Old 08-27-2013, 03:55 PM   #6091
kiwi5
Oddometer: 383
Originally Posted by gnath9 View Post
I have 13/42's and can cruise at 65-70 mph .... tops out at 80 mph.
Is that with a speedo corrected or GPS verification? This is sounding promising. Does the 13.42 set up improve bogging in 2nd gear?
kiwi5 is offline   Reply With Quote
Old 08-27-2013, 06:03 PM   #6092
Auto-X Fil
Oddometer: 662
13/42 is buzzy at 70mph per the GPS, but not going to hurt anything. 60-65mph is great.
It really improves the low end. If you care more about dirt performance than highway, it's a great setup.
Auto-X Fil is offline   Reply With Quote
Old 08-27-2013, 06:08 PM   #6093
kiwi5
Oddometer: 383
That's it then- I'm going to go with a 14/45 set up asap. I will keep a 13t handy if the ride is looking tough. I have read that a 13t sprocket will increase wear on the chain/front sprocket, but by how much? So I'll play it safe and go back to the 14. Now....how many extra links am I going to need? I have access to a OEM CRF250L chain so I can get extra links, now I just need to get two master links....
Old 08-27-2013, 06:21 PM   #6094
gnath9
gnath9's Avatar
Oddometer: 271
I have a properly calibrated speedoDRD. I also agree a little with your comments on a 14 .... my next set will be 14/48
I do not use my bike for commuting so If I can cruise at 60 that's fast enough for me.
gnath9 is offline   Reply With Quote
Old 08-28-2013, 01:04 AM   #6095
kiwi5
Oddometer: 383
We have a CRF250 L at work that is set up with 13/48 sprockets; man this bike is insane! I have climbed wet muddy/grassy hills that I would never try with our other work bikes (crf230L's). VERY buzzy on road, I think I will swap out the 13 front sprocket (on our work bike) for the oem 14 and see how that goes on the road...hmmm...ahh yes, the eternal sprocket set up question. Almost as exiting as the "what oil do I use..." !! Well, at least I get exited about the whole sprocket thang. Not so much for the oil thang anymore....As long as my personal CRF250L can cruise at 90KPH and handle the occasional car passing speeds of up to 110kph, then I will go with the gruntiest sprocket set up possible. I am not blessed with a trailer (or vehicle to tow the trailer) so I have to ride to my adventure sites!
Old 08-28-2013, 03:44 AM   #6096
Auto-X Fil
Oddometer: 662
Just one extra link. For every 4 teeth you add to the sprocket combo, you need to add one full link to the chain.
Old 08-28-2013, 10:06 AM   #6097
jsonder
Tired Old Fart
jsonder's Avatar
Oddometer: 533
That assumes the same size rear tire. Often the rear tire is changed in conjunction with the rear sprocket. I went from 100 to 106 links when I changed the rear sprocket from 39 to 48 teeth, and, changed the rear tire to a Dunlop 606 120/90 from the previous Pirelli 21 120/80.
That was on a CRF230L; your mileage may vary.
To be safe, I bought a 120 link chain and cut it down once I found what I needed. With another master link I used 5 more links to turn my old chain into an emergency spare chain for the new configuration.
John
2009 Honda CRF230L (L'il Red Piglet)
2014 Honda CB500XA (Daily Rider)
jsonder is offline   Reply With Quote
Old 08-28-2013, 10:31 AM   #6098
gnath9
gnath9's Avatar
Oddometer: 271
Well this explains why some people say you can put 13/43's on with the stock chain.
I put on 13/42's and I know I could not have gone with a 43 but, I also put on a IRC TR8 Battle Rally 4.50x18 tire on there wich is a lot bigger than stock. Next time I will get either 4.00x18 or 100/100-18.
Old 08-28-2013, 12:35 PM   #6099
Auto-X Fil
Oddometer: 662
Right - 4 teeth per link is what you need to keep the axle at the same position. If you want to move the axle back to make room for a bigger tire, that'll require more links - and adjustment room in the slider mechanism, brake caliper, etc.
