offline   Reply With Quote
Old 08-02-2013, 03:05 PM   #5658
Avi8tor
ADV Poser
Avi8tor's Avatar
Oddometer: 220
Cool. Do you happen to have a pic of the tail light and then the brake light on? Harcomo took some pics of the Yoshi unit and it looked pretty good.
CURRENT: None
PAST:
Old 08-02-2013, 03:12 PM   #5659
r6realtor
Oddometer: 191
im sure if you googled it you could find pics i do not have any
Old 08-02-2013, 04:54 PM   #5660
Avi8tor
ADV Poser
Avi8tor's Avatar
Oddometer: 220
That's fine...just wondered. Does the DRC tail light have the capability to flash at a brake pull on its own or does it need the 12oclock labs flasher to do that?
CURRENT: None
PAST:
Old 08-02-2013, 06:58 PM   #5661
r6realtor
Oddometer: 191
needs the 12 oclock labs, I have the regular drc on my wr250r and the drc/12oclock labs on the crf, I will say that I have the smoked lens on the crf and regular red cover on the wr. The crf is just as bright even with that smoked lens its definitely eye catching!!!
Old 08-02-2013, 08:17 PM   #5662
jab1026
jab1026's Avatar
Oddometer: 91
Same with my CRF, oil drip/leak
Originally Posted by lloydpb View Post
I picked up the LRP on Saturday am and drove home (17 miles) to find a small oil leak on the brake pedal side of the engine. It is only a small leak but it is blowing down that side of the bike so looks bad.
I havent spoken to the dealer yet as they were closed yesterday, but I have marked where the leak is coming from on the attached photo - does anyone know what this protusion hides in the crankase - is it some sort of breather or pressure release?
Thanks in advance for any ideas - fantastic bike apart from this, so smooth and easy to ride.
Lloyd.
This is the same issue that my CRF has... Guys may I ask what to do..
Another issue on my CRF is that when soak in the rain the cluster gauge panel is having a moisture inside...
jab1026 is offline   Reply With Quote
Old 08-02-2013, 11:11 PM   #5663
Infidel707
Oddometer: 23
First is normal up until first servicing, second is normal as well and hasn't been a problem for me (it rains fall-spring here).
Infidel707 is offline   Reply With Quote
Old 08-02-2013, 11:44 PM   #5664
lloydpb
lloydpb's Avatar
Oddometer: 45
Mines in for its first service on Tuesday - I will let you know what happens,
Lloyd.
lloydpb is offline   Reply With Quote
Old 08-03-2013, 04:03 AM   #5665
jab1026
jab1026's Avatar
Oddometer: 91
Lloyd.
Thanks...
Old 08-03-2013, 04:56 AM   #5666
streaks77
streaks77's Avatar
Oddometer: 27
Originally Posted by RayMurdock View Post
May I ask which mirrors you have mounted and do they use the stock mount hole? Nice surroundings btw! :)
( I have the $100+ Doubletake foldable mirrors, but I don't like the look of 'm )
Was wondering this myself, do tell, please r6realtor
streaks77 is offline   Reply With Quote
Old 08-03-2013, 05:08 AM   #5667
jab1026
jab1026's Avatar
Oddometer: 91
Originally Posted by SAPB View Post
In looking at the cutaway view in the Helm manual, it appears to be the pressure relief valve. So maybe there was too much oil in there?
What is this pressure relief valve? Do the function of this valve is to spit out extra oil in the engine....
Old 08-03-2013, 05:34 AM   #5668
Wargasm
Wargasm's Avatar
Oddometer: 191
In my experience internal pressure relief valves don't normally squirt oil outside the engine. The normally act to relieve pressure if there is some sort of blockage in the oiling system by blowing off excess pressure form the discharge of the oil pump back to the sump. You want to get the dealer to look at this as a new engine shouldn't be leaking oil form anywhere.
Wargasm is offline   Reply With Quote
Old 08-03-2013, 05:34 AM   #5669
SAPB
SAPB's Avatar
Oddometer: 1,493
I have not had this happen on my bike. You can see it in the Helm manual. You get to it by removing the oil pump. No mention of function, but in my opinion, it's there to let some oil exit, before it causes damage internally from too much pressure. I mean, there's a hole to let it out, so they must have determined it was necessary just in case somebody puts in more than the specified amount of oil.
edit: Wargasm posted while I was typing. Definitely get the dealer involved, getting an answer right from a hands on tech person.
C14 - CRF250L, always cleaned while it's raining
CRF250L Service Manual http://www.hondampe.com.au/docs/owni...F250L13_OM.pdf
SAPB screwed with this post 08-03-2013 at 05:55 AM
SAPB is online now   Reply With Quote
Old 08-03-2013, 06:46 AM   #5670
r6realtor
Oddometer: 191
http://www.ebay.com/itm/UNIVERSAL-MO...item27d5fd4e2e
Times are GMT -7.   It's 02:45 PM.
