Old 08-21-2013, 11:54 PM   #5986
maginashun
youngling
maginashun's Avatar
Oddometer: 22
Originally Posted by Vzuke View Post
Yes, Warp Nine rims. I went straight to Warp Nine and bought the tires (Pirelli Diablos) with the rims.
Moto Tires:
110 tire up front 17 X 3.50 rim
140 tire for rear 17 X 4.25 rim
The forks are narrow on this bike, that's why the 110 up front. A 120 is the same width as the fattest part of the forks (near the seals). You could probably squeeze a 120 in but it will rub the snap rings (the wire that prevents the fork protectors from rubbing on the forks). I have seen some guys shave the edge of the tires for clearance. You do have to trim the inside of the fork protectors. No monster rotor with this set up, same size as stock. Something about how the stock caliper was mounted and the extension bracket would be too thin.
The 140 is a good fit but it was rubbing the stock exhaust when the suspension was compressed. My wife's bike was lowered. I had to put a spacer on the Yoshimura exhaust mount to kick it out a little so it wouldn't rub. I had to trim the chain guard a little also.
Lowering is a game of Millimeters. If I would have been thinking I should have gone with a 60 series tire instead of the 70 series, Lower profile. Not sure if they are wider though. That might cause more clearance issues......
Thanks for posting. I've been wondering what the Warp 9's with tires look like installed. Interested in seeing more photos. Like one from straight on. Want to see how thin that front tire looks.
maginashun screwed with this post 08-22-2013 at 12:09 AM
maginashun is offline   Reply With Quote
Old 08-22-2013, 03:25 AM   #5987
SAPB
SAPB's Avatar
Oddometer: 1,661
MT43 info
Searching, I came across this. It has recent posts at the end. It would be easier if it only contained information on a bike of our weight/power, but dig through. Pay attention to the location of the inmate for reference to your ride area. One thing that concerns me is under low pressure (where this tire shines) the sidewall is more prone tearing due to it bulging at low pressure, and catching on a rock or something than a true DOT knobby like the D606. Absolutely gonna need rim locks, I run TUbliss. Over on the KLX thread there are quite a few folks running MT43, and that bike is similar to the power characteristics of our bike. Maybe someone from over there will chime in.
http://www.advrider.com/forums/showthread.php?t=398746
C14 - CRF250L, always cleaned while it's raining
CRF250L Service Manual http://www.hondampe.com.au/docs/owni...F250L13_OM.pdf
SAPB screwed with this post 08-22-2013 at 03:36 AM
SAPB is offline   Reply With Quote
Old 08-22-2013, 04:34 AM   #5988
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,926
Originally Posted by SAPB View Post
"IMS fuel tank capacity 11,100 ml = 11.1 liter = 2.93 gal.
111 oz or .87 gal more than the stock fuel tank."
That's it ? , seems hardly worth the cost and trouble of installing it.
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is offline   Reply With Quote
Old 08-22-2013, 05:33 AM   #5989
Kray
Kray's Avatar
Oddometer: 1,076
It's definitely not a priority mod for those on a budget.
'15 WR250R Build Thread
Kray is offline   Reply With Quote
Old 08-22-2013, 05:56 AM   #5990
DockingPilot
Oddometer: 9,926
The CRF250L Owners thread
Well I'm not on a budget but I've had the ims tanks on my 610 husky ( increased range to 250 miles) and my DR650 which also took it to 5 gals and 250. But for not even a gallon increase seems not worth the effort to me. You could say its a smaller framed bike, and it is, but IMS great increased the range on the WR with that design.
Better then nothing I suppose. Maybe Acerbis will be next to offer a tank for the CRF.