Old 08-28-2013, 03:23 PM   #6100
Woody2627
Skinny Decaf Latte Thanks
Woody2627's Avatar
Oddometer: 1,039
Woody2627 is offline   Reply With Quote
Old 08-28-2013, 04:00 PM   #6101
SAPB
SAPB's Avatar
Oddometer: 1,598
Originally Posted by Woody2627 View Post
Pretty sure they are talking about the tire rubbing on the fender thing near the front of the swing arm, or the swing arm itself, confusing to me also. Gear swap brings the tire forward, unless you go with more chain, to bring it more to the rear. I could be wrong, not gone there yet.........
C14 - CRF250L, always cleaned while it's raining
CRF250L Service Manual http://www.hondampe.com.au/docs/owni...F250L13_OM.pdf
SAPB screwed with this post 08-28-2013 at 04:08 PM
SAPB is offline   Reply With Quote
Old 08-28-2013, 07:54 PM   #6102
jjustj
cum petris et choris
jjustj's Avatar
Oddometer: 5,557
small bikes(crf250l) on colorado back country discover routey
great write up
worth a read
http://advrider.com/forums/showpost....ostcount=149:D
Broad, wholesome, charitable views of men and things cannot be acquired by vegetating in one little corner of the earth all one's lifetime. Mark Twain
RIDE STEALTH,
http://www.advrider.com/forums/showthread.php?t=348508
http://www.advrider.com/forums/showthread.php?t=489958 Sunday worship, a strap-on, and Does this water taste funny?
jjustj is offline   Reply With Quote
Old 08-28-2013, 09:10 PM   #6103
rickypanecatyl
SE Asia adventure tours
Oddometer: 1,128
Originally Posted by MoonBeamer View Post
This is what happens when you overload your rear rack and ride over lots of rocks and water breaks.
I cracked/bent the sub-frame. I plan on getting some angle iron and welding it up to provide more support. So i can carry my gas and gear on the rear rack.
FWIW my KLX250 subframe looked just like that. Bikes and parts here in Malaysia are big bucks but welding is good and cheap. They ended up taking about 3" of rolled steel that was slightly larger inner diameter than the subframe and grinding it down till it just barely fit and welded it back with that reinforcement in the center. Then they added cantilever type flat pieces of steel under the frame.
I've almost always got a heavy Givi box on the back of my bike and that weld job held up for thousands of miles. Going thru Thailand, Myanmar, Laos on a 6K KM trip that was at least 25% washboardy type off road I weighed the box and it was 17 kg or 37 lbs!
My guess is at most it only added 3 lbs to the subframe... probably less.
rickypanecatyl is offline   Reply With Quote
Old 08-28-2013, 09:37 PM   #6104
rickypanecatyl
Oddometer: 1,128
Originally Posted by hurielg View Post
Just got my CRF250L about two weeks ago. I'm brand new to DS, and brand new to off-road in general. Took it for its first real off-road trip yesterday...went swimming.
I dropped the bike about 10 times. Most of that was the back tire spinning out from under me and completely going sideways. Am I giving it too much throttle?
My bike experience has been street bikes only, crotch rockets. I realize dirt is different, but i felt like an ass dumping the bike all day.
It does look like you had lots of fun though! Thanks for being willing to share your stories for our entertainment! :)
The series of DVD's here is really, really good for learning to ride in the dirt:
http://www.dualsportriding.com/
Ned has a way of making his points simple, easy to remember. It's short but you should watch it several times; watch the whole thing once then re watch the first section then go out and practice it for several hours.
Old 08-29-2013, 03:43 AM   #6105
SAPB
SAPB's Avatar
Oddometer: 1,598
Originally Posted by jjustj View Post
Yup, worth the read. Love to try that.
Times are GMT -7.   It's 08:52 PM.
