Old 08-03-2013, 10:19 AM   #5671
r6realtor
Oddometer: 219
exactly, I have had them on my wr for almost a year and the ones on the crf for about 2 months and I take the crf off road quite a bit more, they have held up great, they need a little modification but its pretty simple.
r6realtor is offline   Reply With Quote
Old 08-03-2013, 11:08 AM   #5672
rompe
Oddometer: 60
My own, it had the same kind of 'micro oil leak'. After first service, I've never seen oil leakages anymore.
Enviado desde mi Optimus 2X usando Tapatalk 2
My other toy has tits . . .
rompe is offline   Reply With Quote
Old 08-03-2013, 09:07 PM   #5673
Vzuke
Vzuke's Avatar
Oddometer: 145
Cool mirror mounts.
More details please.
Oh and the most important question, Can you see anything behind you in the mirrors?
I had some wide bars on my DT250 Yamaha back in the 70's and I mounted the mirrors just below and inside of the switches. They were the classic round handle bar mounted mirrors. I just cut the chrome rod down to a nub.
I was looking around my waist, under my arms. Unfortunately this technique would not work well with my increased girth.
Vzuke is offline   Reply With Quote
Old 08-04-2013, 08:56 PM   #5674
kiwi5
Oddometer: 378
13/48 sprocket set up
Wooo-hoo, if you want your CRF250L to really rock off road (and are not too bothered about road use) then go with a 13/48 sprocket set up. We have done this with the work bike and it has some insane torque- I wouldn't do this on my 250L, but I do a lot of road.......
kiwi5 is offline   Reply With Quote
Old 08-04-2013, 10:05 PM   #5675
jab1026
jab1026's Avatar
Oddometer: 92
Nice.. have to try this one hehehe
jab1026 is offline   Reply With Quote
Old 08-05-2013, 02:58 AM   #5676
SugarDust
Kulia i ka nu'u
SugarDust's Avatar
Oddometer: 859
I just rode the Moose Run dual sport rally B/B+ loop this weekend on my LRP. In prep for the single track, I changed out my set up from 13/42 to 12/42 - it was perfect for rocky 2 track as well as the easy/intermediate single track I rode and was able to cruise at about 60 mph on the paved sections no problem. I don't recommend it for the street use at all but recommend it for dirt focused dual sporting. On a side note I was worried that the Q4 would be too loud to pass the 96db off road limit - it came in at 89db, well under the limit. However, the suspension needs some work...guess that will be my winter project this year.
2014 BMW R1200GS -- 2013 Honda CRF250L -- 2013 KTM 250 XCW
In loving Memory of Cruzn2b - 1953 - 2014
SugarDust is offline   Reply With Quote
Old 08-05-2013, 04:25 AM   #5677
SAPB
SAPB's Avatar
Oddometer: 1,583
Wow, broken collar bones, upside down bikes.... Looks like great riding out there!
C14 - CRF250L, always cleaned while it's raining
CRF250L Service Manual http://www.hondampe.com.au/docs/owni...F250L13_OM.pdf
SAPB is offline   Reply With Quote
Old 08-05-2013, 04:42 AM   #5678
SugarDust
Kulia i ka nu'u
SugarDust's Avatar
Oddometer: 859
Sure enough - Over 2 days of riding the B/B+ was 170+ miles of pretty excellent Colorado riding
Old 08-05-2013, 09:53 AM   #5679
Turk
'Bab Man
Turk's Avatar
Oddometer: 114
I've got a 13 front, will adding a 42 rear make much difference? Can I make this switch without changing the chain?
Turk is offline   Reply With Quote
Old 08-05-2013, 10:31 AM   #5680
Auto-X Fil
Oddometer: 662
It's a smaller step than your 13t was.
Stock to 13t = -7.1%
Stock to 13/42 = -12%
And yes, you can do it with your stock chain. You moved the axle back 5/32" from the stock position by removing a tooth, now you'll push it forward 5/32" from stock by adding two.
Auto-X Fil is offline   Reply With Quote
Old 08-05-2013, 10:38 AM   #5681
Auto-X Fil
Oddometer: 662
Here's my deal. I bought a Versys. I wanted passing power (got it), range (200mi+), and storage (came with soft bags). But you know what? I want to ride the LRP all the time. It's just more fun! I will give up the passing power (and easy wheelies) of the Versys for the stupid fun of the Honda, but I want to work on the other two items.
The tank is easy - IMS will eventually release the 3.1 gal tank. Not great, but worth it.
For the bags, I have these requirements:
1) Saddle bags - I want to keep the ability to strap big stuff on the tail, or slide way back there.
2) No using the seat bolts. I don't want to need take the rack off to get under the seat.
3) Roomy. A helmet each side would be perfect, but I can deal with slightly smaller
4) Easy to get in and out of.
5) Waterproof would be nice, but optional.
I don't want to lose the pillion pegs, but it's not a deal-breaker.
Right now the DirtBagz Ranger setup looks like the best match. Any other suggestions?
Old 08-05-2013, 10:53 AM   #5682
Turk
'Bab Man
Turk's Avatar
Oddometer: 114
Thanks for the info. Am I right in understanding that anything larger than a 42 rear will need a longer chain?
Old 08-05-2013, 11:08 AM   #5683
r6realtor
Oddometer: 219
I did a 13/43 and it fit fine but took of the 43 just felt to steep for the street for right now, maybe once I break in the motor a bit more I will put it back on. My buddy runs the 13/43 combo and his doesn't feel nearly as corked up or high revving as mine does but he has about 1200miles on his compared to my 250miles.
Old 08-05-2013, 11:08 AM   #5684
Auto-X Fil
Oddometer: 662
You might be able to squeeze a 43 on there. 45 will NOT fit. If you want to go lower, you'll need wither a 12t front or a longer chain.
As noted above, 12/42 is AWESOME in the dirt. However, it runs out of steam real quick on pavement, and forget about getting on the freeway. 12/42 also matches your stock chain length and axle position.
Old 08-05-2013, 12:28 PM   #5685
Turk
'Bab Man
Turk's Avatar
Oddometer: 114
Cheers guys, I'll order a 12 and a 42 and play around a little, see which works best!
Times are GMT -7.   It's 10:28 PM.