Frank Reinbold
Old 08-22-2013, 06:23 AM   #5991
kb7tgr
Oddometer: 58
I completely agree Not even a gallon more???? Hopefully acerbis or CLark will come out with something that
will actually make sense. I carry nearly 2 gallons in my rear mounted roto-pax (1.94) and my decision is not
budget based either.
kb7tgr
Jim
kb7tgr is offline   Reply With Quote
Old 08-22-2013, 06:36 AM   #5992
bluzharp
Oddometer: 92
It's 42% more fuel without having to figure out a way to haul external tanks. If your day trips are over 100 miles, in remote country, it's a big deal. I have a WR250R with a 3 gallon tank and my buddy is on the CRF250L with the factory tank, and it's something between a scheduling issue and a real pain in the ass to make sure we can get home. I wish the factories would just put 3 gallon tanks on them from the beginning.
bluzharp is offline   Reply With Quote
Old 08-22-2013, 06:48 AM   #5993
roundtripping
Adventourist
roundtripping's Avatar
Oddometer: 1,704
+1
Sent from my Nexus 4 using Tapatalk 4
12 F658GS
13 Honda CRF250L
My SPOT Tracker
roundtripping is offline   Reply With Quote
Old 08-22-2013, 06:50 AM   #5994
DockingPilot
Oddometer: 9,926
The reality is, 42% of not nearly enough, is still "not enough".
Frank Reinbold
Old 08-22-2013, 06:51 AM   #5995
DockingPilot
Oddometer: 9,926
The remote country I have ridden dictates at least 200 miles.
Frank Reinbold
Old 08-22-2013, 06:57 AM   #5996
Auto-X Fil
Oddometer: 703
Plus, it's capacity on top of your reserve:
2.06 gal - 0.4 gal reserve = 1.66gal
2.93 gal - 0.4 gal reserve = 2.53gal
At the 62mpg I average, that means my range goes from 103 miles to 157 miles. Sure, it's still a little weak, but it makes a big difference for me. With the kind of riding I do, I'm usually <100 miles between gas stations. But, I often cut it really close, and need to haul gas just in case. Now I have an extra 50+ miles of reserve.
For many people, They need 250-300 mile range. Once you're packing several gallons on the back anyway, this is a pointless mod.
Auto-X Fil is offline   Reply With Quote
Old 08-22-2013, 07:21 AM   #5997
siyeh
Lawn Nazi
siyeh's Avatar
Oddometer: 1,689
I've gone 140 miles several times commuting here in Wisconsin on the stock tank.
siyeh is offline   Reply With Quote
Old 08-22-2013, 08:40 AM   #5998
DockingPilot
Oddometer: 9,926
Commuting and riding off road where your usually high in the rpm range and blipping the throttle with a loaded bike will give you different mpg.
I was going to say 250 to 300 myself but didn't want to sound exaggerated. But it's true. The big empty in Wyoming. The western tat and so on. You need that level of range to ride without worry.
Frank Reinbold
Old 08-22-2013, 09:11 AM   #5999
Kray
Kray's Avatar
Oddometer: 1,076
The bike is brilliant for me daily commuting 12 miles each way. Whenever I got to the last bar I just stop and put a gallon in. I can usually make it 80 miles. Offroad or longer scenic trips start to get sketchy. I'm always the one asking to stop for fuel. I think a 3 gallon tank with a rotopax in the rear would be my ideal setup. I'm not sure myself nor the stock suspension/frame would want to take much more weight. My current plans are to add Wolfman side racks and a top rear rack with a rotopax for fuel. This should really increase the range of the bike, but I have a feeling I'll be knocking on Race Tech's door shortly after.
Old 08-22-2013, 12:28 PM   #6000
MoonBeamer
The Mountains are calling
MoonBeamer's Avatar
Oddometer: 151
Subframe Crack
This is what happens when you overload your rear rack and ride over lots of rocks and water breaks.
I cracked/bent the sub-frame. I plan on getting some angle iron and welding it up to provide more support. So i can carry my gas and gear on the rear rack.
"I don't mind the pain, Until it starts hurting"
YouTube: http://www.youtube.com/lost1byte
2013 CRF250L (LRP) Woot!!
2014 K1600GTL (For street)
MoonBeamer screwed with this post 08-22-2013 at 07:27 PM
MoonBeamer is offline   Reply With Quote
Times are GMT -7.   It's 09:38 AM.
